Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
I have a Dream Maker Trident 2007 - when two people are in the tub a significant amount of water comes up the back of the chairs and splashes out - Is it possible that a shorter filter will solve the problem or is there another solution? - the filter I have is 4x8 - can a shorter one be used? Would a shorter filter provide enough air and yet leave the right amount of water in the tub - without sucking air after the tub has been vacated? We are loosing 6"-8" of water each time it is in use
5 Suggested Answers
protek480
  • 1714 Answers
SOURCE: my dream maker hot tub keeps needing to be reset
Your heating element is going to ground and 'leaking' current. The GFCI is picking it up and you will need a new element.
Posted on Aug 19, 2009
adamh294
  • 310 Answers
SOURCE: motor will not come on.
OH stands for Over Heat situation.
If the motor is not working at all, you are getting the OH code because of that. The OH happens when there is not enough circulation in the hot tub which causes the water near the heater to overheat the sensor located in that area. It sounds like either the pump has failed, the wiring has shorted to the motor, or the control board is not telling the pump to come on.
Its probably a bad motor since the heater is obviously activating, which it wouldnt if the pumps motor was getting no power. Replace motor and all should be well again.
Posted on Apr 14, 2011
Testimonial: "very helpful. @We did not have the sensor connected properly in the panel board. Now it seems to be working fine. Thanks to you."
Coastsider
  • 331 Answers
SOURCE: I have a dreamaker 8003 xspa that has worked perfectly over the many years that I have had it. The other day I noticed that the water had lowered 6 inches overnight an the water was coming out of the
1. Check equipment like pump, heater, blower, light fixture, for leaks.
2. Remove side panels closest to the are the leak is showing and inspect jets, plumbing in that area for leaks. If insulation is foam, remove any water saturated foam and follow it to the source of leak.
3. If the leak is in plumbing and is very slow, sometimes it can be resolved with "stop leak" products.
Posted on Aug 15, 2012
  • 111 Answers
SOURCE: My dream maker big eze hot tub the jet light on the upper control panel just keeps blinking what does that mean
Are the jets coming on when you press the button?
Try unplug the control from the board and plug it back in.
Posted on Dec 02, 2012
Error code 09
During that 15 seconds, do you see the water moving in the spa?
If not then normally, that means the pump has not primed fully - hence the 09 Error Code. Pump could have a clog internally, but most likely problem, Dirty Filter.
Dec 31, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dec 01, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Aug 07, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
My dream maker spa at temp outside 40 is heating water till only 80 dont know what to do.
This is common when your Heater element is bad.
The friction of the water moving through the pump typically will raise the water to around 80.
Jan 17, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Motor will not come on. flashing OH on tub display dial. Dream maker Model #8003 x 400 series 86L Just purchased used spa and have no manual or directions. thanks
Apr 14, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
I just installed my new X400 Dreamaker Spa. I filled it with water (although cold) and it has been warming up for approx. 18 hours and is only at 80 degrees? Is this normal? How long should it take to...
This is normal with the dream maker spa. The dream maker spas are poorly insulated, and only run 120 volts with a very small heater.
When the unit is first filled, the hot tub will not heat full time either. Most new hot tubs will have freeze protection below 50 degrees F. They will recirculate automatically using the friction and the pumps heat to warm the water above 50 degrees, and then the heating unit will kick on. These hot tubs do not heat while the jets are on high either, so once you are in it using the jets on high, the temperature will start to fall.
Now that you are up to 80 degrees, it should heat up fairly quick however.
Nov 19, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Easy spa round - dream maker - overheat sensor is showing but can't get rid of it even when tub has cooled. Have tried unplugging and starting again. :(
Assuming that you've got adequate water flow, clean/new filter and the pump works as it should; Try a new sensor. They can and do sometimes fail and the sensor is much cheaper than the PCB. ;)
Cheers,
Ian, from: http://hottub.synthasite.com
Jun 03, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
70 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
