Question about Coffee Makers & Espresso Machines
Hi, so I recently borrowed a flash drive from a friend and shortly after receiving it I dropped it in coffee. I removed it straight afterwards and dried of the excess water and plugged it in. Nothing seemed wrong with it so I continued using it, but now a message has come up saying that the drive has malfunctioned. I was wondering what I should do and if their is any way the drive could be salvaged? Thank you
    Sergeant:
  • 315 Answers
I suspect that some of the moisture has settled on the contacts or inside where the circuit board is situated. If it's a "sealed" unit, you might be better off to replace it. If you can open it without damaging the case, you will see the white-ish deposit on the circuit and it can possibly be cleaned out. Good luck, hope this helps.
Posted on Oct 13, 2013
  • 32 Answers
SOURCE: Water won't flow through the tubes
You might need to prime the pump manually since the machine has been moved.
directions:
Fill water tank.
Turn power on.
Open the steam knob all the way.
Press the coffee button.
Put a cup under the steam pump wand.
Wait until you see a steady flow of water and no air.
When you see the flow of water, close the steam knob.
Turn off the coffee button.
Now the machine should be ready to brew an espresso.
If that does not work you can contact the service center for more suggestions:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Jun 04, 2008
SOURCE: OPEN HEAD
Open the head and pull out the piece that hold the k-cup. Take a paperclip and clean out the needle. Replace and you shouldn't have a problem. We had the samething happen to us.
Posted on Apr 29, 2009
  • 60 Answers
SOURCE: fill beans message keeps coming up on jura capresso impressa s9
You need to open the grinder, it`s probably packed with old fine powdered coffee that blocks the outlet. Clean this out and try again. Since it works normal when you use pre-ground coffee, there shouldn`t be any problems with any other parts.
Let me know if you want a description for have to open and clean the grinder.
Posted on Jun 02, 2009
  • 4 Answers
SOURCE: Cuisinart Dcc-1200 coffee maker is gurgling a lot,
I had this same problem and found that coffee grounds had somehow gotten in to the water reservoir and had been circulating thru the machine clogging the charcoal filter. This must have prevented the water from entering the heating chamber efficiently and therefore continued to gurgle until it all got thru. I flushed out the reservoir by holding the pot upside down and shooting water into the reservoir. It took some time to get all the grounds out. I took out the charcoal filter, flushed out that section and replaced it with a new filter. When finished, I ran thru a solution of white vinegar for good measure and bingo!! The coffee pot works perfectly.
Posted on Mar 05, 2010
  • 81 Answers
SOURCE: Coffee not brewing after grinding
After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
Posted on Apr 15, 2010
Keurig B60 Flashing NOT Ready
Needs Priming as per page 17 in manual. Read this section.
Feb 01, 2012 | Keurig B60 Coffee Maker
How can i renew or erase my password on SanDisk microSD memory card if it doesn't appear on my computer and phone? it always says "please insert a removable disk to drive (:E) what to do? :(
Good Day, Possibly the MMC is corrupted already. but before you end up buying a new one try looking for this kind of gadget, if you have friends that have this you may just borrow this once10_30_2011_2_52_44_am.jpgThen just plug in your Memory card here, then plug in to a computer, the computer may show no activity,just let it be, the device will blink a few times, then it should be a steady light afterwards. after that the process is done. but if the device does not steady its lights the MMC is broken, or if the process is done but still password is asked.
This process completely resets the MMC so no data can be restored.
Hope this helps you.
Sep 05, 2011 | SanDisk 2GB microSD Memory Card
The two coffee lights and the water light are flashing
Had the same problem. I sealed my lips around the steam wand and sucked as hard as I could, first with open steam knob, then with closed. Obviously there was some air left inside from steaming before. Machine worked fine afterwards.
Nov 30, 2009 | Starbucks Saeco Italia Digital Barista...
For some reason i can play sierra 117. also the catch skull is mi
This sounds similar to what happened to me, except I couldn't load some multiplayer maps.
If you know someone that recently bought Halo 3,(within a week) ask him/her to return it with your defective game in the case. He/she will receive a new unopened Halo 3, and you can take your friend's recently opened copy of Halo 3.
If you don't want to be cheapskate, you can borrow Halo 3 from a friend, and save it on your hard drive. After that, you can use your defective disc just to play the game. Unfortunately, if you save it on your hard drive, it supposedly makes the game slower when searching for multiplayer matches online, and other things.
If you don't care about saving money, you could buy another copy of Halo 3.
Jul 14, 2009 | Microsoft Xbox 360 Console
Sandisk 8GB Cruzer Gone Dead
As long as it shows in Disk Management in Windows, it is most likely saveable. Borrow a flash drive from a friend, GHOST it to your hard drive and then to your flash drive (Drive to Drive may be unsafe because you can mix up which is which). It should work and then you can reformat it so as not to steal your buddies stuff.
Jun 03, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Instructions for descaling Saeco Royal Digital
I used to run vinigar and water thru my coffee maker to remove the **** vinigar is slightly acidic. make sure run just straight water thru it afterward to get rid of the taste.
Robert
Sep 05, 2008 | Saeco Royal Digital Plus Coffee...
Emachine 5260
Bad power supply will do this
Oct 20, 2007 | E-Machines eMachines Desktop PC
Grinder bottom piece cannot be removed
If you open the door in the front and remove the straining basket you will see an open space where the very bottom the grind cup sits. Take a long thin standard head screwdriver and insert it there until you feel the post of the grinding engine against the screwdriver. Turn the screwdriver like you are turning a screw. The grind unit should start to move up. You can try to use the screwdriver to pry upward to finish the job. Another post said that redrilling the brass post insert on the grind cup worked for him. The problem seems to be the grind motor post that has swollen or been misshapen through the use of the machine. If they were to ask me, there is a better design for this contraption, just look at any blender. Flat disks with downward (or upward) facing fingers on the removable container and the motor.
Sep 16, 2007 | Cuisinart DGB-600 Coffee Maker
Coffee Makers & Espresso Machines Logo
69 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
