Question about Electric 1600 Psi Pressure Washer
Had to replace new pressure switch on a karcher k6.50 pressure washer ,but I forgot which wire goes to which terminals.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
If its two wire it shouldnt matter... if it's multi wire then you are going to need a proper wiring diagram from them
Posted on Oct 20, 2013
Karcher pressure washer doesn't work
it;s normally a switch interrupter must replace with actual with for motor protection.
Aug 14, 2014 | Karcher Garden
I have a karcher K3.97m electric pressure washer. The unit constantly runs and never shutoffs. I after flipping the power switch. What could be worng?
Someone has hard wired the switch to always run because the switch was apparently bad at one time and in order for it to work they just wired it up straight. Remember to rate my solution Thanks in advance
Apr 26, 2012 | Karcher Garden
I have a karcher 620m, power going to switch and coming out of switch but motor wont run, there is a white cylinderical item beside the switch with 2 wires and power isn't getting to it have you any...
The little white thing is most likely a capacitor, and only AC current affects this it blocks DC. These don't often fail, and if but if suspect, then replacement is the only way to tell?
You need to check at the actual terminals on the Motor to see if the power is getting there, it should be present at one side of the motor, the "Hot"side, and the other side or "Cold"side will contact to the Neutral wire, to complete the circuit. It is a very basic circuit.
You also need to check the motor is OK, While motor is disconnected, use a meter set to OHMS, and measure across the the motor's terminals, you should get a lowish Ohmic reading, if it is Open circuit, high Megohms, then either the Motor has "Blown" or the embedded protection fuses inside the motor have, either way the effect is the same the motor must be replaced. This is often what it is.
Below is a exploded diagram manual that may help, it's not all in English, but gives one a good idea.
http://www.pressure-power-washer.com/pdf/karcher/5955-6440.pdf
Jul 06, 2011 | Karcher K2.26 Electric Power Washer
How do you reset a karcher pressure washer
The Knob is broken off of the Plastic Shaft..to the switch assembly.
A new switch assembly is available direct from Karcher.
May 24, 2010 | Karcher K2.26 Electric Power Washer
I left my electric karcher pressure washer it in the shed during the winter and they tell me that the housing and the safety valve need replacing. Can I repair it myself? They want 180.00 to fix it which...
Is there a leak from the bottom ?
If so then there is a crack in the Manifold housing. A New Manifold Complete Replacement is approx. $61.03, can be purchased from Karcher.
If under 1 year old, and you can find a receipt, Karcher will replace the whole Pressure washer under warranty.
Apr 29, 2010 | Karcher PSI Electric Pressure Washer
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Karcher kb 2020
a/c or gas? if a/c you probably have a bad switch. if gasoline you could have no connection to kill wire to coil or the switch is bad.
Jul 07, 2008 | Karcher 2500 PSI Pressure Washer
Electric 1600 Psi  Pressure Washer Logo
151 people viewed this question
Top Electric Garden Experts
Steve Oakes
dannydoesita
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
