Question about Janome Sewing Machines
How do I do a satin stitch on a Janome 6500 ?
    Champion:
  • 241 Answers
Set a zig zag stitch and then make the length short.
Posted on Oct 13, 2013
4 Suggested Answers
SewTechWayne
  • 186 Answers
SOURCE: I need to satin stitch around the edge of a project
Try using the zig-zag setting, but adjust the stitch length to .3 or .4 (very small).
good luck!
Posted on Jan 31, 2009
Tally Girl
  • 1128 Answers
SOURCE: I am having trouble trying
Have you changed the needle(s) recently in your overlocker? I would put in a new sharp size 70 for satin, turn down the stitch length a fraction, put the blade about middle of its range, thread tensions all to 5 and test serge. Then adjust the two looper tensions until you get the thread wrapping around the smoothly but not bunching up the satin within the stitch. Also put your differential to zero for a start and see how the stitching looks.
It is easy to forget to change the needles in the overlocker because it is usually a bit of a fiddle but they will go dull. And remember to just loosen off the needle screw a little, enough to remove the old and insert the new, don't turn it all the way out as they come out and there is often a little ballbearing up in the needle housing that can drop out and get lost with some models.
Also most sergers the two needles sit at different heights so make sure you've got them both fully up into the housing and sitting right, tweezers are a big help with this, I usually pop the needles into the housing, then balance the needle points on the screwdriver blade and lift it right up until it is all the way up, then hold firmly with the tweezer and do up the needle enough to hold it. Then repeat with the 2nd needle, then go back and recheck the first one until they are both spot on. Then manually turn through one stitching sequence to ensure that the needles are not touching the loopers, if you hear any touch, go back and recheck the needle placement again.
If you are just neatening single layer edges I would just use a 3 thread on satin and take out the left needle so it doesn't leave holes. If you are seaming two layers, then go to four thread (both needles) but you may need to use a bit of differential if the seam is puckering a bit.
If you find that changing the needle makes no difference at all, and stitches are still not forming correctly then it is possible that the timing is out a bit and the machine would need a service to sort this out. Hope this helps you out.
Posted on Apr 18, 2011
Testimonial: "thanks heaps I will try all that"
Tally Girl
  • 1128 Answers
SOURCE: How do you lengthen stitch. The stitches are so
your machine should have a stitch length dial on the right hand side above the flywheel, it might have numbers from 0.5 to 3 or 4, higher number for longer stitch (effectively this moves the foot and feed dogs faster in relation to the needles to make the stitch longer).
If you have the Serge Pro SW432 that your enquiry is linked to and you have not used a serger before, then definitely get hold of the manual, you will need it. Sergers are very different to sewing machines - once you've mastered one, its easy, but there is a learning curve.
Firstly, ALWAYS extend the thread aerial up, you'll see loads of images of sergers sitting nicely with the aerial in the lowered position, great for moving them to avoid damage. But they won't work well, a serger seams at 1500 stitches per minute and the thread streams off the cones so you need to ensure there is a good clear feed via the aerial to the tension dials.
Buy good quality thread cones and keep it out of the sun and dust. Cover your machine when not in use (lower the aerial first). You could start with white, grey and black thread as this will cover a lot of fabric prints/colours etc. To change thread colour, you will need to cut and knot on the new thread for the two loopers (right hand side cones) - do this about 6 inches above the first thread guide, and then chain off to feed these through down to the needle plate, when you see the new colour come through okay, stop. Repeat the process for the needle thread or threads (3 or 4 thead depending on what stitch you are sewing) but stop chaining when the thread knot is above the needles. Stop, loosen these tension dials and pull the thread down, cut out the knot with scissors and thread the new colour through the two needles. Use threading wires if you have them, or tweezers. Pull both these and the two looper threads together under the pressure foot, lower the foot, turn your tension dials back to 5 and chain off. The thread sequence is important, mostly top looper, bottom looper, then needles, this is so much easier demonstrated than explained.
