Question about Wharfedale Titan 12 ACTIVE 12" 2-Way Powered Speaker
I want to hook up my Titan 12 speakers to computer, but don't know how.
Wharfedale problems
Take it to a repair shop. You have a short circuit or too small a fuse. Have an expert check it before you try to use it again.
Apr 05, 2014 | Wharfedale Titan 12 ACTIVE 12" 2-Way...
Don't know how to recharge
Just use the combined USB/audio cable. Plug the standard USB side in your computer, or even in the back of some modern TVs, and then plug the other side with the smaller USB plug into the speaker.
Sep 29, 2012 | xMini X-Mini II Portable Capsule Speaker -...
Installation of speakers
The speakers require the AC adapter to be connected for the speakers to function. The AC adapter powers the amplifier of the speakers
http://support.dell.com/support/edocs/acc/ada215/ada215.pdf
Apr 18, 2010 | Dell A215 Computer Speakers
My monitor speakers are not working name of my monitor is Spectrum 9 GIrsA or GlrsA could you help me locate the problem . I know tht the speakers work ,because when I hook up another cpu the speakers...
check if you have installed your sound drivers and the monitor drivers , if they working good on other cpu that should fix your problem. if you don´t know how to check or update drivers let me know. and good luck
Jun 12, 2009 | Dell E153FPT 15" Flat Panel LCD Monitor
Wharfedale Titan 12 ACTIVE 12" 2-Way Powered Speaker Logo
16 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
Matthew Spark
Matthew Spark
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
