Question about Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -
The intelliflo pump, Easytouch system shuts on and off in program
This system starts and stops during its programmed runtime. The installer has replaced a board in the Easytouch8 and a pump controller on the pump. He has quit returning my calls. It doesn't seem to be a high line pressure problem.
  • 128 Answers
Call Pentair warranty and they will send someone out.
Posted on Sep 05, 2009
How do I clear a "Key Error" when trying to get to "Schedule" mode to set Start and Stop times?
your hitting the wrong key see youtube for how to program your pump i used it and it was helpful
Aug 16, 2014 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Runtime error and install stub Dell Ispiron 560
Runtime errors Some applications may be causing a conflict. Many times runtime errors are a result of incompatibility between two or more programs. Press the "Ctrl," "Alt" and "Delete" keys simultaneously to open Windows Task Manager. From the "Applications" tab, close each open application until the runtime error is resolved. Check for patches, bug fixes or upgrades by visiting the manufacturer's website. Search for your product and determine whether there are downloads to fix the problem your PC is experiencing. When none of the above fixes help, reinstall the troubling program. In severe cases, you may need to reinstall your operating system. Make sure that you back up the other programs and files you want to preserve, which may be erased during the re-installation.
Jan 22, 2013 | Dell Inspiron 560 (Intel Pentium Dual Core...
Run-time error 339 - OS: Windows 7
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
Runtime errors Some applications may be causing a conflict. Many times runtime errors are a result of incompatibility between two or more programs. Press the "Ctrl," "Alt" and "Delete" keys simultaneously to open Windows Task Manager. From the "Applications" tab, close each open application until the runtime error is resolved. Check for patches, bug fixes or upgrades by visiting the manufacturer's website. Search for your product and determine whether there are downloads to fix the problem your PC is experiencing. When none of the above fixes help, reinstall the troubling program. In severe cases, you may need to reinstall your operating system. Make sure that you back up the other programs and files you want to preserve, which may be erased during the re-installation. Hope this helps.
Jan 10, 2013 | Microsoft Computers & Internet
Pentair pump flow slows during operation
go to utube see the video on your pump programming sounds like you have the run time on 1200 rpm
Nov 17, 2012 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Runtime error
hope this helps
Aug 03, 2012 | Computers & Internet
The motor will not come on everyday like it is suppose to. You can cut the breaker off and turn in on again and hit start and it will work fine until the next day. Control panel was replaced about six...
To protect the IntelliFlo pump electronics from damage due to freezing conditions, the pump will switch itself on to generate internal heat when the air temperature drops below 40° F. This feature is not intended to protect the system plumbing from freezing. The pump will run at a lower speed than what you have it set, unless you have programmed the adjustment.
The Intelliflow pumps are great pumps, but come at a disadvantage- A whole lot of electronics.; Since the intelliflow pumps are fairly newer in the market, and you have already had the electronics replaced recently, so I am going to presume that you still are under Pentair Manufacturer warranty.
The issue you are describing remains a problem with the electronics. Since you are not getting any alarm codes, there may be in issue in the wiring or you may have a defective pump. Before calling into the manufacture, lets reset the pump to factory defaults:
The IntelliFlo VS-3050 pump can be reset to the factory default settings. All previously adjusted pump speeds that were saved will be erased. To reset the pump to the factory default settings: 1. Ensure that the pump is powered on and the green power LED is on. 2. Press the Stop button to stop the pump. 3. Press and hold all of the four Speed buttons simultaneously for four seconds. Power off the drive and reenergize. The default settings will be in effect.
If this solves your issues, then you can program the pump to operate at the desired time/speeds.
If you are still having issues, I recommend contacting Pentair Warranty at 800-831-7133. Be sure to have the date of install, the Serial and Model numbers handy when you call.
Dec 08, 2010 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Microsoft Visual C + + Runtime Error
I just recently install Window 7 ultimate on my computer and then Acrobat 8 Pro start acting up. Try to open PDF file it will open for a little while then this thing pop up said Microsoft visual C++ Runtime Library and Runtime Error. Then it shut down.
Anyone know how to solve this problems please help.
Karoon Yip
karoon.yip@gmail.com
Jan 31, 2010 | Nova Development Photo Explosion Deluxe...
I get the following problem during installation 1607: Unable to install installshield scripting Runtime. please help me
Unable to continue or unable to install with this program are searching for support on it. Runtime errors are common in system registry which a certain is missing or broken.
There are some causes on it.
  1. Confliction with TSR or other running program.
  2. Software Issue
  3. Computer Virus
  4. and Memory Use.
To fix it here is a link to help you:
www.yboyandrei.com/runfix
This one can repair all broken DLLs in your system.
Please rate if i am helpful to you.
Thank you.
Sep 01, 2009 | Peachtree Software Accounting 2005 for PC
Pump works in spa mode, but doesn't work in pool mode. Why?
We need more info. Which control system is it? Suntouch, easytouch, intellitouch.......? It sounds like a programming problem in the controller.
May 25, 2009 | Pentair 3hp Whisperflo Pool Pump In -...
Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -  Logo
523 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
