Question about Monitor Audio Bronze B4 Speaker
Tweeters dead ... are they repairable ? - Monitor Audio Bronze B4 Speaker
  • 1,013 Answers
The tweeters themselves aren't "repairable" but they are replaceable. You can get parts from your local Monitor Audio authorized service center. Dealers Monitor Audio
Posted on Jun 27, 2014
Have 2 jbl 615 get good base and sub but neither tweeter playing
You will need to determine if it's the amplifiers or the tweeter themselves that are not working. If you open up the cabinets and check each tweeter with an ohm meter for continuity it will show if the tweeters are working, in which case the amp is the problem. if the meter shows that the tweeters are blown, you should still hook up another tweeter or speaker to the horn amp to see if it's blown and therefor took out the tweeters.
If any of this sounds complicated, you'd be best off taking the cabinets to the repair shop.
Mar 16, 2015 | JBL Audio Players & Recorders
Where can I source a replacement tweeter for cerwin vega e-712
the exact replacement tweeter can be purchased from midwest speaker company
google it
Sep 27, 2012 | Cerwin Vega E-712 Main / Stereo Speaker
If all speakers except some of the super tweeters in my gem sound tr-150 cabinet aren't working, could it be the crossover network that they appear to be all wired to, is no good, or do you think all...
Did you actually mean "all speakers... AREN'T working" except some tweeters? Crossovers don't protect the woofers. If crossover die all speakers they protect go silent due to loss of signal. Excess volume or distortion kills speakers and not always linearly.
If you said it wrong and some tweeters work, I'd suspect the latter above...
You (or we) could guess or you could take out one tweeter at a time and swap it with a (presumed) working one or just emasure it for dead short or open with an ohmmeter. If the tweeters check out and work elsewhere the problem would likely be within the cabinet.
Sep 08, 2011 | Gem Sound TR-150 Speaker
I have wharfdale atlantic 400se. The tweeter is no longer working. How do i work out if it is a cross over or the tweeter
If there was a traumatic high-volume event that preceded this problem, I'd guess the tweeter died.
If you can access the connections on the tweeter and you have an ohmmeter, you could disconnect the tweeter and measure across the the terminals. A shorted or open voice coil = dead tweeter. A measurement near the stated impedance is probably ok.
If you have NO ohmmeter, you could carefully connect the output of one amplifier channel directly to the tweeter and just scooch the volume upward slightly from silence while playing something with very little bass in it. If you hear it, the tweeter is alive.
Apr 18, 2011 | Wharfedale Atlantic 100 Rear Speaker
Polk rti6 tweers blown...4 speakers.....can these tweeters be repaired
It may be possible to have the tweeters repaired by Polk however if you have the skills your least expensive route would be to replace the tweeters and install them your self. I would recommend using the internet to find replacement tweeters either through Polk or possibly Ebay, or Amazon. Each tweeter has 2 wires that must be removed before uninstalling. Note the polarity and where they connect. red is + POSITIVE , BLACK IS - NEGATIVE
Apr 15, 2011 | Polk Audio RTi6 Main / Stereo Speaker
No sound from one tweeter
Could be an open capacitor in the cross-over, unconnected wire to the tweeter (not likely) or a blown (open) voicecoil in the tweeter. Remove the tweeter and with a 9 volt battery (even run down but not dead will work) quickly touch it to the connections to the tweeter - it should pop and crackle. No static, the tweeter has sung it's last song.
Apr 08, 2011 | Acoustic Research AR 318PS Speaker
Mackie srm 350 tweeter is dead cannot find any UK parts servicesa that will provide either a new diaphragm/coil ot even the whole tweeter
I found that Stan at Surrey amps was able to supply a tweeter for a srm 350. But you need to let him have the full part number on the tweeter as it seems they have changed the design on the tweeter at one point ( or more ) in the manufacture.
phone (0)208 8730927
www.surreyamps.co.uk
regards Peter
Mar 16, 2010 | Bob Mackie SRM350 Main / Stereo Speaker
Quite new speakers 9.1 but the sound is very dull - sounds like tweeters are not working can these be repaired
You didn't answer if they ever worked right.
One doesn't usually judge tweeter function visually. They don't actually move much.
Take a cylindrical tube (like from a paper towel) and place it over the tweeter to isolate it from the room sound and the woofer, then place your ear at the other end. Anything? Nothing?
What sort of signal are you feeding them? Let's look (or listen) to the source and how its audio gets to the speakers. Define the electronics, pathing and setup.
Maybe some history. Have you ever tried to blow them up in your enthusiasm for the new rig? If the tweeters are dead, that may have happened. Microphone use and feedback = dead tweeters.
Feb 20, 2010 | Wharfedale Diamond 7.1 Main / Stereo...
TweeTer Not working.
The only way I can think of to check is to disconnect the leads to the tweeter, then check resistance with an Ohm-meter...no reading means dead speaker.
Dec 28, 2007 | Car Audio & Video
Tweeters only works when touched!
This is not a solution, but I have the same problem. Obviously, the problem is with the tweeter not the crossover. I can't find a replacement tweeter so i am about to take it to my local stereo repair store and see if they can fix it. If you find a replacement tweeter, let me know.
Oct 13, 2007 | Audio Players & Recorders
Monitor Audio Bronze B4 Speaker Logo
104 people viewed this question
Top Monitor Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Monitor Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
