Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
I have whirpool gold series central park edition side by side and I just replaced water filter now its leaking in freezer by ice maker
gaeb7
  • 25 Answers
SOURCE: hotpoint csx22bc 21.7 cu. ft. leaking water on freezer side
Look for obstruction at the drain tray for the freezer. Common to have plastic wrap sucked into that area.Or gunk in the drain line. Blow through line to insure the gunk is not an issue.
Posted on Mar 01, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Whirlpool Gold Ice maker doesn't work
You definitely have something wrong with the ice maker if the water has turned to ice Schmerold. And the IM is not harvesting. The way it works is the IM needs 28 degrees F to harvest. If the coils below in the condenser are dirty the IM won't try to harvest. The Ice Mold thermostat is mounted on the firewall of the Ice mold in its own little cubby whole. To access it you will need to remove the head. Then remove the shell separating the Ice mold from the heads housing. There you will find the ice mold thermostat. It's only function is to get it on. If the temperature is right in the freezer. To test this precious thermostat one needs only to stick it into a freezer and let it hang out for an hour or so. Then grab it and check it for continuity. If it is open it has failed and belongs in the file 13. It is easily replaced and inexpensive.
On your model, ice maker operation is controlled by an optical sensor mounted on both sides of the freezer liner. The usual failure of this model is a bad emitter board, located in one of these recesses. You may view the service instructions for checking this sensor.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
I will also send free manual for you through email. And Rate my assistance.
http://servicepartstec.blogspot.com/
Posted on Apr 04, 2009
rylee_smith
  • 8619 Answers
SOURCE: ice maker stopped
Hi!
Please check these:
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
If your ice maker has a small red plastic lever, lower it to lower the wire.
If there's no plastic lever, simply lower the wire.
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 23, 2009
SOURCE: ice maker stopped making ice. water works fine
chande the filter
Posted on Jul 12, 2009
woodchuck789
  • 4059 Answers
SOURCE: Whirlpool Gold Side by Side Ice maker not making ice.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Posted on Aug 31, 2009
Water pooling and freezing in lower freezer, whirpool gold french door? How do I rmove liner in fridge to follow line?
Sounds like a clogged drain. Remove food, remove bins and shelves. Remove ice maker if freezer is in the bottom. Remove back panel. .melt ice on drain pan and run hot water into drain.
Feb 14, 2015 | Whirpool Refrigerators
Ice maker leaks water-whirlpool GD5SHG
please check fill valve as it could be open. also check if supply tube at the back in the freezer is plugged with ice. check if the fan running in the freezer
May 13, 2014 | Whirlpool Gold White-on-White 21.9 cu. ft....
My Whirpool Ice Maker Model GI15NDXTS won't stop making ice
check bin thermistor connection or replace it is inside the bin on the right side
Aug 04, 2012 | Whirlpool Gold Series GI15NDXT 15"...
Whirlpool Refrigerator water leak through Ice dispenser
You need to remove the ice maker and open the front carefully. It has small micro switches inside it and it sounds like one that opens the water control valve is stuck in the on position. Be careful not to loose the arm spring and how that goes back together as you take it apart. Sea Breeze
Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker stopped
Hi!
Please check these:
Thanks
Rylee
May 23, 2009 | Whirlpool Gold Series GI15NDXT 15"...
Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Nov 15, 2008 | Frigidaire Freezers
Whirlpool gold ice maker problem
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker and frige
A COMMON FAILURE FOR THE WHIRLPOOL REFRIGERATORS THAT CAUSE NO COOLING IN THE FREEZER IS A BAD RELAY ON THE COMPRESSOR.
LISTEN CLOSELY FOR ABOUT 5 MINUTES TO THE BACK OF THE REFRIGERATOR. IF YOU HEAR A CLICK AND THE COMPRESSOR HUMS AND THEN CLICKS AGAIN AND SHUTS OFF THE COMPRESSOR, THE RELAY IS MOST LIKELY BAD. ABOUT A 40 DOLLAR COMPONENT.
ALSO, CHECK THE FREEZER BACK WALL. IF IT IS FROSTED UP, THERE IS A FAILURE OF THE DEFROST CYCLE. YOU WOULD HAVE TO CHECK THREE COMPONENTS. THE DEFROST CONTROL, HEATER, AND BI-METAL.
Apr 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
