Question about DIT Freegate
Every time I try to use freegate it says 'Network connection problems' but my network connection is perfectly fine plz plz plz plz help me
Every time I try to use freegate it says "Network connection problems" but my wifi is perfectly fine plz plz plz help
click start->run -> enter "command" without quotes-> ipconfig / flush dns-> ipconfig /renew... if this is not helping try disable and re-enable the WLAN adapters (control panel ->network and ...->click the adapter with right clik and disable/ enable)
Oct 13, 2013 | Computers & Internet
Asus p5g41t-m csm motherboard is having LAN problems
Go to Control Panel and Device Manager. Check Network Adapter for normal. If all appears normal go to Network and Sharing Center to setup a connection. If still unable to make a network connection then download the LAN driver for Windows 7 from ASUS at this link and install it.
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=22&m=P5G41T-M&os=&hashedid=FaRsjolgBLJKq49g Then reboot and try your connection again.
Dec 03, 2011 | ASUS P5G41T-M/CSM Motherboard
Restricted for the facebook site in the college
Hi, welcome to FixYa.
You can overcome this problem by using some proxy website like hidemyass.com
or you can try some proxy program like FreeGate or JonDo.
Mar 11, 2011 | Facebook Social Network
The network set up just fine, and the adapter connects perfectly to the Netgear wireless network. One laptop connects wirelessly via the XAVN2001 extender, but the other laptop (in the same room) cannot...
Try searching for drivers on the second laptop. also, try updating the firmware of all your networking equipment. those things alone might solve your problem.
Feb 28, 2011 | Computers & Internet
Signal problem
Dear customer
I will get vary happy to help u. If u are a Technician then open ur mobile handset by T-6 screw driver and firstly wash ur network antina and IC areas by a toothbrash with PCB cleaner.Check the network connecter make a jumper from network connecter to connecter pins by micro soldering IRON and give some hot air to network IC with pest.If u are not a technician then its better to go ur nearest NOKIA care center.If u are saticfied withmy information then please vote me. Thank you for your visit.
May 24, 2010 | Nokia 6300 Cellular Phone
New wireless adapter will not get IP address
plz i want to dsl wireless connection plz call then now +92332330458
May 03, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
HP Wireless "working" but it won't connect to networks
I had a similar problem with my HP g60-243cl and new drivers solved the problem. I also have to turn off wireless and turn it back on a couple times if I switch networks.
Apr 09, 2009 | HP Pavilion G60-120US NoteBook
Macbook 13.3" won't log in to wireless
You need to check your network card software your problem may lay there. I've seen this problem many times in the passed. I will install a wireless network card or software on someones computer and two days later it will not connect everything looks fine. No matter what I do it will not connect. Remove net software for the card or on board wireless reinstall and boom it works fine.
routers may need reset or configured off the internet or the start up cd. I take this a wireless router hooked to internet gateway. don't know not enough information you may need to tell me a little more. first try install of net-card software then set you working router to unsecure no pass word need see if you connect then change it to you wpa password protected.
Mar 20, 2009 | Apple aluminum 13-inch MacBook laptop-...
Bt fusion home hub
Dear Bern
if ur using windows xp its very easy to solve
1) Just restore your omputer to older days that which work greatly.
Steps
start- program files -- Accessories- system tools- System restore- select the date whih it works greatly. and the give restore. then system will restore after restarting
best of luck
Sep 20, 2008 | Computers & Internet
Computers & Internet Logo
132 people viewed this question
Top DIT Computers & Internet Experts
soras46
john h
 steve
steve
Are you a DIT Computer and Internet Expert? Answer questions, earn points and help others
