Question about Hitachi VH650 2 1/2" Full Head Fencing Coil Nailer
My Hitachi NR83A blows air out of the plunger in front of the trigger and the driver goes all the way down when I plug it in. All the o-rings have been replaced as well as the o-rings in the trigger. What is wrong?
There is a small ball and a small rubber tube in the trigger as well, are the still there?
Posted on May 11, 2009
    Sergeant:
  • 206 Answers
95% of the time your problem will be in the head of the gun.
You said you put an o-ring kit in it, so next check the head cap (877-307) for any nicks or imperfections, replace it if so. The other area in the head is the 2 gaskets under the head cap - if you try to check them, you will have to replace them - they will tear when you separate them.
The other possibilities - one, one of the o-rings on the cylinder guide got pinched when you reassembled, or your gun housing could be distorted causing one of the Cylinder guide o-rings to not seal properly.
These are the most common reasons for a Hitachi trigger leak.
Posted on Oct 11, 2012
2 Suggested Answers
  • 1388 Answers
SOURCE: Hitachi NR83A air leak
Most all Hitachi nailers that use the plunger style of firing/safety mech will leak air past plunger (part #877-339) when firing, however should not leak when connected to air or resting. If air is leaking past plunger when connnected to air check following:
Remove head to reveal cylinder plate (part#877-318). Remove plate and check outer oring for nicks or broken. If nicked or broken, replace and problem solved. If in good condition, remove cylinder guide (part #877-310) and check two outer orings for nick /cut. Use caution when removing/installing cylinder guide. It is easy to pinch orings when installing causing air leak at plunger. If orings are in good shape then problem is warped body of gun not allowing outer orings to seal. To check for warped body, use the cylinder plate as a guage by lowering it into the area where the cylinder guide rests. Good Luck with your repair.
Posted on Mar 12, 2009
Hitachi 45ab blowing air out of trigger
If air leaks thru trigger as soon as you connect airline, replace the vinyl ball under the trigger stem. If air leaks when you depress the trigger, replace the small oring on the trigger stem. If air leaks slightly from plunger in front of the trigger valve, problem is inside of the gun. Remove the head and pull the large circular plate. Replace the large outer oring. Good luck
Feb 10, 2014 | Hitachi NV45AB2 Roofing Coil Nailer
Air is pouring out of the head of my NR83a Hitachi nailgun
It appears that there is a small o ring that has missed you attention in reassembly and has fallen out of the groove. re do the job paying to gaskets and o rings.
Mar 10, 2013 | Hitachi Nr83a- Strip Nailer-driver Blade...
My hitach nr83a just blows air out the exhaust when pluged in and wont shoot. is this a trigger or exhaust problem ???
Your problem is most likely where the cylinder / head come together. In the Hitachi framers, the cylinder is designed to move up and down (unlike Bostitch where the head valve moves) so if the O-rings are dirty or broken, or the spring under the cylinder is broken - the cylinder won't make a good seal to the head valve.
You can try plugging the tool in and giving a couple of firm taps straight down on the head with a rubber mallet - if the leak stops or slows you'll know the problem is with the cylinder movement.
Check the head valve seal - often they get sand / debris embedded in them which prevents the cylinder from making a good seal.
It is rare for a Hitachi trigger to be a problem.
Nov 24, 2011 | Hitachi Nr83a- Strip Nailer-driver Blade...
NRA833AA model. air is leaking out of trigger valve & will not fire. require manual to check operation.
Here is a link to hitachi web site listing for your gun. Look at the bottom of the page for pdf files of parts lists and manual.
http://www.hitachipowertools.com/store_item.php?iID=154&arrPath=1,9,43,p154,
There are two areas around trigger that can leak air. Spray soapy water on trigger stem and/or plunger valve. If leak is at trigger stem check vinyl ball. If leak is at plunger valve, most likely worn or broken oring inside of gun. Remove head and pull outer ring to reveal two orings. A worn outer oring will cause leak at plunger. If orings are ok on outer ring, pull cylinder and check for scratches where orings contact. If scratched, sand with 400 grit paper untill smooth and repack gun with oring kit. Good luck.
Jan 09, 2011 | Hitachi NR83AA3 3 1/4" Clipped Head...
My hitachi nr 83a leaks air at the trigger
Often a trigger leak in the NR83A is caused by a bad gasket in the head #877-327. If this is improperly installed, cracked, or overcompressed it will cause the trigger to leak.
It is uncommon for the trigger itself to be the problem.
Sep 24, 2010 | Hitachi Nr83a- Strip Nailer-driver Blade...
Air leak
My Guess is that it needs a new "O " ring or some other form of seal some where round the trigger actuating spindle. Should be quite easy to fit if you can get one the right size
Jun 05, 2010 | Hitachi NR83A2S Framing Nailer, Full Head,...
Air leaking aroung the trigger assembly from my Hitachi NR83A
if you took the trigger apart the part that you unscrew has a nylon ball and a black rubber ring you should check them and make sure that you didn't loose them when you took it apart,if they are there, then you need to service the gun, and after you clean all the moving part and you put it back together, it may still leak from the top,Take a rubber hammer and give it a good hit,now not to hard, and it should seal
Apr 27, 2010 | Hitachi NV45AB2S Coil Roofing Nailer
I just rebuilt the nail gun with all new o-rings and gaskets and when I put the air to it air actually blows the rubber boot off the plunger on the trigger assy.
I am assuming that the boot is blown off when your fire the nailer. This is caused by a loose/worn plunger and valve. If the plunger moves from side to side too much air will flow past the valve and blow off the boot. Most used hitachi nailers will blow this boot. Only way to fix is replace one or both parts. If air leaks past the boot immediately when you connect to air, check oring on plunger A (part# 874-820) or outer orings on cylinder guide and cylinder plate. These outer orings are easy cut while inserting these parts into cylinder. Check orings for nicks. Good luck and post again if you have more questions.
Mar 11, 2010 | Hitachi NV45AB2S Coil Roofing Nailer
Mar 12, 2009 | Hitachi NR83A2 2" To 3 1/4" Full Head...
Hitachi VH650 2 1/2" Full Head Fencing Coil Nailer Logo
271 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
