Question about Toshiba NB205-N210 Netbook
I accidently locket my bios on my toshiba nb200 j13 so i thought i had to remove cmos battery but i don't know where it is can someone find me a dissasembly video or explain me how to take apart the notebook
  • Toshiba Master
  • 7,993 Answers
Here is the link to a Toshiba laptop dis-assembly website. Explore it and find information on your model.
http://www.irisvista.com/tech/
Posted on Oct 20, 2013
mellomania
  • 121 Answers
SOURCE: toshiba tecra m2 bios missing sections of video
get to the mainboard
there is a jumper near the cmos battery usually shows the
word (jbat) near it , try to change its position for some
seconds while power is off , this way will clear cmos and set the
mainboard bios to default settings.
start the system hit delete or F2 to enter setup then exit saving changes.
Posted on Nov 15, 2007
SOURCE: toshiba A135-S4527 cmos battery dead
I found where the cmos battery is located. By the Toshiba tech support website , it's next to the PCMCIA Slot, just behind it. To get to it, Take off LCD, keyboard, top palmrest, hard drive, battery, memory, top power cover,switch board, modem, network. and some others. Too many to describe here. Items to remove not in order.
I Have the service manual downloaded already.
Let me Know
comier957
Posted on Aug 10, 2008
  • 12 Answers
SOURCE: need to unlock phoenix bios password for toshiba satellite a135-s4527
You would need to take the Cmos battery apart for 10 minutes. There another way whit password cracker but it is more hard to do it. Try searching for Hiren Boot CD's. Thanks Let us know. Obed
Posted on Sep 05, 2008
kornho
  • 781 Answers
SOURCE: Need to reset phoenix bios
have yout tried this application..
http://www.cgsecurity.org/wiki/CmosPwd
I've heard before about the toshiba paralell loopback (it's also mentioned on the website above) as a way to unlock your bios you may want to try that aswell.
post back if it worked.. would be good to know if it did.
I remember also reading about the possibility of flashing your bios (you're going to need a floppy drive unit) to at least unlock your hard drive and get your data out, you may still not be able to hack into the bios again.
Posted on Oct 01, 2008
  • 55 Answers
SOURCE: need to change cmos battery for toshiba laptop 1805-s274
look on back of laptop you will see some panels under panels you will see two little wires connected to mother board that's the cmos battery unplug it and change it
Posted on Mar 30, 2009
Toshiba portege m100 hardwares not starting
Yes the CMOS battery needs to be changed. Then you can go into the BIOS and set the Date & Time.
The CMOS/BIOS will be set back to the defaults when you remove the CMOS battery and this may fix your problems.
Sep 05, 2012 | Toshiba Portege M100 Notebook
NB205 has HDD password. How can i remove it?
- Seems like a BIOS password issue. You need to reset the BIOS and in order to do that you need to take out the CMOS/Lithium battery out for about 5 seconds and put it back in.
- Make sure you are static free and the laptop should be turned off completely, battery and power cord unplugged before opening the bottom panel.
- Locate the CMOS battery. Most of the time it is located under the memory modules or hard drive depending on the brand and model of the laptop.
- If the CMOS battery is soldered to the motherboard and you don't have experience with soldering, i suggest you bring the laptop to someone who knows how to.
- If you do not want to remove the CMOS battery, what you can try is short circuit the jumper settings. Click here for tips on how to locate jumper settings.
Hope this helps.
Sep 10, 2011 | Toshiba NB205-N210 Netbook
My Toshiba laptop got wiped and failed to wipe. So when I try to restart it, it asks for a BIOS PASSWORD in a blue box. I've tryed all tricks and don't know. The satelite number is L455-S5009. I...
The BIOS and Supervisor passwords cannot be removed or changed unless you know the existing password(s). If you forget your BIOS or Supervisor password, you will have to have the password removed by a Toshiba Authorized Service Provider
Aug 17, 2011 | Toshiba Satellite L455-S5009 laptop
Hello, My name is Vahe and I have got the following problem, I have forgot my BIOS password and I can't to turn on. Laptop model Toshiba satellite A200-13M. So I have got some solution to delete...
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 02, 2011 | Toshiba (K000002020) Motherboard
Toshiba nb200 bios password
To reset the BIOS read the information from this link: http://www.fixya.com/support/r7229632-reset_or_remove_bios_password
In case of your laptop the easiest method would be using Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery especially with Toshiba laptops as they have the battery soldered to the motherboard.
Feb 11, 2011 | SGP Toshiba NB200 Laptop Cover Skin [Cube]...
I have toshiba satellite c650 laptop but laptopb locket with power on password so please guide me how to reset password on toshiba satellite c650 password
To reset the BIOS read the information from this link.
In case of your Toshiba laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 29, 2010 | Toshiba Computers & Internet
How do I remove the mainboard battery on a Toshiba NB200 netbook, in order to reset the BIOS / CMOS passwords?
I know this not exactly what you are looking for but its all Ive found so far....it is a tear down guide for the NB but it is in Italian...lol It has good pictures as a guide though. I'll keep looking.
http://netbookitalia.it/toshiba-nb100-guida-al-disassemblaggio.html
Sep 09, 2009 | Computers & Internet
Reset bios password/jump cmos
you can remove your BIOS battery for about 10 seconds and the BIOS password and adjustmens that you custom made in your BIOS will reset.
you dont need to jump cmos if you get out the BIOS battery for a couple of seconds because the BIOS will reset itsself
let me know how it worked out
greetings
Jan 02, 2009 | Toshiba Satellite A135-S4527 Notebook
BIOS Password
I know on other toshiba's they have to connect it to a usb or lpt1 port with a special dogel that will remove it... some laptopps and desktops use a EEROM that even if you take out the cmos battory it doesnt allays reset it.. so you might have to ship it to mfg..
ps just to make sure you took out the cmos/bois battory not the laptop battory
I think I saw the video on youtube of the guy using the dongle but know clue where to get it nor any one I know has an EEPROM programer... sorry
Aug 05, 2008 | Toshiba Satellite A215-S7422 Notebook
Toshiba NB205-N210 Netbook Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
