Question about Dryers
I have a hoover hnv 375-80 tumble dryer, i have replaced the jocky wheels and belt and forgot to label the wiring on the circuit board !!! any one have a diagram please
SOURCE: Replacing the Drive Belt
I am not an expert but I do have a Hotpoint 9334 Tumble Dryer which I guess is similar to the 9314.
To replace belt or heater element you must remove the front panel complete with door.
Screws are different sizes in different places so note where they belong as you remove them.
1. Remove 2 screws at rear top which go through the brackets holding the top panel, slide back the top panel a little and lift it off.
2. Pull off the rotary timer knob and remove 2 screws beneath.
3. This is the tricky bit! Remove the the plastic panel which covers the switches etc.. This panel has 5 plastic fingers which secure it to the metal plate behind, locate the ends of the fingers where they pass through the metal plate. Using a metal rod or punch and a hammer, tap the ends of the fingers to push them back through the holes easing each in turn a little at a time to avoid distorting the plastic unduly. (This is a bit scary as you have to hit them quite hard and the fingers look fragile)
4. Open the door and remove the 4 screws then remove 3 screws at the top and 3 screws at the bottom of the front panel. Lift and ease forward the front panel, unhook the door catch release wire, pull off the electrical connectors and put the front panel aside.
5. Lay the machine on its back and remove 1 screw holding the element housing to the top plate and pull off the electrical connectors.
6. Fit the belt around the drum, through the idler pulleys and over the motor spindle.
7. Put it all back together.
Posted on Feb 03, 2008
hards327
  • 30 Answers
SOURCE: How do i replace belt on condenser tumble dryer
you need to remove the whole front of the machine by removing the : top by the 3 screws at the back,then unscrew the screws across the front of the top of the bezel then remove,then open the door,remove the circle of screws then put the machine on its back,remove the screws at the bottom front of the machine,then lift the front bottom of the machine and slide it upwards then you should be able replace the belt then refit in reverse order good luck.
Posted on Mar 17, 2008
  • 417 Answers
SOURCE: Zanussi Tumble dryer belt replacement
Yes, that sounds about right.
Posted on Oct 11, 2008
godtech
  • 51 Answers
SOURCE: i need a wiring diagram for a hotpoint tumble dryer model vtd00
CALL 1-800-626-2005 ALSO CHECK THEIR WEB PAGE WWW.HOTPOINT.COM
Posted on Jan 16, 2009
SOURCE: My hoover tumble dryer hnv
I've had exactly the same problem with this model and nearly traded it in as it was getting so noisy. However - it can be fixed! You need some general purpose grease from Halfors etc and some WD-40 and a philps screwdriver. Just follow these steps to get the front panel off the dryer: Instructions to lubricate the pulley wheels on the Hoover HNV380 dryer 1. Disconnect from the mains 2. Unscrew screws at the top of the rear of the dryer which allows the top panel of the dryer to slide backwards out. 3. To take off the front of the dryer, unscrew the screws at the top of the inside front panel, next lay the dryer onto it?s back and open the dryer?s door? there are 4 screws on one side and two on the other ? leave the outer 2 screws on the side that has 4 screws which keep the door on and unscrew 2 inner screws and the two screws on the other side. Then finally there are 3 more screws on the under panel to unscrew. This allows the front panel to be moved enough to see inside the dryer. 4. Check the belt that wraps around the drum is ok and centrally in position. 5. Under the drum the belt wraps around the spindle of the motor and is guided by the 2 pulley wheels. These wheels are probably the main culprit of the noise and can sometimes be reproduced by pulling at the belt through the wheels. Put plenty of grease around the pulleys and keep turning the belt to ensure that the grease gets into every bit of the wheels. 6. Then spray WD-40 around the pulleys for good measure and also into the motor and spindle. Make sure there are no more squeaks when you turn the drum by pulling at the belt trough the pulley wheels. 7. Re-assemble the dryer by going back trough the steps in reverse. 8. Just to be certain once the dryer is re-assembled undo the silver cover on the back of the dryer and spay more WD-40 around the plastic fan and into the motor through the fan. I reckon that this should last for a good 12 months or more before starting to squeek again - so far it's been 2 months and sounds as good as new Good Luck
Posted on Jun 10, 2009
Where can i get a user manual for a hoover hnv 375-80.thanks
Go online to Hoover .com, look up "User manuals", have the machine details off the sticker on the back of the machine ready, search your machine, down load the manual. Easy as that.
Oct 20, 2014 | Dryers
Is70c belt direction diagram
Hi Grant...
I hope this is what your looking for, I do not have your brand here, but maybe the same routing of the belt applies to yours
Bud
Apr 17, 2013 | Indesit IS70C Electric Dryer
Have had two hoover vhv 680c tumble dryers from the coop electrical store. They have worked for two days exactly then when you go to use it again there is no power to the machine (replacement for each...
Purchased one of these tumble dryers on 20th Oct 2011 from Currys, yesterday morning no power whatsoever.
Have refused repair or replacement after seeing your similar problems and also after finding this review that indicates that these tumble dryers dont like the cold.
As many people like us have them in the garage, I'm not interested in one that needs it's own radiator and blanket !!!! grrrr ..
http://www.appliance-reviews.co.uk/p/Hoover-VHV680C-Vented-Tumble-Dryers-in-White-22491/reviews#tabs
Feb 28, 2011 | Dryers
How do i replace the belt on my hoover performa plus
http://www.ehow.com/how_6316606_replace-belt-tumble-dryer.html
Feb 21, 2011 | Hoover Dryers
Hoover tumble dryer vhc392T drum not turning. There is power to the machine but the drum wont turn.
check the belt to see if it is broken. check the drive motor to see if it is working.
Jan 10, 2010 | Hoover HDC6 Electric Dryer
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
The drum on the tumble dryer isnot moving, why is this?
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 18, 2009 | Zanussi TC180W Electric Portable Dryer
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My hoover tumble dryer hnv 380 is making grinding noise when in turns. Seems the drum bearing needs replacing. I am looking for instructions on how to fix this problem.
May 01, 2009 | Dryers
Dryers Logo
49 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
