Question about Hotpoint Washing Machines
Hot point washing machine aquarius ws541 is not working alllights flashing????
SOURCE: washing machine hot point aquarius wms38
remove the panel at the lower rear of the machine you will then see the motor there are two 13mm head bolts remove both of these, hold the motor and push it toward the front of the machine this will disengage it and it can then be lowered and removed from the rear of the machine remembering to disconnect the white multiconnector and the earth wire. Job done refitting is the reverse of removal.
Posted on Mar 07, 2008
barkencoa
  • 3463 Answers
SOURCE: washing machine stops mid cycle and lights start flashing
Drain the water by lowering the hose into a bucket or something and then try it on spin, if it spins o/k then you probably have blocked pump or filter.
The filter is located in the large black hose that is fastened to the bottom of the drum, remove and clean.
Hopefully this will solve the problem.
Plz rate this solution.
Thanks.
Posted on Dec 17, 2008
localwonder
  • 6784 Answers
SOURCE: lights flashing / flickering on face on controls-machine not work
This is normally a signal that is for a control fault. you will need to pull the power and shut this unit down for 5 minute.. if the unit continues to flash after this reset, you will need to replace the control board/timer in this case. it has failed.
Posted on May 22, 2009
barkencoa
  • 3463 Answers
SOURCE: door lock flashes doesnt work or start up
The flashing door lock light is indicating that the door is not closed proerly.
This can be caused by a weak or broken spring in the door handle.
Another reason for this to happen, is a faulty control board at the top of the washer, a blown track will cause this.
This in turn, is usally caused by a fault on the motor.
Hope this helps.
Posted on Jan 20, 2010
  • 51 Answers
SOURCE: WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
appliancesdav@hotmail.com
pallesappliancerepairs.com
Posted on Feb 03, 2010
Hot point Aquarius machine. Lock light flashing red but won't reset.
could be ther is still water in the machine which is why the door is still locked still wast pipe blocked unplug it fo a while 30 min
Oct 03, 2015 | Washing Machines
Hi washing machine Aquarius hot point wt540 lights flashing will not turn off or cancel. Removed top top find the wires had burnt .
You could cut both ends beyond the black and use a butt connecter to splice them together. Don't forget to unplug it first
Sep 29, 2012 | Washing Machines
Pipe burst water got into machine.we dried it out and now when we press on button lights are flashing..nothing else working
Remove top cover, and lower rear cover of washer.
Get a hair dryer, and blow the hot air into the washer at every point you can gain access to.
If it still does not work, then it could be that one of the electrical components has suffered damage due to water getting on to it.
Good luck.
Dec 29, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
Dec 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine stops mid cycle and lights start flashing
Thanks.
Dec 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hot point aquarius wf740
Hi.
F03 indicates that the wash thermistor is open or short circuit.
I think you need to call engineer to sort the problem
Please leave feedback.
Dec 02, 2008 | Hotpoint Aquarius WD640 Front Load...
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
Feb 13, 2008 | Hotpoint WMA32 Front Load Washer
Flashing FOO3
The F003 error code relates to a deffective wash thermistor that should be replaced. Now its depends on your technical qualifications if you will do it by yourself or will call for a tech. Good luck!
Aug 23, 2007 | Hotpoint Aquarius WF210 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