If you can find a classroom/shop offering overlocking user lessons, go take a couple, its well worth the money. Otherwise go to you-tube and watch all the videos you can search on sergers, threading, etc.
Good luck with your serger, please respond with 4 thumbs if this has been helpful to you. :-)
Posted on May 19, 2011
What number is satin stitch on Piaf quilt expressions 4.0
A satin stitch is simply a zig-zag stitch that is shortened enough so the threads lay next to each other without laying over another but also without any space (fabric) showing between. Keep in mind that the thread weight will cause the satin stitch to differ.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Feb 19, 2017 | Sewing Machines
Janome MC11000 how do you realign your embroidery unit. When doing applique the satin stitches do not cover the tackdown stitches. I've tried several designs, all by quality digitizers and all the...
P, attern is from monster knits for little monsters. I'm attempting to do the little piggy on page 24. It a pull over hat with a neck ruff.
Dec 05, 2013 | Sewing Machines
How do i do a satin stitch on a janome 6500
here is a link for a manual, see if it's the right one
http://www.sewingpartsonline.com/instruction-manual-janome-and-newhome-mc6500p.aspx
if it's not the right one then contact janome about a manual
Oct 13, 2013 | Janome Sewing Machines
How to adjust tension janome 4400
Before you go changing settings... make sure you are stabilizing the fabric correctly. Towels especially requires a stabilizer on top AND on bottom.
Dec 06, 2012 | Janome MC 4400 Computerized Sewing Machine
The button holes that I want to do are larger than the automatic buttonhole will do on my Janome MS5027, is there a way that they can be done manually?
Mark your garment with chalk taking care to mark the start point and end points and a straight line to follow. Set your machine up for a fairly wide bar tack (zig zag in place) Then position the needle left and set it up for a satin stitch (fairly narrow) slowly stitch forward until you get to the end mark. Then do another bar tack. At this point you move your needle to the other side and satin stitch in reverse until you get to the first bar tack.
I would test this on a scrap piece first. Then proceed.
Jul 25, 2012 | Janome Sewing Machines
Janome 2030 QDC How to predict whether the buttonhole (24) will start forward or backward? I power off the machine and reselect stitch 24 and move the buttonhole presser foot to the start position every...
does it sew buttonholes both ways?
My Janome 6500 always buttonholes away from me, so when it starts, it sews the near bartack, then stitches backwards down the right hand side of the buttonhole. It then comes back with little straight stiches on other side and sews the zigzag backwards on the left side, then the far bar tack. I would have thought your Janome would do the same stitch sequence.
Jul 16, 2011 | Sewing Machines
I don't know how to make satin stich Janome DC2010
As a general rule of thumb, satin stitch is obtained by selecting zig-zag, turning stitch width up to 3 or 4 and stitch length to 0.5. If you have a clear plastic open toe sewing foot, put that on to help view the area.
If you are doing applique (attaching pieces of fabric to another surface) with a satin stitch, you may also need to use tear away stabiliser underneath or interface the fabric first, it depends on what/where you are doing the satin stitch onto.
And a nice machine embroidery thread will give you a much silkier appearance than plain thread.
Mar 13, 2011 | Sewing Machines
What settings for doing zig zag for satin stitch around applique. I have used 3.5 width and 0.2 length but the fabric has a tendancy to pucker and the stitches sometimes bunch
It depends on a couple of things. Depending on the fabric you're using you might want to use a stabilizer like an iron on tear away. If the stitches are bunching the stitch length might be to tight. Try going to 0.3. if the stabilizer doesn't work. With the stabilizer on, it will keep the fabric firmer so it won't pucker. Make sure you have the decorative stitching foot on the machine with the little indentation for the satin stitch to ride in. If you have the wrong foot on, this will cause bunching too. Let me know if this helps.
Aug 22, 2010 | Janome Memory Craft 4900QC Mechanical...
Janome 6500 will only stitch one stitch each time I press the peddle
the lock button is stuck on the front n of you mech.
Apr 15, 2009 | Sewing Machines
Sewing Machines Logo
93 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
