Question about Dell STUDIO ONE 1909 ALL IN ONE CORE 2 DUO 2.93Ghz 320GB 4GB DVDRW 18.5"
I have a dell studo one 1909 all in one computer. On powering up the computer for the first time i get a red display screen that fades to normal after 10 seconds, and then 30 seconds later the monitor goes black(as in off). I then turn the power off and back on, the screen goes black after 3 to 5 seconds, leaving me no time to do anything. I have tried replaceing the motherboard (video card is permenant on the board) with the exact same results. Any suggestions on my next steps, besides get a real computer.
SOURCE: Display goes black after 5 minutes
Repairing the DELL E171Fpc LCD Monitor with the complaint of display shutdown after few seconds (power LED still on) was not difficult. Normally when this type of problem happens, we would first suspect the inverter board, then the filter capacitors and lastly the main board. A defective in one of the lamps and a faulty TL1451AC PWM IC or inverter ic may caused the display to shutdown as well. If the lamp is defective, it will send a feedback to pin 3 or 14 of TL1451AC IC and caused it to stop producing output signal thus the display just shut off once you switch it on.
Posted on Jun 02, 2007
SOURCE: problem in monitor
you need to either buy a new inverter board, or if you are competant with soldering onto boards, you need to replace the c5707 transisters at points q740, q739, q760 and q759 on the larger board. best place really for the replacement c5707s is ebay
Posted on Aug 27, 2007
techniwiz
  • 275 Answers
SOURCE: Dell Monitor goes blank, green light still on.
try one thing this will tell you if there is a problem with the monitor or the system
start the system and go in to bios and than check out if u still loose display
and if yes than when u loose display disconnect the data cable of the monitor from the system and chk out if u see the self test on the monitor or not
the self test if the colour patern if u see that its nothing wrong with the monitor its ur system
if u do not see the colour patern ... monitor bad
if the colour patern is seen reseat the cpu heatsink , remove the display card (if any add on display card ) and reseat the memory cards
and if that doesnt work remove all the add on cards and than start the system on the onboard display
and than put the cards one by one u will get the culprit
Posted on Nov 20, 2008
  • 11 Answers
SOURCE: Screen goes blank
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Cause of power going off: There is a bad 1000uF, 16V cap on the power supply board.
Solution: Replace cap. Radio Shack sells a 1000uF, 35V cap for $2. This will work.
Why did the cap go bad? The cap is too close to a heat sink and over heated.
What does this cap do? This cap sends a signal to an IC which keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage is applied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor: These monitors are difficult to open.
The two plastic pieces snap together and must be pried apart with a flat screw driver.
After removing the stand, you need to insert a flat screw driver at the bottom of the screen where two slots are located. Then work the screw driver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuit board.
Unplug the monitor cords from the driver board and remove the screen.
Unscrew the mounting screws from the power supply board and remove.
You will need to pinch the plastic support in the middle of the board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will be on the side of the cap. It will be bulged up on the top. You will see burn marks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + of the cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from the heat sink as possible.
Reassemble monitor and turn on.
This should solve the problem.
Posted on Jan 01, 2009
  • 53 Answers
SOURCE: Dell E173FP 17" Flat Panel
you are seeing a common problem there are 4 transistors that switch off the power to the back light most of the time these are not bad but the solder joints have cracked causing a bad connection and simply resolder these will fix the problem.But there are also a problem with bad caps in these monitors it is ez to see them cause the top of the bad cap will be bulging up I have seen 100s of these monitor fixed with just resoldering the connection in the power board which is also the back light board.any flicker in voltage in this circuit will cause the power to the pack lights to shut down.
Posted on Jun 10, 2009
How can I fix my this ? Pixel colour fades on screan , though battery is fully charge , how can I fix this please?
some computers will fade the screen automatically when on battery power. on windows systems, you can change those settings (normally) by going to Control Panel -> Hardware and Sound -> Power Options -> Edit Plan Settings (beside the option in use) -> change advanced power settings -> Display (see screen shot)
Sep 14, 2015 | Samsung GT-N8013EAYXAR - 10 1 Galaxy NOTE...
The print on my screen is very light and hard to read. How to fix?
The brightness of the screen on battery and on AC power is configured in the pre-OS setup.
When the computer starts you will see options like press F2 or DEL to enter Setup.
Choose this option and you should find your brightness settings.
Two points:
Lower brightness saves battery power.
Your notebook display will fade over time. You might be able to find a replacement at eBay. If not, I am sure Dell will fix it for you.
I hope this helps.
Jun 26, 2011 | Dell Inspiron 2200 Notebook
Hi - the screen on my dell d410 goes dark 20 seconds after powering on, regardless of whether I boot normally to Win (XP) or hit F2 to reach the BIOS. Note the screen display is just about visible if...
As per the problem description the Laptop Display is Fade out even in BIOS window. If that's the case then the unit must be serviced as the issue is Hard ware related. The Computer uses minimum Softwares in BIOS Mode, Hence most of the Diagnostics related to Displays and Input adn Output devices are done in BIOS. I suggest you get the unit serviced. For details of the Nearest Dell Authorized service Center please visit the following Link:
http://www.dell.com/content/topics/reftopic.aspx/dfo/topics/en/services/services_warranty?c=us&cs=22&l=en&s=dfh&~ck=mn
Dec 06, 2010 | Dell Latitude D410 Notebook
My computer keeps telling me to type in a password every few mins
I suspect that you have your computer set to go to a power-saving mode in a very short time and then have password protection enabled to resume normal operation. In the Control Panel, find the screen saver option (I suspect you can also get there from righ clicking on any unused section of the display and choose Graphics Properties and go from there). Uncheck the box for "On resume, display logon screen"; also adjust the wait time to one that better suits your usage.
I hope this helps.
Jan 16, 2010 | Microsoft Windows Vista Home Basic for PC
Black screen
If it fades linearly, it is probably the high voltage inverter for the backlight fluorescent lamp. Generally, the lamp dies over time with some flickering of it first.
That inverter is normally on a small, separate board and once the unit is open, it is easy to locate and replace.
Sep 30, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 25, 2009 | Acer Aspire One PC Notebook
Dell inspiron... turn on and screen will not display anything, but slightly illuminates... plugged into desktop screen, running safe mode, computer will run, but cannot boot up normal on desktop screen and...
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 11, 2009 | Dell Inspiron 6000 Notebook
My dell latitude D830 display colors have faded.An
I would check your graphics card control panel. You may have (or someone else) set the contrast or some other setting to low or high. If you are using nvidia you can run the optimization wizard.
Mar 12, 2009 | Dell Latitude D830 Notebook
Dell monitor is flickering
If you have another computer, try hooking to it and see if it flickers on it too.
If you hit Ctl-Alt-Delete and choose Task Manager, does the box flicker there?.
Adjust the monitor ratio in the Display Settings/Display/ Display Adapter Properties, Monitor Tab, see drop down (increase screen refresh ratio to higher number).
Nov 10, 2017 | Dell E207WFP LCD Monitor
Monitor fades and turns blue
this sounds like a transistor issue concerning the ccfl lamps the power transistors are deteriorating and they will eventually go bad you can have them replaced and that should fix the issue. otherwise I would say have the capacitors that feed the ccfl's may be getting old and need replacement as well, its not something the average customer will want to do but if you have a service center that does electronic repair then that would be bst.
Hope this helps
Jan 30, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell STUDIO ONE 1909 ALL IN ONE CORE 2 DUO 2.93Ghz 320GB 4GB DVDRW 18.5" Logo
41 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
