Question about Dell Latitude D800 Notebook
I have a dell d800 laptop and a glass of water droped into laptop and now is not charging plzz tell me the solution
    Sergeant:
  • 330 Answers
FIRST THING, REMOVE BATTERY. IT WILL SLOW DOWN THE DAMAGING PROCESS. Like any electronic components exposed to moisture or liquid, corrosion sets in real fast on the circuit board. If you have the tool and the knowledge to take the laptop apart, remove the case and see the extent of the damage. Easy to recognize by the greenish/white deposit on the circuit board. If it's only near the charging port, you could be lucky and get away without any damages but just cleaning the corrosion away. Hope this helps!!!
Posted on Oct 13, 2013
mewms_14904
  • 1027 Answers
SOURCE: dell latitude d800 laptop
The problem may be the modem has to assign an IP address to your laptop, what you may have to do is plug the laptop into the modem and see if the laptop recognizes the modem with no errors in device manager,
Next turn off the laptop and modem, reboot the laptop then modem for the modem to assign an IP address.
Posted on Mar 19, 2008
  • 120 Answers
SOURCE: d800 will not even boot
Okay, I had that problem with my HP less than a minute ago.
Maybe it is the same problem. See if the battery light comes on. Press the power button again and again if it doesn't start, for some time. It may show the boot screen and hang. Now, the battery must be charged. Shut it down directly and switch the AC off.
Now, switch it on and see if the battery light comes on. If it does, it is the same problem as mine. Now, turn the PC over and remove the battery carefully. There may be switches for that.
Now, plug in the AC and start it without the battery in. If it does, you're done. Now, plug in the battery again.
Posted on Nov 28, 2008
  • 2567 Answers
SOURCE: dell laptop connected to 1209s projector...dell page indicates searching for signal and can't
Using the Display When you start the computer with an external device (such as an external monitor or projector) attached and turned on, the image may appear on either the display or the external device.
Press <Fn><F8> to switch the video image to the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, external DVI monitor only, and external CRT monitor and external DVI monitor simultaneously.
Posted on May 15, 2009
leecom72
  • 4806 Answers
SOURCE: Dell Latitude D800 Wont Power Up
Take out the battery and try booting the machine on AC power only. If the machine boots up then let the operating system load up, the shut it down. Remove the AC jack and put the battery back in again, then power it up.
If it boots all is well if it doesn't then there could be a problem with the battery.
Please let me know how you get on and good luck.
Posted on Nov 12, 2009
angelo_mlc
  • 1035 Answers
SOURCE: dell latitude d800 laptop i have forgetton the
You can reset the windows password by using 3rd party tool.
you can visit this site (there are options for the tools and intructions how to do it)
http://pcsupport.about.com/od/toolsofthetrade/tp/passrecovery.htm
Posted on Mar 28, 2010
Cant connect my dell latitude d800 to internet. the wireless says that it is connected, but when i pull up my internet browser, it tells me i am not connected. wtf?
Make sure the router is getting online. You might have to cycle the power (unplug for 30 seconds and plug it back in) on the router.
Jan 23, 2012 | Dell Latitude D800 Notebook
I Have a Dell Latitude D800 and it's plugged into power. when i hit the start button it lights up a couple of lights on the keyboard, they go out after a couple of seconds and then nothing happens?
Is the battery charging? and is the power adaptor properly plugged in? If yes then it's probably a faulty PSU and you will need to phone DELL for a replacement/repair.
Sep 06, 2010 | Dell Latitude D800 Notebook
Hi! my dell d800 wont turn on. I have take then battery out and such and then put it back in but it still wont work. I have put the charger into the computer and the computer says its not charging the...
the battery is damaged..replace the battery with a new one or you will have to run your laptop straight from a eletric power source with the battery removed.
May 02, 2010 | Dell Latitude D800 Notebook
Dell latitude d800 laptop i have forgetton the
Mar 28, 2010 | Dell Latitude D800 Notebook
Check the status of the battery directly from the battery. Turn the laptop over and on the batter is an battery indicator button and lights to tell you if it's charged. If it is charged then you have an problem internally. Wiggle the tip of the power cord at the laptop connection to see if it is loose, if it is then you have an loose connection on the motherboard which can be fixed by an experienced tech that can solder or the motherboard will need to be replaced.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Dell Latitude D800 Notebook
How do i keep my battery from going low so fast on my dell laptop
that's a common reason when you use your baterry for a long time. You might need to buy a new battery.
Mar 20, 2009 | Dell Latitude D800 Notebook
Dell D800 probles with windows media player
sounds like a memory allocation issue..check that first
May 04, 2008 | Dell Latitude D800 Notebook
Dell Latitude D800 Notebook Logo
23 people viewed this question
Alun Cox
