Question about GE Cooktops
Neff T1213 element replacement - GE Cooktops
Suitable replacement for a Neff T184 induction hob
then you need to go shopping at an appliance store
Sep 29, 2016 | Neff Cooktops
Hob ceran replace with new induction hob
Need looking at by NEFF , a big job .
Mar 16, 2015 | Neff Cooktops
I have intermittent problem with two of the four rings - sometimes they work sometimes they don't
see this causes and proceed for fix it. God bless you
Surface Element Switch If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Surface Element Board If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Terminal Block If a surface element won't work, there may be a problem at the terminal block. The appliance has a power cord which is attached to a terminal block. Over time, the connections at the terminal block can fail and burn open. When this happens, normally all of the surface elements won't work. The solution is to replace any burned wires and replace the terminal block.
Loose or Burnt Wire Connection If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Oct 02, 2012 | Neff Cooktops
Induction hob neff T4243 has cracked will I need to replace it
Did you crack your hob by means of impact or did it happen on its own accord?
I have a neff induction hob and has just cracked in 3 directions while cooking this evening. I am just trying to determine if there is a common fault with this neff product or I am just unfortunate. Mine is under warranty and have a engineer coming on Monday, so have the whole weekend with no hob as I have been advised not to use it.
Many thanks
Feb 28, 2012 | Cooktops
Glass on neff t4243 induction hob has cracked
hi,
is it possible to replace a cracked glass on my Neff induction hob?
where would I get the glass for my Neff induction hob replaced?
is it very costly?
the model number is t4483x2/09
My neff helectric hob two of the plates are not working
Sounds like the heating elements burnt out.
Dec 12, 2011 | Cooktops
Press power on switch and blows main fuse box
Possible that the main heating element is faulty. It is possible that the wires have shorted or due to insects if there was failure of the insulation of the wires leading to shorting of the lead lines.
Disconnect the main lines and use a multimeter to check and confirm the short of the heating element or wires.
Take all precaution for safety in testing live circuit.
Aug 18, 2011 | Neff T1323 Electric Cooktop
Neff instructions
Visit http://www.bshcustomerservice.com/
And enter your model number to download a PDF instrustion manual.
Jun 16, 2009 | Neff T1323 Electric Cooktop
Wiring for Neff Hob-not supplied/no wiring instructions
The details of how to wire the T1213 hob are printed on the base of the hob next to the terminal compartment. For a single cable installation, Neutral is connected to terminals 4 & 5 which should already be linked with a copper link. Terminals 1,2 & 3 should be linked together using the links supplied (hidden in the side of the terminal compartment) and Live is connected to any one of 1,2 or 3. The Earth goes to the terminal beside the cable clamp.
Nov 28, 2008 | Neff T1323 Electric Cooktop
Child safety lock on neff cookertop
Just hold down the on button for about 10seconds
Sep 23, 2008 | Neff 23 in. T4343 Electric Cooktop
Cooktops Logo
26 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
