Question about Sewing Machines
The tension dials on my Bernina 2000DCE overlocker is not working, no matter where I turn the dials, the tension remains the same, a mess! Any suggestions?
    Champion:
  • 241 Answers
Possible problems are lint between the tension discs. You can clean this with a business card. If the tension discs are not meeting together you must take the machine apart to adjust the spring tension. If all the tension discs not closing. If that is the case your presser foot tension release lever may be stuck.
Posted on Oct 13, 2013
Testimonial: "Thanks Joe, I will try to clean between the tension dials as suggested, if no luck will resort to taking it to a technician. Cheers."
  • 106 Answers
SOURCE: bernina 1300 dc overlocker skipping stitches
Make sure the chain stitch thread is threaded exactly as it should be, make doubly sure the thread comes off the bobbin vertically and runs through all eyes smoothly. Any faults in the threading causes extra tension at the needle despite what the tension is set on.
If this is not the cause then the needle depth and the looper timing needs checking.
Rob
Posted on Mar 30, 2008
talk2ginny
  • 34 Answers
SOURCE: My Bernina 930's lower tension
Hi - you might have a dirty bobbin case, or need a new one. IAfter awhile, little teeny dust bunnies can collect in your bobbin case and cause your bobbin tension to go wonky, especially if you use cotton thread. If you happen to have an extra bobbin case, try using the new bobbin case to see if that solves the problem. Otherwise.....
  • Remove your bobbin case and take out the bobbin. Find a small, stiff brush like the one that came with your machine and stand in very good light. Brush out the inside of your bobbin case, and push one or two bristles of your brush into any opening you can see. If you see any trace of dust but you can't get it out, use tweezers to gently pull the dust out. Now look at the outside of your bobbin case. In the small opening where you insert your bobbin thread into the bobbin case, there is a small piece of metal with screws in it the lays over the bobbin case. Brush that area carefully, and again, insert one or two bristles under than piece of metal and into any other small opening where the bristles will fit. Try sewing again. If you are still getting loops, take out your bobbin case with the bobbin thread still inserted and grab the bobbin thread with two fingers. Let go of the bobbin case - sort of like you are holding a yo-yo. If the bobbin case starts to drop as soon as you let go, your bobbin tension is loose. If the the case doesn't move, gently snap the bobbin thread you are holding and see how far the bobbin case moves down toward the floor (you might need to try this a couple of times, the bobbin has a nasty habit of flying out). When you do the snap, the bobbin case should move down about two inches and stop. If do not know how to adjust the bobbin tension, either check your manual or take the machine in for service.
  • If you haven't already, it's a good idea to remove the thread plate that sits under the needle and clean that area out with your brush. Also, get a really good flashlight and check the area where you insert your bobbin case. Gently turn your fly wheel and look inside the hook area - remove any dust or bits of thread.
In general, you should oil your machine as indicated in your manual as often as directed. You should change your needle every 10 hours of sewing - or each time you start a new project, and you should take your machine in for service every one or two years - even if you only use it once and awhile.
Hope this helps, Ginny
Posted on Jan 31, 2009
redbeard00
  • 957 Answers
SOURCE: Thread tension for Brother XL 2230.
If you have pattern dials set correctly then I might guess that one or more sets may have been missed when the thread was being set up in the machine. most of these models show either arrows or numbers for each or way the thread needs to be routed.
Posted on Apr 26, 2009
  • 51 Answers
SOURCE: tension dial not correcting tension problems
Look to see if the 'check spring" is still there, and not broken.
If the tesion nob can be truned without any feeling of tension, then maybe the screw that attaches the 'tension housing' to the stem has loosen or broken.
Posted on May 10, 2009
yeroc
  • 397 Answers
SOURCE: Baby Lock BL3-406 tension setting messed up.
set all to 3-4
Posted on Nov 27, 2009
Setting the tension on bernette 203 overlocker
The standard tension setting for an overlock stitch is the midway point on the dials. This is the factory setting, however, it may be different on each machine due to use and age. Of course, those tension settings will need to change in order to achieve other stitches, ie rolled hem...
HINT: When threading, ALWAYS RAISE the presser foot and give each thread an extra little tug when going through the tension disk to make sure the thread is seated securely. AND, be sure to always thread each thread in the order specified in the manual.
You might want to download the Serger Workbooks (below) and work through them. As you do each project, note what settings your machine requires in order to perform each stitch satisfactorily--this will save you a lot of time whenever you want to get a specific stitch.
Bernina Mastery Workbooks (scroll down)
Apr 30, 2017 | Sewing Machines
How do I get a balanced tension with my Elna 624 overlocker?
The best way is to thread with 4 separate colors of thread and then studying the stitch result. With the 4 colors, you can easily tell which thread tension is "off" and whether it should be tightened or loosened. However, a serger is not like a sewing machine where you can set the tension and use that setting for most projects. With a serger, a change in one or a couple of thread tensions will create a totally different stitch.
For most machines, there is a mark at the midway point on each tension control that is the "optimal" tension for a 4-thread overlock. HOWEVER, every machine differs, so these settings may need to be tweaked.
Make It Handmade Perfecting Serger Overlocker Tension
The Anatomy of The Best Serger Tension My Tips Bonus Unpick it Serger...
How to Adjust Thread Tension on an Overlocker Singer Australia
Different Serger Stitches and How to Use Them
You may want to download the serger workbooks at this site (Bernina), and work through each of the stitches. Make notes in the workbook as to how you have set up your machine to get the best of each stitch. This will be a great reference manual for many years.
Feb 23, 2017 | Elna Sewing Machines
My Bernina overlocker 334D is correctly threaded but does not make the loops when i sew.
indicates incorrect needle thread tension
make sure that the thread is between the tension plates
Dec 29, 2016 | Bernina Sewing Machines
Bernina 335 serger won't sew/overlock. carefully rethreaded the serger but that hasn't helped.
The 335 has a two thread chain stitch (stitch type 401), and the overlock side (right needle side), is a three thread plain overlock. If you are describing the plain overlock as the problem, I would first suggest the following in re-threading:
1. Thread the upper looper
2. Thread the lower looper
3. Thread the needle last (important)
If the needle threaded, you cannot re-thread the lower looper without breaking the thread.
In order to thread the lower looper, the lower looper must pass by the needle thus picking up the needle thread. So, instead of threading the lower looper thread underneath the needle thread, the looper would be threaded on top and cannot sew without breaking the thread.
Make sure that the threads are bedded between the tension disks. Check this by stretching the thread fore and aft of the tension disks as well as visually noting that the threads are not accidentally threaded behind the disks. You can also loosen the tension disks when threading so as to allow the threads to bed deeply between the disks.
Please reply with your observations.
Sep 27, 2015 | Bernina Sewing Machines
2000dce
No question ! Anyway, I only deal with Bernina sewing machine questions.
Sorry
Dec 12, 2011 | Bernina Sewing Machines
Starting overlocking
hi there,
check & correct the FF:
  • Correct thread tension.
  • Replace needle.
  • Replace needle with correct size.
  • Use proper thread or needle.
  • Check threading order.
  • Increase pressure on presser foot.
  • Reset needle.
Jun 01, 2009 | Bernina Sewing Machines
Bernina overlocker 203 locking thread is not sewing on fabric
You need to adjust the tension for your threads. Use scraps to test sew as you adjust the individual threads to bring them into proper balance. Your manual will tell you how to do this.
May 12, 2009 | Bernina Bernette 75
Bernina 1300 dc overlocker skipping stitches
Rob
Mar 14, 2008 | Sewing Machines
Sewing Machines Logo
85 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
