Question about Home
What are can openers usually made of? - Home
    Guru:
  • 97 Answers
Can openers are usually made of metal and sometimes metal and plastic together
Posted on Oct 13, 2013
How do I manually close asi 850 sunroof that's fully open on my 2004 Dodge Durango 4.7l V8?
Look toward the back of the sunroof on inside, if there is a small circular piece of plastic or other slot like opening. Open it with proper tool, probably a screw driver. In there should be the part u will need to turn, with the proper tool usually sized to fit socket & ratchet, or Allen key, or star wrench. In order to close, or begin to close the sunroof manually. Usually u can get it started manually, then run it as u usually
would.
Aug 08, 2015 | Dodge Cars & Trucks
Is there a thermastat in ge adora microwaves that could overheat
there are couple protection thermostats on all microwaves. one is cavity t-stat, one is magnetron tstat. if it gets too hot inside the microwave usually cavity thermostat is wired the way that all power will go off to microwave, it will open circuit(usually they not resettable). If magnetron tstat opens up, usually will open circuit to magnetron only (so light is on, seems to run, but no heat). I Hope that helps.
Mar 01, 2015 | GE Microwave Ovens
How can I remove a DVD disc when the open/close switch is not qorking?
You can usually open a stuck disc drive bay with a paperclip. Look at your drive and check whether it has a small hole (see pic), it is usually near the button. Open the paperclip to give you a small prodding device. Place the paperclip into the hole and gently push until the door opens. Hope it works 25336095-4apljjurgwhtblpqenqx5pee-4-0.jpg
Dec 24, 2014 | LG Televison & Video
How to open hood?
Dear David Williams,
The best way to open the hood is using the lever, usually near the accelerator to the very left. There is usually a picture of a car ( SRGSRG963 image ). After you pull the lever you need to go to the hood and find the release latch, usually located in the front center. One thing to note is that different manufactures have different ideas in opening them, so it is best to consult your owners manual for full details. Here is an example video:
Hope this helps,
Vikas
Apr 27, 2014 | 2005 Ford Fiesta 1.3
Replacing battery
Need a screwdriver. Unscrew the back of the mouse. Usually there's a compartment where the battery is isolated.
Apr 02, 2014 | HP DC172B Mouse
Window and door rough out Openings
Usually adding 3/4" to 1" to the actual window or door size (for a prehung door) works well. Blueprints can vary, some are the actual window and door opening ,some are rough openings. Usually rough opens will be followed by R.O. Hope this helps.
Dec 26, 2013 | Microsoft Windows XP Professional With...
I CAN'T OPEN MY OPERA MINI ANYMORE
Sounds like you have no internet - your data plan is usually tied to your SIM/carrier. Check with your carrier because
some prepaid plans do not include data.
Nov 17, 2013 | Cell Phones
What program should i use to open files they dont open with internet explorer
A file is usually open by the computer only when the associated program is installed in the system. The associated program recognize the file extension and open it.
For Example :A notepad file will be open by Notepad editor untill and unless you cange it to open with other program.
Microsoft Word can open a notepad file too.
Files usually you will find or will downloaded from internet are usually .exe, .rar, .zip, mp3, .avi, pdf etc.
I recommended, you installed these few softwares
1. Adobe Flash player.
http://fpdownload.adobe.com/get/flashplayer/current/install_flash_player.exe
2. Adobe Reader.
http://ardownload.adobe.com/pub/adobe/reader/win/9.x/9.2/enu/AdbeRdr920_en_US.exe
3.Jave runtime
http://fs4.filehippo.com/2222/75ce054974f24f4ca18bf8c0be7bc18f/jre-6u17-windows-i586-s.exe
4. Winrar
http://www.rarlab.com/rar/wrar391.exe
Don't if you are not sure of the application to open a file.Download
"Irfanview".below is the link
http://fileforum.betanews.com/sendfile/1099412658/1/1262777908.514057fe0774684918afa85f23fdb31b3a1511ce/irfanview_plugins_425_setup.exe
It will open almost any files.
That's it.
Jan 06, 2010 | Toshiba Satellite Pro L300 Notebook
CD is stuck in my bose lifestyle system, the message displays as "opening" but does not open
Not familiar with this model but all cd tray's have a manual release mechanism, its usually a small hole on the front of the tray. I've found a paper clip unwound usually works fine. Push it in the small hole, you will feel it stop against something, push a little harder and the tray should open enough for you to manually pull it open.
Jan 24, 2009 | Audio Players & Recorders
DV-S555 wont always open
I sounds as if the guide tracks on each side are sticking. Be vary careful and put a little bit of tuner cleaner and lub on the tracks and this will usually fix the problem. Do not spray it into the tray for it may mess up your lens. Hope this helps.
Jan 07, 2009 | Onkyo DV-S555
Home Logo
597 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
