Question about MSI CR500-479US Notebook
Which screws do I remove to get at the cooling fan
    Scholar:
  • 181 Answers
Better bring your laptop to a service man, even though you open it successfully, you still need a correct replacement for the defective cooling fan.
Good day
Tedmac
Posted on Oct 17, 2013
How to change the cooling fan in a toshiba laptop model p200d-139
Instructions
Shut down your Toshiba laptop, and then disconnect all cables. Close the LCD lid, and then place the laptop face down on a flat surface. Position the laptop with front edge facing you.
Locate the battery pack near the top section of the laptop's bottom casing. Press on the battery release button. Remove the battery from the laptop.
Locate the cooling fan compartment cover. Its location varies from laptop to laptop, but it will be the only hardware cover with a vent in it. Remove the Phillips-head screws securing the fan's cover in place. Remove the cover from the laptop.
Disconnect the fan's cable from its connector on the motherboard. Remove the Phillips-head screws securing the fan in place. Lift the old fan out of the fan compartment and set it aside. Removing the old fan will reveal the processor chip. Apply a thin coat of thermal grease to the processor's surface using a clean paper towel. This will prevent your new processor from frying once you power on your laptop.
Place the new cooling fan assembly inside the fan compartment. Align the screw holes on the new fan with the screw holes inside the compartment. Replace the four retaining Phillips-head screws, and then reconnect the fan's power cable to the motherboard. Replace the fan compartment's plastic cover, and its retaining Phillips-head screws.
Replace the battery pack and reconnect all power cables and external devices. Turn on your laptop to test the new cooling fan
Jul 28, 2012 | Toshiba Computers & Internet
2005 Jeep Liberty overheats at idle but while in movement temp returns to normal.
Check to see if the fan on the radiator is working at idle.
Here's information on how to change the fan if needed:
Engine Cooling Fan Removal & Installation 2.4L Engine To Remove:
  1. Remove the coolant bottle and set aside.
  2. Remove the power steering reservoir and set aside.
  3. Disconnect the cooling fan connector.
  4. Remove the cooling fan mounting screws and the cooling fan.
To Install:
  1. Install the cooling fan and the mounting screws. Tighten to 50 in-lb (5.5 Nm).
  2. Connect the cooling fan connector.
  3. Install the power steering reservoir.
  4. Install the coolant bottle.
3.7L Engine To Remove:
NOTE: If the fan blade is bent, warped, cracked or damaged in any way, it must be replaced ONLY with a replacement fan blade. DO NOT attempt to repair a damaged fan blade.
NOTE: For 3.7L Heavy Duty/Max Cool/Trailer Tow cooling package, the viscous fan cannot be removed separate from the shroud. Both fan and shroud must be removed together.
  1. Disconnect battery negative cable.
  2. Using special tool #6958 spanner wrench and #8346 adapters, remove the viscous fan from the water pump.
  3. Gently lay fan into shroud.
  4. Disconnect the electrical connector for the electric fan, then disconnect connector from shroud.
  5. Remove the two fan shroud mounting bolts connecting the fan shroud to the radiator.
  6. Remove the shroud and fan from the vehicle.
To Install:
  1. Install fan shroud assembly into the vehicle. Tighten fan shroud to radiator bolts to 50 in-lb (5.5 Nm).
  2. Install shroud mounting bolts tighten bolts to 89 in-lb (10 Nm).
  3. Connect fan motor wire connector to harness connector, and attach connector to shroud.
  4. Connect negative battery cable.
  5. Start engine and check fan operation.
Aug 31, 2010 | 2005 Jeep Liberty
Fridge wont cool
Dismantle the light unit and remove same. Front cover 2 screws and difuser. Mark difuser for right way up. Remove screw covers to lower unit and remove four screws. Ease away unit breaking ice seal and unclip connections. Remove same. Defros with hair dryer or similar and then do the same with the removed unit. Clear away insulation from fan drain and defrost to dry condition. Replace as removed. The problem is it has to be repeated at intervals when the fan shows signs of founing. You will know by the noise. Paul.
Jul 11, 2010 | Amana ASD 2624 Side by Side Refrigerator
Cooling fan not working on median md 96640. How do I take the back off to clean/replace cooling fan?
you will have to remove all screws on the back then flip it over and remove key board then there will be more screws to remove LCD and palm rest. then remove screws from mother board and then you will be able to get to the fan.
Jan 06, 2010 | Computers & Internet
Cooling fans dead. how to open keyboard.
http://support.dell.com/support/edocs/systems/latc640/sm_en/fan.htm#1000113
    1. Remove the hard drive.
    2. Remove the keyboard.
    3. Remove the display assembly.
    4. Remove the palm rest.
    5. Remove the microprocessor thermal cooling assembly.
    6. Remove the two M2.5 x 5-mm screws and one M2 x 3-mm screw that secure the hybrid cooling fan to the system board.
Oct 10, 2009 | Dell Latitude C640 Notebook
How do I get the fan out of my toshiba a300?
You will have to remove ALL cover screws, remove battery pack and screws, remove all covers, Once you can pull apart unit, you will have 4 screws holding on the fan.
Aug 18, 2009 | Toshiba (K000000460) Heatsink With Fan
My amana bottom freezer won't cool both the fridge and freezer are warm
I just had the same problem with the same fridge. When I removed the inside panel in the freezer, I found that the cooling/circulation fan had fallen due to the mounting screws having rusted off. I removed the fan housing to get the screw ends out from the back side and remounted the fan with new screws. The fridge and freezer both work fine now and I'm assuming it will for many more years until it happens again.
Nov 04, 2008 | Amana ABB1927DE Bottom Freezer...
Removal of cooling fan
You need to disable your laptop.
follow this step:
Remove harddrive.
1. on the back of laptop, there are 2 doors. open it all. 1 of them is harddrive.
2. remove harddrive.
Remove wireless cable.
1. open 2nd door on the back, you can see rams and wireless card. unplug wireless cable from wireless card.
Remove chassis
1. Remove 2 screws on the hinge cover, so you can remove the power cover (power cover is cover that have power button).
2. after you removed power cover, removed keyboard.
3. remove 4 screws that hold lcd from chasiss. you can remove lcd now.
4. remove 3 screws under keyboard.
5. remove all screw on the back of your laptop.
6. remove upperchassis.
7. remove 2 screw that hold motherboard from lowerchasis.
8. take motherboard out from lowerchasiss.
9. now you can see the thermal fan.
Jun 19, 2008 | Acer Aspire 5050-3242 Notebook
How do I remove it?
fan is usually hold in by screw and 2 power wires (red/black). Also look for clips.
Apr 07, 2008 | Sanyo Denki Case Cooling Fan
SAMSUNG RS21DCNS
speaking from memory: remove the middle translucent section held by one screw at top and clips. you will then see the additional screws you need to undo
May 07, 2007 | Samsung RS2630SH Side by Side Refrigerator
MSI CR500-479US Notebook Logo
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
