Question about Sharp Office Equipment & Supplies
White stripe when send fax - Sharp Office Equipment & Supplies
If the person you send to receives a copy with a missing column of text or image, chances are the scanner is failing. The scanner has a row of optical sensors. If a few of those sensors [often in a group right together] stop working, then no image is recorded from the original under the bad sensors. Depending on what you paid for the fax machine, it may well be more cost-effective to buy a new fax machine than to pay for someone to replace the scanner. To test the scanner, run the machine in copy mode and see if your copy comes out with a white stripe.
Posted on Oct 14, 2013
MY SAMSUND SF 560 IS SENDING BLACK STRIPES ON FAXES
open the scaner unit and take out the white roler. clean the glass whit alcole and put roller back. thes it it sould be fine.
Aug 31, 2011 | Samsung SF-560 Plain Paper Laser Fax
Vertical stripes appear on incoming faxes
Hi:
Try making a copy and verify that the vertical stripes are showing up in the same area. If not, then the problem is not with your fax but the sending fax.
Andrew
May 27, 2010 | Brother IntelliFax-2820 Laser Fax
Black stripe running down left side of paper when
Open the top of the fax where your documents go in. There will be a thin **** of glass where the document is read. On the end that reads "dirty" is a smudge or some white-out that needs to be cleaned. You may have to clean it with some cloth wrapped on a flat tool. Do not scrap or scratch anything, just clean enough to get the dirt off. Then make a test copy.
Apr 29, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
I get big black stripes on copies i make or faxs i send to somene .
you need to clean the **** glass. this is what views the image to be sent. you probaly have white out on it. very common.
Dec 26, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Every time I send a fax from my Dell 966, a black stripe appears down the middle. All photocopying/printing is operating normally, its just the fax that won't work! How do I fix this?
its quite possible the area that scans the paper(s) you are sending is dirty.
If the machine is one of those phone/fax/scanner/copier jobs, simply open the top panel, and with a damp cloth, wipe the runners that feed the paper through from left to right or right to left (just make sure any dirt you're wiping goes off to one side)
its also possible that a paper (that white-out was used on) that has been recently faxed, left some white out on the feeders
Aug 16, 2009 | Dell 966 All-In-One InkJet Printer
When making a copy we get an ink stripe down the center
open up the document feeder and clean the scanner glass.
Jan 21, 2009 | HP 1040 Plain Paper Inkjet Fax
FAX received full of black stripes
If you are using upper tray to send the fax than kindly open the fax gently and clean the lens with some cotton and spirit and than try to send the fax you will get the best result. to open the fax unit gently refer the user manual or this open by lifting it up side and you can see the lens inside it so clean the same ok.
Dec 22, 2008 | HP LaserJet 3050 All-In-One Printer
Blank vertical stripes on incoming faxes
1st. Print a report. If the blank stripes are still there, you must remove the drum and t6oner combination and clean the laser glass located on the bottom of the machine.
If the blank stripes do not appear, then the fault is on the scanner of the sending fax machine.
Feb 25, 2008 | Brother IntelliFAX 2800 Laser Fax
Copies here and recipients faxes: dark, lined
How long has the drum been in there?
try this:
1-take out toner, look and see if it is ok. do you see stripes on it?
2- look at the drum are there any black rings on it? ( you did not specify white or black lines)
3- where the glass is on the opposite side ( the part you lifted to clean the glass, look at it standing from the back. you will see a white metal plate with some springs in it if you touch it. this is the reference that the fax has if there is/are a black dot on it it will give you a black line clean carefully. if it is scratched use white out to cover and make white again.
For the darkness try making a copy in photo mode if it is still too dark change drum.
Dec 07, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
White "Stripes" across page
REPLACE PAPER AND THE INK CARTRIDGE
May 14, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
