Question about Seagate Computers & Internet
Hi, my Toshiba 500 GB external hard drive is suddenly inaccessible! The message I am getting is "The parameter is incorrect" Can anyone advise what can be done to fix this problem? Thank you
  • 2 more comments
  • sami
    sami Oct 17, 2013
    I really wish to recover the data on the disk before formatting, although I tried to format it but that also failed as Windows is unable to access the drive and the only message I get "parameter is incorrect". Please note that my computer is detecting drive D when it is pluged in but cannot be accessed! There is no hardware defect, only I need to know if there is a way to fix the incorrect parameter and make the disk function again. Thanks
  • B.Boelens Oct 18, 2013
    It's either a hardware-problem or a software-problem. Thats's the reason why I've included 4 steps to see where the problem is located. I forgot to mention there's another thing you can perform under Windows, which is even shown at YouTube. Please check the following link.
    Add a Commenthttp://www.youtube.com/watch?v=Bp1MUqMHWZY
    http://www.youtube.com/watch?v=Bp1MUqMHW...
    Novelist:
    Scholar:
  • 100 Answers
You might consider the following steps first :
1) Try to remove the USB-cable from your PC. Now try to re-attach it to another USB-port at your PC.
2) Try to connect this external disk to another PC.
First of all, you should check if your harddisk is still under warranty and even may give it a call at Toshiba customer-service for help.
If you've lost warranty or prefer to solve it yourself, you can go for the following steps :
3) If this didn't solve the problem, there's a chance there's an internal failure of electronic components at your USB-enclosure. In such case it's best to remove the disk and see if you can reconnect it inside your computer to the motherboard. If the problem is solved, than, yes, it was a failure at the USB-enclosure. It's time to look for a different USB-enclosure which you can buy quite cheap online, or at a local store.
4) If the problem still maintains, you're problem is a bit larger: the harddisk got seriously damaged / defective.
Posted on Oct 15, 2013
Testimonial: "Thanks a lot B. Boelens for your support, however that did not work. I got no problems with the USB port on my laptop, also the portable disk has no hardware issues, something went wrong with the parameter! Have you got a way to fix the parameter? Thanks a million"
  • sami
    sami Oct 19, 2013
    Hi B. Boelens, thanks again for your continuous support. I tried following your advice and everything seemed to be going well until (while processing chkdsk/r (x:) I got a message "Error found. chkdsk cannot continue in read-only mode" What can I do to overcome this problem? Thanks a lot
4 Suggested Answers
SOURCE: XP doesn't recognize my external 500 GB WD My book essential edition hard drive
I had the same problem some have posted about. I had a lot of data on my drive and then one day it didn't show up in "My Computer" anymore. I had to assign a separate drive letter to the external drive.
Plug in the drive.
Right click on "My Computer"
Click on "Manage
Click on "Disk Management"
On the bottom half of the right side you should find "My Book" assigned to a disk number.
Right click on "My Book"
Click "Change Drive Letter and Paths"
Click Change
Select a new drive letter and hit OK
Hope this helps some people out.
Posted on Nov 06, 2008
SOURCE: power supply details for Maxtor 500 gb, external hard drive and ? manual
The PSU for my Maxtor 500Gb 9NZ2A4-500 drive is 12V DC, 2A rating, 2.1mm "plug" with centre "hole" as positive.
Regards, kbsguru
Posted on Nov 24, 2008
SOURCE: power supply for Maxtoe Basics External Hard Drive 500GB
Is 12VDC 2,0A the inner pin is + and the outer pin is -
Posted on Dec 04, 2008
I:\ is not accessible.the parameter is incorrect.......i m used seagate expanision portable drive,model SRD00f1 500 gb
you have moved your hard drives around on the usb port, your playlists are still trying to find the last location it was in, you havent lost anything, just your pc is looking for the files where it remembers them, search for one of your files you know of, it will still show up.....then right click it and select "open location" take note of where the file is located, it may be calling your external drive D: or E: now....i would delete all playlists and create new playlists to where they are located. also make sure the folder they are stored in is shared.....just right click the folder where the files are know to be hiding, and select properties, and enable share....and share type select "everyone" and reboot
Feb 27, 2014 | Computers & Internet
Hdd detected however error message incorrect parameters. files not seen
right click on 'drive'
go to properties
click on security
click on your user name in the upper window
and in the lower window select all check box allow
click on apply button then ok
it will work definitely
plus
from explorer, right click the hard drive and properties, and in security tab, click full access for system & users
However if proper drivers are not available then download it from
http://www.seagate.com/ww/v/index.jsp?locale=en-US&vgnextoid=1b0cfbbad0f89210VgnVCM1000001a48090aRCRD
Nov 17, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Toshiba 500 GB External Hard drive cant be detected by windows xp
yes you could simply format the harddrive in Fat32 using your macos that would be the best solution but don`t forget to backup your data by copy pasting the files on your mac or something else and after that to move them on the external hdd again to be available on the windows machine
Mar 11, 2010 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
Seagate 500 GB external hd that suddenly changed from NtFS to RAW
You can use a utilities like partition recovery to try to recover the previous partition.
Sep 17, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
SimpleTech 500 GB external hard blinking red light
I got one with the same problem. I opened up the case and hooked up the hard drive to a generic usb to sata adapter that i picked up on ebay and it works fine now if a bit clunky looking.
Sep 10, 2009 | SimpleTech 500GB SimpleDrive Pro External...
Usb devise not recognised
You probably damaged the drive from sudden disconnection of the signal line. I would suggest trying it on one other computer before considering it trashed.
Jun 08, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
Simpletech 500 GB external hard drive - unresponsive
If you really can not get it to work anymore, you could try opening it up and connecting the hdd directly on a IDE/SATA port in your computer. This will only work if you have a desktop, for a laptop you would need all kinds of converters.
May 03, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
WD 1TB MyBook suddenly needs reformatting?
most likely cause of this is that the partition tables are corrupt....you'll need to run a checkdisk on the drive..
go to command prompt
change to drive letter of the drive you want to scan
type in
chkdsk /p
you should get a message about windows finding some faults and repairing them....once done you should be able to access the data on the drive
Jan 19, 2009 | Western Digital My Book Home Edition 500...
How do I get the files from the WD external (500 GB) to my computer
In this case the MOST effective way is to try some data recovery program to see if it can help rescue your data on your WD external.
Jul 24, 2008 | Western Digital My Book Essential Edition...
Computers & Internet Logo
64 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
