Question about Contour 720p Video Record Dash Camera Helmet Cam Dvr
Hi, I have a mini f9 dvr camera but i need to update the firmware on it. I have the updated file but not sure what to do after that. Any help would be appreciated. Regards Andrew Phillips
Need to update the firmware for dvr model 404 cms76b
If you wish to get some details; check the site linked here. Pull up older posts.
Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Jun 06, 2016 | Televison & Video
Firmware update fail on night owl fs84500
Same here. Updated firmware system rebooted and locked on the Night Owl screen. Mine is the FS-8500.( DVR model FS-500 ). Anybody find a fix to the issue? I believe the firmware is in the motherboard. Anyway to hook to PC and "push / force" the firmware into the DVR. Or some tyoe of master reset. Or is this thing bricked for good.
If it cant be fixed, do you know where I can get a new motherboard with firmware installed. Tried talking to tech support but am fighting with them over the issue. Pretty freaking useless over there.
Aug 19, 2012 | Night Owl Optics Night Owl LION4500...
FIRMWARE for Sanyo xacti vpc-hd2000!?
Updating Firmware on Xacti HD2000
This page explains how to download and install the firmware update for the VPC-HD2000.
  • This firmware is for the VPC-HD2000 only. Please do not install it on another model.
  • By installing this firmware Greek, Swedish and Finnish will be added as new menu languages. (Please notice that for this purpose the menu languages Traditional Chinese, Simple Chinese and Korean will be deleted!)
    It is not necessary to install this firmware update when there is already the possibility of choosing Greek, Swedish or Finnish as menu language! Please check this before continuing with the update.
  • Before updating the firmware, please read through the explanations on this page.
  • Make sure to update the firmware in the order shown below.
  • The camera might not boot up properly if its power is turned off during the firmware-updating procedure.
  • Please read the accompanying licensing agreement before downloading this firmware. Downloading the firmware automatically implies your acceptance of the licensing agreement.
Requirements:
  • SD memory card (henceforth referred to as "card") with capacity over 8 MB.
  • Fully charged lithium ion battery.
  • Additionally, you need one of the items listed below:
    (i) A SD memory card reader (henceforth referred to as "card reader")
    (ii) A dedicated USB interface cable (shipped with the camera).
CAUTION
Be sure not to take out the battery during the updating procedure (this lasts about 60 seconds).
Avoid operating the buttons on the camera or closing the monitor unit during the updating procedure.
I) Preparing to update (copying the firmware onto a card)
Step I.1: Format the card on your camera*
  • Turn the camera on and set the "REC/PLAY"-button to "PLAY"
  • Press the "MENU"-button.
  • Move joystick to the left and select "OPTION MENU 3".
  • Move joystick to the right and select "FORMAT". Press the "SET"-button.
  • Select "FORMAT". Press the "SET"-button.
  • Select "YES". Press the "SET"-button.
    *CAUTION
    If you format a card, all images and data stored on that card (whether protected or not) are deleted! Please be sure to move or copy important images and data to a PC or to another card!
Step I.2: Download the Firmware*
  • The firmware can be downloaded here.
    icon_dl1.gif Firmware Update XACTI HD2000
    s313n081.bin (7.5 MB)
    *CAUTION:
    Please be sure to download the file onto a hard drive and not onto a removable location such as a card reader.
    The firmware file should be saved in a location where you can easily find it again later (e.g. save it on desktop of your computer).
Step I.3: Copy the file "s313n081.bin" to the formatted card (from step I.1):
The method of operation differs depending on whether you use a card reader (i) or a dedicated USB cable (ii).
(i) When you copy the downloaded files with a card reader: (1) Put the formatted card from step I.1 in the card reader. (2) Copy the "s313n081.bin" file created on your hard disk in step I.2 to the root directory of the card.
(ii) When you copy the downloaded files with a dedicated USB cable: (1) Connect the camera to your PC with a USB cable and turn on the camera. When you connect to your PC, please make sure the camera's USB interface is set to "Card Reader". (Please refer to "Setting the Connection Mode" on pages 7 to 8 of the Instruction Manual in the Xacti Software CD 1.0) Please make sure the camera is recognized as a removable disc. (2) Put the formatted card (from step I.1) in the camera and then copy the "s313n081.bin"-file created on your hard disk (in step I.2) to the root directory of the card.
(3) Remove the camera from computer.
Please read "Dismounting the Camera" on pages 9 to 11 of the Instruction Manual in the Xacti Software CD 1.0 for a description of how to disconnect the camera.
