Question about Pool & Spa
Digidoor 2 garagedoor motor dropped and broke the connections. need the wiring diagram
  • 3,103 Answers
Need photo..
Posted on Jan 11, 2014
My digidoor 1000n motor recently did not close all the way leaving a gap of about 60 mm and yesterday the gap seemed a bit bigger more like 100 mm how do i set it to close fully
on the rail there should be 2 cylindrical black magnetic read switches with white wires connected to them.
Those are the open and close distance units
sometimes they come loose and move with the vibration of the motor when opening the door
Nov 30, 2016 | Cars & Trucks
Hi,I have a Digidoor 3 motor & it open & closes as normal but after the garage door is closed it drops the chain about 15cm then slums it back into the track. Can anyone help me out please?
will need a digi door or roller door mechanic in your area
head office ? use contact us
DigiDoor Garage Door Motors Installations Repairs of DigiDoor 1000N...
three motor makes it harder
door drop is 15 cm is not a good thing
chain system needs to be retention ed
motors synchronized
event track may need to be re aligned
Oct 31, 2016 | Building Materials
Who do I contact for Digidoor repairs and maintenance in the Lydenburg area?
only link for digidoors repair
one company
use "contact us " their web page
to get the nearest authorized repairer of didgi doors to the lydenburg region
Oct 14, 2016 | Building Materials
Can i fit 12v battery backup for digidoor 11 to open when there is loadshedding. My digidoor2 had the extra consoke for remote receiver
Nope, Digidoor II has no battery backup. You need to invest in a UPS or replace the motor.
Digidoor one, Digidoor III and the Digidoor IQ all have build in battery backup.
__________________
Reference:
http://www.4x4community.co.za/forum/showthread.php?t=142874
Jun 13, 2015 | Computers & Internet
I bought a receiver to pair a Centurion D5 motor with thE Digidoor motor.How do i install the Receiver on a Digidoor motor?
Hi there Vusi.
You should have a manual open and close switch on the wall for your Digidoor. You need to find the two wires which control the open and close functions on the Digidoor Trace these back to the Digidoor motor connect these to the Comm and NO terminals. You also need to supply 12V power to the receiver This needs to be connected to the Possitive and Negative terminals on the receiver. These connections originate in the Digidoor motor housing and can be connected right there. Some Digidoor motors have connection terminals for additional remote receivers in the housing. Remember that the minimum connections needed are Positive, Common(Sometimes the common is also the negative supply so you can bridge the common and negative terminals on the receiver) and NO. Then pair the remote with the receiver as per the instructions in the receiver box. If you still cannot come right post pics of the PC boards of your receiver and Digidoor motor and I will identify the connections for you
Jan 05, 2015 | Televison & Video
Digidoor ii wall console will not open or close the garage door
First thing to check is the power. If this is on, then the only answer is that your green wire linking console button to the motor has a break in it. I found my break at the motor connection - after time this had been bent and weakened and had snapped. I snipped end of green wire (motor side), cut away plastic and reconnected to motor connection with two arrows up and down, and wa la! Try it.
Mar 11, 2014 | Transcend T-Sonic 850 Digital Media...
How do I connect a external receiver to digidoor motor
I assume this is a garuage door opener. Connect the NO contact across the two wires that go to the push button.
Feb 01, 2014 | Electrical Supplies
I bought a second hand Digidoor 1 with garage door. The door opens and closes perfectly when the digidoor is off. When I power up the digidoor the motor will not open the garage door when the door is...
You are receiving interference from the digi door. You will have to return this unit and go with a different one on a different frequency. Chamberlain makes a clicker that would work well with that unit. Thanks BB
Sep 21, 2010 | liftmaster Chamberlain Garage Door Opener...
I have a digidoor 2 automatic garage door and it closes in stages not in one motion. The problem started when I stopped the closing motion half way down by remote control to let someone in. Up until then...
It sounds like your obstacle setting might be set too low and the friction of the door is causing the motor to stop. There are two white alan key adjustments on the side of the motor that can be adjusted to change these settings for the up and down sensitivity. If this does not solve your problem contact the Digidoor technical helpline on 2711 4749060, they will be able to assist you.
Aug 24, 2010 | Kitchen Ranges
Sesam 200 garagedoor opener/lift will not run anymore
Originally posted July 2, I doubt he is still here waiting.
Jul 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pool & Spa Logo
136 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
