Check the audio settings first. Check whether Balance control have set to center or not. It should be at its center position, to get the both speakers to work. If it is found OK, check the left speaker. If it too found OK, then check and replace the damaged component/s at its audio output section circuit. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
SOURCE: Samsung Dnie, flashing lights then no color!
Turn every thing off then unplug power cord for a good 30 seconds - check all cables and turn back on.
SOURCE: plano tv samsung txe2746
saludos tengo un problema en la fuente de alimentacion y exploto el integrado que esta unido a un disipador de calor precisamente en el serial del integrado quien me podria ayudar facilitando el plano electrico del samsung txe2746.
gracias
