Hdd is saying no more recording space but we have 430 left
4 Suggested Answers
GSAN
  • 106 Answers
SOURCE: AFTER 6 HRS RECORDING MESSAGE DISPLAYS NO MORE SPACE LEFT
It is true that the manual says it can record 100 or more hours...but that is at the lowest resolution. You can go to the menu screen and from there go to the recording properties and play around with different recording resolutions that best fit your recording needs. Also, the DVR uses a Hard Drive just as any computer does and within' time it becomes fragmented... that may cause it to record less hours even if you delete recordings. You can format the internal hard drive by going to the main menu screen and press and hold (for about 10 seconds) the OPEN and PLAY buttons on the unit (not the remote). At this time you should see the words FORMAT on the LCD screen and the unit will shut off. Keep in mind that formatting will erase everything on the hard drive so make sure you back up to DVD whatever you want to keep. Hope this helps.
Posted on Jun 25, 2008
SOURCE: My LG LRH-880 HDD/DVD recorder
Somehow, my HDD/DVD recorder recorded correctly 2 times last night, even if I did not do anything specific to fix. I will keep an eye on new occurences of this problem, but it appears at the moment that the issue disappeared by itself.
Posted on Sep 14, 2008
SOURCE: my MR16 says HDD full-
I had the same problem. After some reasarch I found out that even if you erase a song the data is still on the recorder in "hidden files".
What you have to do is download the WAV manager software from Fostex.com, then copy all your files to your PC, reformat the hardrive on the Fostex, and copy the song files back on to the Fostex form your PC.
I know it's a pain in the ****, but I guess that's one reason this thing was so inexpensive.
I still am very happy with mine, but after 3 years of constant use in my case, some type of maintenence can be expected to happen.
Posted on Apr 12, 2011
Problems recording on LG RHT49H HDD
There may be plenty of space in the HDD but you can only set a certain number of timers. Delete a less important timer setting to make room.
May 05, 2014 | Televison & Video
Toshiba dr 430
hard disc may be corrupt, format the hdd to completely erase it this may fix it
Mar 29, 2014 | Toshiba DR-430 DVD Recorder
My rh397d comes up with the msg 'lack of space' when setting timer recording; disc has loads of space. Have been advised to reformat hdd and to save contents by copying to pc. How do I connect to pc? ...
If the manual doesn't mention copying to pc, then you probably can't.
What mode are you recording? If you select high definition then it will require a much larger space than a lower definition recording.
Mar 11, 2011 | Televison & Video
My MR16 says HDD full- so I erased 12 songs and 10 wav files to free up space. No matter how much i erase it still says HDD full when i attempt to record. do i have to initialize and lose everything to...
Jan 01, 2011 | Fostex MR16HD/CD Digital Recorder
DVD Record wont finalize - LG RH397D
Have you changed brand of disks? Sometime different brands give different results.
Aug 08, 2009 | LG DR787T DVD Recorder
After I reformat my LG HDD video recorder to give me more space, it only clears a tiny portion. How do I clear the whole recorder? I am going to HDD format, and reformatting. Thanks
Do you mean it always shows 10Gb less space than the capacity of the drive. ie only shows 150Gb but you have a 160Gb drive? The reason for this is that it has 10Gb reserved for the buffer of the pause/rewind live TV.
Cheers,
Keith
May 22, 2009 | LG 42LC2D 42 in. LCD HDTV
Polaroid dra-01601a hdd to dvd recording
You will have to split the title and record on more than one DVD. The default speed is SP, that is 2 hours of recording. If you want to record longer programs, go into setup and change the default record speed to one of the other settings, for example: SP+ which is 2 1/2 hours or one of the other longer record settings. This DVD burner will only record at the same speed as you recorded to the hard drive. You can also edit out the commercials by using segment. Go to the title you want, press the right arrow, scroll down and select segment. When you want to start your edit, press enter. when you want to stop the edit, press enter again. You can use your right arrow to skip forward 30 seconds and your left arrow to skip back 10 seconds if you went too far when editing. You will see where your edits are on the screen by the darker color. Do this through the whole program. When you record to DVD, the commercials will not be recorded. Hope this helps you.
May 01, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Harddrive space problem.
When the HDD was fornatted, was it formatted appropriately? It's quite possible to format a 160GB HDD to present a smaller amount of space.
Mar 08, 2009 | Trekstor (21202) 160 GB USB 2.0 Hard Drive
My LG LRH-880 HDD/DVD recorder sometimes stops recording by itself, before the end of the programming and even if there is enough disk space left.
Sep 13, 2008 | LG Televison & Video
Copy recorded pgms off DVD HDD to DVD+RW
the manual specifies that if you select for recording the FR mode the machine automatically adjusts the recording mode for the program to fit on a 4.7G dvd. If you use a dvd DL if will auto detect that you have this type of dvd and the FR mode will automatically allow you to make full use of the available space. Depending on the space needed on the dvd the picture quality will be good to excellent (refer in the manual to Recording Modes..)
Aug 30, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
