Question about Dryers
Hoover Aquavision DYC 8913B Tumble Dryer.......Starts then after 30 secs switches off. I have cleaned out filter at bottom & the same thing happens when restarted. There is a red light on left hand side that comes on...
textonor
  • 130 Answers
SOURCE: Bosch Tumble Dryer Filter Light
Helenhjb, there is a couple of things I can think of that can cause this. The filter is one. The mesh on the filter is extremely fine, so get a steady stream of water running, then put the filter under the water. If the water doesn't run straight thru, then wash the filter with detergent until the water does run straight thru. If this works fine, then your issue may be that the door switch is set too far back and when you do heavy loads, the laundry pushes on the door and shuts down the dryer. On the Bosch, any time you open the door during the cycle, it will flash the lint filter lamp. The only other thing I know of usually has an E:01 flashing on the display is restricted vent. Hope this helps.
Posted on Feb 03, 2008
yalmer
  • 549 Answers
SOURCE: hoover nextra tumble dryer
Please first check if both fuses or the circuit breaker has not tripped.
If you are getting only 120v on one leg of the 140v power, you may get lights and no heat, otherwise please give the make and model.
Posted on Feb 27, 2008
  • 5 Answers
SOURCE: Tumble Dryer not getting hot
thermister i.e thermostat in located just in side of fillter housinfg damaged replace i
Posted on Sep 12, 2009
  • 17 Answers
SOURCE: hoover tumble dryer filter light staying on and
if you have cleaned your filter at the door and checked the outlet is not blocked either then it will most likely be the heater element on the back of the machine, it has three parts to it, 1 thermal switch,2 is some sort of magnetic type switch and 3rd is the element its self,
problem is its only sold as one unit, but very easy to replace.
Posted on Mar 03, 2010
SOURCE: I need to clean my filter on my beko tumble dryer!
I usually just stick the shower on it to clean out all the bits of fluff that gets gathered in there, but remember to give the inside of that hatch u brought it out of with some kitchen towel before u put the condenser filter back in.
Posted on Oct 18, 2010
Could you tell me where the thermal limiter is situated in a DYC8913B please
Ian, Did not find your particular model, links below may help in changing and testing your thermostat.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Condenser Dryer Model No DYC 8913B Product Code 31100391
Hoover DYC8913B 80 Thermal Limiter
Dryer Isnt Heating High Limit Thermostat Testing Dryer Troubleshooting...
How to replace thermostat on tumble dryer how to diagnose the fault
Apr 24, 2016 | Hoover Dryers
Hoover Tumble Dryer VHC 391t. Its starts and does a cycle stops to turn the other way and just stops. If you press the start button it just clicks.
The most common problem for this would be the motherboard of the system that's controlling the Hoover Tumble Dryer. You will have to either get it repaired by a professional or get a new dryer.
May 14, 2012 | Hoover VHC391 T-80 Dryer
Hi, My 8kg Hoover Tumble dryer Vision HD stopped working, first a filter care light, so cleaned the filters and now the light comes on but nothing happens. Any ideas? Thanks Matt
try drying the inside of where the water reservoir is.also water may be collecting in a hole on the base of the condeser hosing.
Jan 08, 2011 | Hoover Dryers
Our Hoover 8kg tumble dryer is not working - lights on but not moving around. Any ideas?
if you are adventurous take the plug out of the wall to remove power for safety . there is an access panel at the bottom of the dryer take off the cover and with a flash light look at the motor and pulley assembly to see if the belt broke it might be laying in the bottom of the dryer if not might might be the timer assembly . their is also a switch on the door it can go bad you can check it by taking a pencil or some other small round object and pres the switch in and try to turn on the unit that will check two things without replacing needless parts.
Feb 25, 2010 | Hoover Dryers
Hoover tumble dryer filter light staying on and blowing cold air
Jun 05, 2009 | Zanussi TC7102W Electric Dryer
its your thermostat mate they cost 30quid simle to fit
Jul 06, 2008 | Dryers
Hoover tumble dryer
I think you may have a bad relay on the motor, where power is re-applied after the push start is released
Oct 11, 2007 | Hoover HDC6 Electric Dryer
Dryer stuck in sensing mode
Since no help was available without premium assistance, I actually contacted a repairman. He performed all the tests again and told me the problem was the control board. Then wanted $600 to fix. I found the part online for $150 and fixed it myself in about an hour. Instructions were easy.
Sep 08, 2007 | Hoover HDC6 Electric Dryer
Dryers Logo
173 people viewed this question
Top Dryers Experts