II) Updating firmware on the camera itself
CAUTION>:
Do not turn off the power during the updating procedure (this lasts about 60 seconds)!
  • If the power is turned off during the updating procedure, the update may not be properly completed and the camera may not start up.
  • To prevent the battery from running out during the updating procedure, please use a fully charged Lithium ion battery.
  • Do not remove the battery during the updating procedure.
  • Do not operate the buttons on the camera or close the monitor during the updating procedure.
Step II.1: Insert the card with firmware-update file (from step I.1) into camera
Step II.2: Turn the camera on and set the main switch to "PLAY".
  • The playback screen will be displayed.
  • If the camera is in SIMPLE mode, switch it to NORMAL mode.
Step II.3: Press the "MENU"-button.
  • The menu screen will be displayed.
Step II.4: Choose "OPTION MENU 3"
Step II.5: Choose "FORMAT" from the Menu Screen, but do NOT go into "FORMAT"
Step II.6: Move joystick to the left for more than 2 seconds.
  • The update screen will be displayed.*
    *No Update Screen
    If the update screen is not displayed, it's possible that the update file was not copied onto the card. Please refer to "Preparing to Update" to copy the update file onto the card and follow the updating procedure once more.
    If the main switch is set to "REC", the update screen will not be displayed. Make sure the main switch is set to "PLAY".
Step II.7: Choose "YES" and press the "SET"- button.
  • Updating will start.
  • During the updating procedure, the screen will show the message, "LOADING. DO NOT POWER OFF", and the access light will flash.
    Please do NOT turn the power off during the updating procedure! (this takes about 60 seconds).
Step II. 8: When the updating procedure is completed, the camera will turn off automatically.
  • Please remember to format the memory card once more before using it again.
Oct 15, 2010 | Sanyo Xacti VPC-HD2000 High Definition...
Is it normal that when you r updating the firmware of it,much of time is needed?..the MB is increasing while updating
Usually firmware update takes much time depending on the speed of the Internet connection which you have.
First nokia updater have to be downloaded and when you try updating your mobile firmware then the nokia updator downloads the necessary update files from internet which takes again some time. After the firmware download then actual firmware updation happens. This will take some minutes.
Please note that interruption in firmware update may make your mobile unusable. Then you have to make a service call if anything happens like that. so perform firmware update with a high speed Internet connection and have UPS for your system.
I hope this is helpful to you.
Thanks
Mar 07, 2010 | Nokia N97 mini Smartphone
How to put videos in sansa mp3
Hi There !!!
If you want to add videos into MP3 player. I would say you have to have the Sansa Media Converter (SMC) to be installed in the computer.
For your kind information, the file format supported are : ASF, AVI, DAT, DivX(ver 6.0), DVR-MS, MOV, MP4, MPEG 1, QT, WMV, and 3gp/3gpp2
Feb 02, 2010 | SanDisk Sansa Fuze MP3 Player
Cyberhome DVR 1600, where can I get the firmware update
Hi there
The best bet now the company has gone bust is trawl through the forums to see in anyone has a firmware upgrade saved and available for download. Here is a good start.
http://www.avforums.com/forums/index.php
Good luck and thanks for using Fixya!!
Feb 19, 2009 | Cyberhome DVD Recorder - DVR1600
Pioneer DVR-K17B
I have the same problem. Has anyone found a solution? I have an HP Notebook dv6700 with a Pioneer DVDRW [DVR-K17B ATA Device]. For the past few months I haven't been able to burn anything to disc. I can't find any firmware updates online. I'm not sure if I need to buy a new drive?
Thank you in advance for any feedback.
Oct 26, 2008 | Pioneer DVR-107D DVD±RW Burner
Troubles Transferring, now power
You are describing a software and firmware update.
The software update should not have any effect on the camera start-up, but the firmware update could.
Please check to see if there were any instructions sent with the firmware files (like a Read Me file or release notes), which might give you special instructions for properly loading the firmware. Some manufacturers require that you hold down certain buttons on the device when power cycling to load the firmware.
Also ALWAYS be sure to have newly charged batteries of the right type, because a power failure in the middle of a firmware upgrade can ruin a device, requiring service.
Go to their web site to get details about the firmware update, if you are sure you did infact update firmware. Also, their tech support should be able to assist you with additional issues if their recent release is problematice for any reason.
Good luck.
DigiChick
Jun 20, 2008 | Olympus SP-350 Digital Camera
Contour 720p Video Record Dash Camera Helmet Cam Dvr Logo
758 people viewed this question
Top Contour Home Security Experts
Lawrence Oravetz
Are you a Contour Home Security Expert? Answer questions, earn points and help others
