Question about Hardware & Accessories
Operating manual for geyser load control timer isg1201
Good day I need a manual to program a ellies ISG1201 geyser timer
Try Googling (ellies)(ISG1201)(manual) without parens.
Jun 12, 2017 | Hardware & Accessories
Where do i connect the geyser load wire to a dhc15a-20a timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#PB1
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#FM1
The other terminals are NO NC and Com
Neutral does not connect to these... only Hot
Hot connects to Com... and then connect wire to geyser to the NO contact... general illustration on link above
Sep 19, 2014 | Hardware & Accessories
Marley md26
A standard 'Geyser' (water heater) timer is quite capable of controlling the two heaters.
Nov 22, 2013 | Heating & Cooling
How to set a Kes load control timer model ISG1201
The Geyser Load Control Timer, ISG1201, is designed to prevent geyser from operating during the Eskom's designated weekly morning and evening peak times. The ISG1201 features 4 easily selectable, pre-programmed, geysers "ON" operating profiles to ensure maximum comfort whilst not burdening the user with the complicated process of having to program the unit.
The profiles are as follows;
  • Program (1) is always "ON"
  • Program (2) "ON" after sunset to accommodate solar geysers
  • Program (3) "OFF" all the time
  • Program (4) savings program - "ON" 6 hours weekdays and 12 hours weekend days
Source: http://www.kgwanyape.com/solutions/isg1201-geyser-load-control-timer/
Oct 31, 2013 | Hardware & Accessories
I have a powerbar with 8 outlets 4 always on 4 controled by a digital timer with 6 buttons, Top row Day, Hour, Min. Bottom row Clk, Mode, Prg. When i set the timers my lights dont shut off or correlate to...
1) Copy following link to identify timer and download manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#striptimer
2) Check that battery is operable,
Move selector switch to ON position.
Check that each program has ON and OFF times set.
Check that each ON time has same days of operation as OFF time.
To delete programs, hold down MODE button and press Prog button.
Check outlet has correct polarity using circuit analyzer.
Try power strip on different outlet.
Check load rating of timer matches type of load being controlled.
This timer might not work for CFL inductive loads, try with ordinary light bulb.
Dec 28, 2012 | Globe Electric Hardware & Accessories
Geyser timer stopped working
Check circuit breaker.
Click fully off and then back on.
Check for burned smell at breaker or loose crackling sound that says breaker is bad.
Reset timer. Then Reprogram.
Possible geyser timer manual
http://waterheatertimer.org/pdf/Digital-Geyser-Timer 24H-7-Day-Timer-230V Brochure.pdf
This timer has a non-replaceable internal rechargeable battery.
If battery has gone bad, then timer is defunct.
Use manual override button to turn timer ON-OFF.
Then test across terminals 3 and 4 for 240Volts.
Turn timer OFF, and test across terminals 4 and 5 for 240Volts
If no voltage shows then timer does not have output.
If test shows 80% undervoltage, that can cause load not to activate, depending on type of load.
Have electrician check for voltage issues at power company transformer.
Unknown what load timer is connected to.
Max load for this timer at 240 volts is 3680 watts, 16 amps.
Motor load is 230 volt 8 amps.
Check label on load for watt or amp rating.
Volts x amps = watts
Watts divided by volts = amps
Oct 31, 2012 | Hardware & Accessories
Need manual for timer dtsx-240-hc
More information is needed.
Review options below:
1) Add a comment and describe timer in detail for best possible answer.
2) DTSX timer appears to be older-style GE/Grasslin or Intermatic/Grasslin/Frost King defrost timer with selectable voltage and F 3 1 2 4 N X wiring terminals.
Open following links to identify timer and download possible manual
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#defrost
http://waterheatertimer.org/pdf/DTMV40-instruction-manual.pdf
Additional resources explaining more about defrost timer operation:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#8145
3) Tork makes DTS series timers with 1, 2 and 4-channels:
Each channel can be programmed separately to control different loads with different on-off schedules.
Timer clock is 120Volts, but dry switch terminals can be wired to control any voltage load.
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DTS
Sep 28, 2011 | Hardware & Accessories
How to hook up a tu40 tork 120/or 240 timer
Open following link for TU40 manual and wiring diagrams:
http://waterheatertimer.org/Tork-timers-and-manuals.html
TU40 timer, like most of the new generation Intermatic and GE timers, can be wired with different voltages and wired many different ways and control multiple loads or single-load plus 2-speed operation.
The following is illustration shows basic wiring to control single 240Volt water heater.
http://waterheatertimer.org/images/Tork-TU-wiring-500-2-500.jpg
Jun 21, 2011 | Hardware & Accessories
Hardware & Accessories Logo
751 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
