Question about Stoves 900DFa Dual Fuel (Electric and Gas) Kitchen Range
Oven cuts out after about 15 minutes
Cooker is about 5 years old. Last night the oven behaved normally whilst warming up to 180C but then cut out. The grill wouldn't work and the red indicator light didn't come on. After allowing it to cool, the oven warmed up, the grill came on but I noticed that the cooling fan wasn't working. I'm assuming that some safety device has shut down the oven and grill functions due to the lack of cooling of the controls. Does this sound right and if so what's the cure ?
  • Anonymous Mar 16, 2014
    Fan oven and grill suddenly not turning on
    Problem Solver:
  • 7 Answers
Most common fault is the cooling fan is failing to come on, whreas the fan will be okay ( check windings with ohmn meter ) it will normally have a ceramic 10k resitor in series with the live which goes open circiut
Posted on Jan 07, 2008
SOURCE:
My gas oven won't ignite, takes several tries to ignite it.
All gas appliances have a thermal cut out this will shut the gas off if the flame goes out the down side is when the thermal cut out becomes faulty it can shut the gas of when you are using the cooker the only fix is to replace the thermal cut out
Jan 18, 2015 | Kenmore Ovens
I have a caloric oven, prestige series. Don't know model. it is about 15 years old. last year the oven wouldn't heat and smelled gas. That was repaired. Now, oven ignitor comes on but oven...
The ignitor is bad again,if it (ignitor) comes on but no flame/heat its the ignotor again, what would make the ignotor go bad so fast (usually last 10-15 years) is a problem with the oven burner, so now BOTH the ignitor and burner would need to be replaced,if it is 15 years old the ignitor is readily avaliable but the burner may not be
Gene
Aug 04, 2011 | Ovens
This cooker was fitted by Kitchens Direct last year, so is new. No manual was left by the fitters A power cut, throws the electronics out and the oven stops working. How do I get the light to stop...
Most likely, the digital panel just kind of locked up. The first thing I would try is to turn off the circuit breaker at your home's breaker (or fuse) panel for about 5 minutes and then turn it back on again. This should "reboot" it and hopefully the oven will get its brains back!
I hope this helps! :)
Dec 14, 2010 | Ovens
Oven not warming up
The first thing to check is the oven element, this is located at the rear of the oven compartment behind a removeable cover.
Although it may look o/k, the only way to be certain is to test it with a meter.
Hope this helps.
Jan 30, 2010 | AEG D2100-4 Electric Double Oven
Beko SCG 7521 gas cooker flame won't stay lit in oven.Once you light the flame in the oven & hold in the oven button for the recommended 10 secs it cuts it's self off when you release the oven...
bloody hell that is so scarey i have the same problem and its round about the same time yours went funny if you have a solution can you let me know as im looking for the answer myself [email protected]
Oct 08, 2009 | Ovens
Oven cuts out after ten minutes and comes back after cooling down.
thermal cut out fuse, costs about £30, my company fits them for £78 all in in essex
Nov 19, 2007 | AEG B3101-4 Electric Single Oven
Problem with main fan oven - electric
there is an overheat stat and this is operating and cutting out the oven. the causes are several but here are the main things to look for: oven stat is faulty causing the oven to overheat. you should check over the range to see if stat is reasonably accurate. overheat stat itself is faulty. there is another stat which turns on the casing fan. (this is the fan which is out of sight - not the fan inside the oven) if this stat is faulty and not turning on the casing fan, then the overheat stat will operate. the casing fan is faulty or jammed. lack of ventilation. see if you can narrow it down a bit and get back to me if you wish
May 06, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
Nov 21, 2006 | AEG B3101-4 Electric Single Oven
Stoves 900DFa Dual Fuel (Electric and Gas) Kitchen Range Logo
494 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Ismael Rodriguez...
wayne murphy
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
