Question about MSI MS-N014-ID1 Netbook PC - 9S7-N01441-262
I can't open my pc. when the technician check my pc he said that the problem is the key board. Is it possible that the key board is the main reason why my pc is not working
    New Friend:
  • 3 Answers
Possibly
Posted on Oct 13, 2013
Screen Flickers
There are many reasons for this fault. Contact any service technician. The main reason is with fault with its main power supply regulator board itself. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 25, 2015 | Vizio L32 32 in. LCD HDTV
Vizio e470i-ao won' turn on, power supply board replaced still no picture or sound, led power on indicator light comes on momentarily then goes out?
Power ON signal voltage should come from the main board to power regulator board. It does not come now. Check for the reason. Probably, the main board will have the fault. Contact any service technician. http://electronicshelponline.blogspot.com/
Jul 23, 2015 | Vizio Televison & Video
Element tv no picture just sound already replaced inverter board. What else could be wrong
Check voltage supplied to the back-light inverter board; from the main power regulator board. If there is no voltage; check for the reason. If there is voltage; and still the back-light does not turn on; two possibilities are there.
1. Damaged back-light lamp/s.
2. Start up voltage to back light inverter board does not comes from the main board. If this is the case, main board is faulty. Contact any service technician; if so.
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 17, 2015 | Element Electronics Televison & Video
Frozen screen
Sounds like main board is faulty. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
For some reason, if the firmware has been corrupted, this kind of fault can occur. If so it will be best to contact any service technician.
Apr 15, 2014 | Olevia LT32HVM 32 in. LCD Television
Goes to standby mode
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 12, 2017 | Televison & Video
FUNCTIONAL PROBLEM, SC544
A fusing temperature of over 250 °C is detected 5 times by the main control
board (this takes 5 seconds)
- Possible Causes -
· AC drive board defective (check the triac)
· Fusing thermistor defective
· Main control board defective
For safety reasons, Level A service calls cannot be cleared by
turning the main switch off/on. The following procedure must be
performed to clear these service call conditions after servicing
the machine.
1. Turn on the main switch.
2. Enter SP5-810 (SC code reset) and press the Enter key.
3. Exit SP mode and turn the main switch off and on.
Jun 10, 2011 | Ricoh FT5832 Copier
Can't on and off tv
Hello Carl, check first for:
  1. AC mains voltage.
  2. Open Main line.
  3. Open TV cord.
Then we go to the TV itself,
  1. check for power switch does they feel spongy, sluggish or not operating properly.
  2. If you use a remote, check for batteries.
This is now TV power supply problem. need to open the back panel. Caution this should be done by a tech person.
  1. check the ac line from mains to power supply board.
  2. check for open fuse.
  3. check for output voltage on the main board.
If you see bulging capacitors, check for power regulator. This part of the service requires a technical person. as this point the logical next thing to do if the trouble was not found, replace the entire power board. Replacing the power board is costly. Hope you decide what is reasonable. Replace board plus labor and effort, and a possibility that the TV may not work due to poor analysis. OR call your dealer for service.
Feb 15, 2011 | Televison & Video
My Viewsonic N3735W power will not come on.
  2. Open Main line.
  3. Open TV cord.
Feb 15, 2011 | ViewSonic N3735W 37 in. LCD TV
Unit will not turn on
  2. Open Main line.
  3. Open TV cord.
Sep 13, 2010 | Sylvania Televison & Video
I have gestetner 2722ztd copier when i replace the explosure lap the copier dispalys error code e1 on the screen .how i clean/remove the error massege ? please help me
Please check after replace the continuity the expo lamp,expo thermofuse.The E codes are displayed in the copy counter.To display both digits of the E codes press the enter key.
E 11 - Exposure lamp error.Possible cause: expo lamp open,expo thermofuse open,power supply defective,main board defective.
E 12 - Exposure lamp error.Posible cause:AC drive board defective,main board defective.
E 13 =Zero cross signal error.Possible cause:main board,power supply defective,zero cross line open or the conector on the main board is not conected correctly.
For reset turn ON/OFF the main switch unplugged wait 10sec and turn ON or:turn ON the main switch,turn DIP switch 101-1 ON/OFF and turn the main switch OFF/ON.The DIP switch is located in the rear parts into the main board.
Sep 20, 2009 | Gestetner Office Equipment & Supplies
MSI MS-N014-ID1 Netbook PC - 9S7-N01441-262 Logo
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
