Question about HP Pavilion dv6000t Notebook
Hp dv600 will not turn on. It doesn't matter if the battery is in or if the adaptor is in, it will not turn on. I have no idea what to do or if there is anything i can do.
  • 696 Answers
First thing to try, unplug the unit and remove the battery
Then hold the power button for at least 30 seconds, this will drain any power left on the motherboard.
plug the power line back in and attempt a restart. If it works you may get an error message warning you that your hibernation file is damaged. it is ok to allow the boot to continue but you will loose any unsaved files you had open.
If this doesn't work, unplug it, put the battery back in and then replug the AC adapter. look at the front left edge of the laptop and check for the AC light, looks like a lightning bolt. If it's not lit you may just have a faulty adapter, then can be replaced for about $100, with a targus or kensington universal adapter.
If the light is on and the reset doesn't work, it's likely a hardware failure in the charging circuit or motherbaord which can generally be repaired but depending on the price of the unit isn't always cost effective.
Feel free to post back and let me know if this does or doesn't work for you.
Chris
Armor-IT
Posted on Apr 24, 2009
HP DV6000 If I push the powrer button all of the lights above the F buttons light up nothing else
Posted on Apr 02, 2011
Were can i buy hp dv600 battery for real heap and charger
Posted on May 15, 2010
How do i download wifi driver for hp dv600 laptop
Go to hp.com and under support and drivers enter your model number from the bottum of the computer select the operating system and find the wireless driver
Oct 10, 2012 | HP Computers & Internet
I have a hp6735s i got a new battery and it turned on for all of 2 mins then went of its bin charging for about 10 hrs and blinks half ornage half blue but wont come on at all .. the ac adapter voltage is...
The Genuine Battery for this laptop is:
(HP: HSTNN-IB51, 451086-361)
47WH 10.8 Volts
Adaptor sounds right also, though its not the volts that count ( give or take 0.5 volts each way) but the amps that matter, guess your charger will be a 3.25 or 3.65?Amp if its a genuine charger?
The actual problem could be down to a few things:
1.) Check the adaptor, see that the LED light on the adaptor is not flashing green, it should be steady. if in doubt, try a new adaptor or a borrowed one if possible. An adaptor that looks ok, may also fail under load.
2.) Check the DC jack port and see if the centre pin is loose, if it is, the DC jack will need replaced in the laptop.
3.) with a toothbrush or similar, clean the metal fins in the battery bay that the battery locks into, good contact here is important to the batteries ability to charge.
Jul 24, 2011 | HP Compaq 6735s Notebook
Hello, I'm Bre. I own an HP Mini 1035nr and I have a problem. One day my laptop was running really well and then it abruptly shut off. I had no idea what was going on so I attempted turning it back on....
When you say the screen before, I'm assuming its the splash screen with the hp logo on?
This would point to a missing OS, but you should get a message saying OS not found or similar.
if you are not even getting this message, there is a problem that may be related to hardware.
Try the following:
1.) remove battery and ac adaptor, press the power switch and hold for 30 seconds
2.) replace ac adaptor and try without battery
If the problem is not cured and / or the netbook will not boot up, please repost any error messages you get and I'll help further
Jun 24, 2011 | HP Mini 1035NR Notebook
I got an HP Compaq nc 6230 laptop a few months ago. The battery life has been getting smaller, but whenever it was in the port, it was fine. A few days ago I tried to turn it on and after three or four...
With the laptop connected to AC power using your AC adaptor, use your HP Support Assistant or download HP's battery check software which will check the health of your battery and possibly determine if the problem is with the battery or the AC adapter. The instructions are here. You potentially may have a battery with some bad cells. If so, it sounds like it is new enough that it could be under warranty. I've seen this software indicate whether it is covered under warranty or not.
Oct 28, 2010 | HP Compaq nc6230 Notebook
Hello , actualy i took the battry out while my hp ,dv600 on then when i turn it on again it turns on but my screen is black and the computer lights goes on and of every few seconds , what do you think is...
Removing the battery shouldn't hurt it, unless you were doing a BIOS update or something, at worst, the PC should reboot and you might get a message about Windows not shutting down properly. It sounds like the battery might be dead and is not getting charged. Have you tried it with the AC adaptor? Is the adaptor definitely plugged in correctly?
Jan 27, 2010 | HP Pavilion dv6000 Motherboard
HP DV600 laptop doesn't turn on even on mains.
It sounds like your ac adapter has died, and thus is not charging the battery back up. Test the adapter for power output. If it isn't working, the only option is to purchase another.
Jan 07, 2010 | HP Pavilion dv6000z Notebook
Hp Pavilion Dv600 Wont start up!!!
it looks like your mainboard is cutting the power. and need to get servvice.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Laptop won't turn on, blinking blue light
Jeremy,
It depends what failed on the motherboard. If the charging circuit is failed then you may indeed need a new mobo. The fact that it was working wouldn't be affected by the dead circuit as it only effects th laptops ability to recharge the battery or run from power.
Try talking to hp online tech support as they offer a $500 flat rate repair on many models. They can be access by going to www.hp.com and clicking the "contact us" link the the chat with live technician link.
Chris
Armor-IT
Apr 24, 2009 | HP Pavilion dv6000t Notebook
HP Pavilion dv6000t Notebook Logo
3,720 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
