Question about Grundfos Pumps UPS15-58FC
One of my 3 Grundfos UPS 15-58 FC pumps on my heating system has a slight rattle and is running very hot. The temperature drop across the pump is also much greater than that of the other supply side Grundfos. Is the rattle a bad bearing and is the impeller toasted. It may have run dry earlier this summer when one of the kids turned on a thermostat, while the electric heating tanks were shut off.
    Sergeant:
  • 216 Answers
In most cases the impellers are what fail in these pumps. Generally speaking if a bearing is going out you won't have a heat difference you would have a pump that fails to run due to overheating of the thermal overload or the circuit breaker tripping. You can test the pressure to see if it's the same or close to the others 15% or more requires a replacement of the impeller.
Running these pumps without fluid will also quickly destroy impellers within 10 minutes. They require that fluid to stay cool.
Posted on Oct 20, 2013
3 Suggested Answers
  • 512 Answers
SOURCE: Grundfos MQ pump starts every 15 seconds
Pressure is bleeding back through the pump or system to the tank or well or where ever the water is coming from. Should be some sort of one way valve to keep water from going back to the source, mounted somewhere so that once pressure is pumped up, it will hold that pressure in the part of the system that has the pressure switch that controls the pump.
That or you have a leak where you can't see it. (Actually you do, it is just internal and not leaking outside the pipes!)
Posted on Nov 05, 2012
boysor2933
  • 293 Answers
SOURCE: Low pressure from grundfos pump to house
Does your system equipped with pressure tank (pneumatic tank)? If it has, maybe it's already filled with water due to some pinhole leaks. Drain the tank and see what will happen.
Posted on Nov 06, 2012
My grundfos hot water circulator works great. how often should I set it to circulate the hot water, ever hour, before morning shower or evening shower.
Last one I installed, I used a PIR sensor to control it, so that whenever someone walked towards the bathroom or kitchen, the pump will start up and run for 15 minutes. It really depends how often you use hot water - if only certain times of day, then it would be wasting power to run the pump, and heat loss from the pipes (unless very well insulated). If you have a regular pattern of use, then you could use a timer/programmer as you would on your normal hot water or heating. If your piping is plastic, then don't run pump continuously, as some plastic piping is not recommended for continuous circulation at normal hot water temperatures.
Oct 21, 2017 | Grundfos Hardware & Accessories
Central heating pump stops running
If you can not hold your hand on the motor for a count of 10 when it has cut out, the motor has overheated and needs to be replaced or find some reason for an overload.
Jun 21, 2017 | Grundfos Garden
Grundfos JPF4A pump. takes a long time to get up to prime then once it kicks in after running water it gets to 50 shuts of but drop pressure instantaneously and kicks back in again. The constant on off...
The check valve is bad. When the system builds up pressure and shuts off the check valve prevents water from dropping back down the well line. When the check valve goes bad water drops back down the well line and siphons water back out of the well tank causing the switch to kick on and off constantly. The check valve will between on the well line coming from the drop pipe. It may be making a constant rattling noise as pump is running. Replace the check valve and you should be fine. Also check the pressure in bladder tank it should be 2psi below the "cut-in" pressure for the switch.
RJ
May 22, 2011 | Grundfos Plumbing
Just bought a house and it has a grundfos timer/pump attached at the hot water tank. I have no hot water and the timer doesn't turn (as I've seen other timers do). Is it supposed to turn so that the...
Grundfos is a sealed unit and not a repairable item.
The timer dial should turn.
And pins located around dial control ON-OFF functions as timer dial rotates.
Does the receptacle have power?
If receptacle has power, and Grundfos is not working, then it is broken.
Grundfos manuals for UP series pumps do not show breakdown or parts list of any kind.
http://www.us.grundfos.com/web/download.nsf/Pages
Bigger question:
Why don't you have hot water?
Is water heater functioning?
Water heater is a separate appliance from Grundfos pump.
Grundfos pump circulates hot water from tank into the lines so there is no waiting for hot water ... but hot water heater should still make hot water.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Add a comment about water heater if that is also a problem.
You could have 2 problems, and water heater is main issue.
For do-it-yourself electric water heater repairs:
http://waterheatertimer.org/6DIY.html
Nov 20, 2010 | Grundfos The UP1510B5ATLC 125th HP 1...
New grundig pump is now making a kind of clicking noise. Grundfos ups 15-50 type of pump for central heating system. Only fitted about 3 weeks ago and started of silent now making irritating rattling...
I was ready to pass your question and go to the next person because you said it was making a clicking, and I could not relate or diagnose that type of sound for that kind of pump. Thank God I decided to read to the end where you said rattling sound. that is what you should have said in the beginning.
1st, did you replace the pump cartridge or the whole pump unit? 2nd, is the pump in a different oriented position than the original pump position? The inner cartridge floats inside the pump as it rotates and if it is in an oriented position that allows it to bounce (to & frow) it will make this rattle sound; not serious but can be annoying. It is was a replacement cartridge, perhaps the new gasket and the old gasket are in place, thus allowing too much space for the cartridge and it therfore moves too much and rattles. Or, if it was replaced as a whole new unit. there is a problem with it that you should not be responsible for, except for the positioning orientation. Finally, if there is still too much air in the system, the air bubbles will jossle the cartridge untill you get rid (bleed ou ) the remaining air. Goodluck<Macgivor
Jan 02, 2010 | Grundfos JPS4 1 HP Pressure Booster Pump
My hot tub pump will not stop running even after it has reached temperature and completed it's cycle. I have a Balboa Instruments control unit. Any suggestions?
sound like you have the filter cycle set to fc means filters all the time try to push temp button and then pump button. in sequence you want it to be f2 means filters 2hrs every 12 hours
Nov 22, 2009 | Sys BALBOA SUV SYS 5.5kW W/ 120V 1.OHP...
Grundfos UPS 25-50 180 - start up
Are you able to check for power to the pump with a mult-meter. If you have power you the know the pump has siezed (flat spot on the motor) if there is no power then you know there are issues with the controls.
I hope this may have helped,
Tom
Oct 14, 2009 | Grundfos Plumbing
Combi bioler heats water but wont heat the
There are 2 Heat Exchangers and 2 Water Pumps on a Combi, at least the one I had when I lived in the UK did.
There is a Thermal Cut Out on both. They look like a Disc, that is Soldered [with provision for connecting the wiring] onto the Hot Water Outlet from the Exchanger to the Pump, to Supply either the Domestic Hot Water, or on the other Exchanger, Central Heating.
If 1 of these fails, the System will start up and when the temp reaches a certain point will trip out the Burner, and continue to Run the Pump until the Temperature drops, and then Stop.
The type I had, had Pumps with a Black front facind nut, this unscrews anti clockwise to release that center, that could be pulled slightly, and used as a Key to turn the Pump Impeller, in the event that lack of use would make it stick, when powered up.
There shouId be a Diagram, inside of the Front Panel, that shows the layout for the whole Internal Water flow, Pipes, Pumps, Safety devices etc. I hope this has helped you.
Regards,DT
Nevada, USA
Aug 29, 2009 | Heating & Cooling
Grundfos Pumps UPS15-58FC Logo
420 people viewed this question
Top Grundfos Pumps Plumbing Experts
Boyet Soriano
Boyet Soriano
Matthew Ward
Level 1 Expert
Gil Shultz
Are you a Grundfos Pumps Plumbing Expert? Answer questions, earn points and help others
