Question about Poulan Pro 25CC 2Cycle Gas Blower
Damn blower will not start after two times used.also floor s when pulling of rope very many times
  • 547 Answers
You need to adjust the carb ..
Posted on Oct 17, 2013
5 Suggested Answers
rwvanlue
  • 486 Answers
SOURCE: Hi, I have a Poulan gas blower, the rope will not pull out
remove spark plug for inspection
1) silver or aluminum color
STOP the piston is seezed. TOO costly to repair
2) plug dark brown or black (pretty much normal)
remove recoil housing for tangled rope or broken rope rotor
Posted on Nov 08, 2009
Testimonial: "Thank you very much for your help, I did just what you said. The spark plug is brown, so that's good news!"
SOURCE: Weedeater gas blower FLI500E. The pull cord has become jammed
You have to find a way to push the starter. It normally gets all stuck due to grease. One push with a screwdriver on the actual starter (The thing the rope turns) should wind the whole cord up. If not, clean it. Alot of oil/chunky-ness gets trapt when your using it.
Posted on Jul 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: pull rope came out of poulan pro blower
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
  • 1267 Answers
SOURCE: starting rope has pulled away
For a reasonable handy mechanic it is an easy job. What you have to do is expose the winder/clutch assembly and re-knot the end of the rope through the spindle and preload some spring pressure on the rope winder/clutch. You have to judge how much pretension to put on the winder so as to keep the rope wound and not too much that the rope snaps back uncontrollable.
Posted on Dec 30, 2010
Replace the starter rope
you have to remove the recoil from the engine. you will see where the previous rope was tied off. remove old rope and turn spring assembly until tight then back off 1 complete turn. after tying your rope, put through the passages until it comes out the housing hole pull rope all the way through and tug on it to make sure that your knot stays. holding the rope let it recoil in slowly. pull on rope a few times to make sure action is smooth. install handle and adjust rope to proper length
Apr 08, 2014 | Toro Power Clear 221QE Electric Start 21...
How to rewind pull start rope ryobi gas blower ry09550
you need to pull it all the way out at the roller/wheel, get screw driver or some thing that can jam it not to let it roll back, and tight the rope to it and make sure not to slip the rope, and hold the roller/ wheel until you done with the rope, and release the roller/ wheel gentle slowly, let it wind in the rope.
Jul 24, 2013 | Ryobi Gas Blowers Models Ry09550
Need to relace starter rope
Remove the cover from the side of the blower that contains the pull start. This usually involves removing the self-tapping screws that join the two halves of the blower housing together.
  • 2
  • Remove the broken rope from the starter pulley. Usually the rope is attached to the pulley with a simple overhand knot; just grab the knot and pull the rope back through the hole in the pulley. Sometimes the rope is attached to the pulley with a staple or some other fastener, which you'll have to remove first.
  • 3 Remove the handle from the replacement rope, if it's already attached.
  • 4 Thread the end of the rope opposite the handle through the hole in the starter pulley, working from the inside of the pulley (the side facing in toward the engine).
  • 5 Fasten the rope to the pulley. If it attaches with a knot, simply tie an overhand knot, pull it tight and trim off any excess rope sticking out of the knot. If it attaches with a fastener, replace the fastener.
  • 6 Wrap the rope counterclockwise around the pulley until the pulley is full; this usually involves one or two wraps.
  • 7 Thread the free end of the rope through the hole in the blower housing.
  • 8 Replace the blower housing and screw it in place.
  • 9 Trim off excess rope, leaving about 6 inches of rope protruding from the blower housing.
  • 10 Attach the handle to the starter rope. This typically involves threading the rope through one or two holes in the handle and securing with an overhand knot.
  • Read more: How Do I Replace a Pull String on a Hand Held Blower? ' eHow.com http://www.ehow.com/how_6920861_do-string-hand-held-blower_.html#ixzz1DKqEmA1w
    Feb 07, 2011 | Homelite Garden
    Weedeater gas blower FLI500E. The pull cord has become jammed. How can I un-jam the rope pull? I have removed the bottom of the blower and can get the rope pulled out, but it will not retract properly or...
    Apr 27, 2010 | Poulan Weed Eater Electric Blower/Vacuum...
    Stihl backpack blower starter rope is pulling harder and harder. When it dose pull it starts right up.
    See if your rope pulley is opening up and allowing rope to double over on itself.When this happens the rope will wedge in pulley causing it to pull hard.
    Nov 15, 2009 | Garden
    The best way to start cold husqv leaf blower 145
    Most of the small outdoor power equipment that I have used takes the following to start:
    1. Prime 6-8 times, or whatever the manual calls for.
    2. Choke the carb to full choke.
    3. Pull starter rope. It may sputter and die.
    4. After it sputters and dies, put the choke on 1/2. Pull a time or 2 more and should start. Run like that 10 seconds or so, then take choke all the way off.
    Oct 30, 2009 | Husqvarna Backpack Blower 155 145 Starter...
    Poulan Pro Blower starter string
    This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
    First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
    1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
    2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
    3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
    4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
    5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
    6. Put the blower housing back on and your ready to start the engine & mow.
    Pls rate the answer
    Kurt
    Mar 26, 2009 | Garden
    Pull rope broke
    Kurt
    Mar 15, 2009 | Garden
    Poulan Pro 25CC 2Cycle Gas Blower Logo
    62 people viewed this question
    Top Poulan Garden Experts
    Roland W VanLue
    Roland W VanLue
    Phil Walker
    Phil Walker
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
