4.1circuit diagram woofer - Audio Players & Recorders
Tip
Infinity bass pro - Circuit diagram
See the circuit diagram for Infinity. sub-woofer. Electro help
on Jul 08, 2014 | Sony 182556522 1-825-565-22 SUB WOOFER...
I have a 97 528i that kept throwing P0340 code so changed the CPS and still is throwing the same code why?
have you changed the correct CMP sensor
the code refers to sensor A bank 1circuit malfunction===causes wiring---sensor---ecm
it may be a bad wire or connection or the wrong sensor
Jul 14, 2015 | Cars & Trucks
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Nov 14, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
I need a wiring diagram from car stereo to 2 x 6 " x 9 " and a sub woofer please
You can connect the two 6x9 speakers to the two individual left and right outputs of the car stereo.
Connect each of the left and right channel with the correct polarity . Now the Sub-woofer requires an amplifier to be connected separately and so you need to use the car stereo to be linked to a sub woofer amp which powers the sub woofer.
Mar 26, 2011 | Car Audio & Video
I have a SPL phantom dk-3400 car amp and when i
Even withou the help of any diagram you have a visual indication. Look inside to the area of the burn. identify the component. check around the burned area for the cause of the burn. it could be the failue of the output or the power side. equipped with a multimeter you must be able to identtify stage by stage the short of the circuit. remove, replace and test. afterwards connect the woofer - check if your woofer coils are damaged too- Hope this helps? Good day
Jul 12, 2010 | SPL PHANTOM DK-3400D Car Amp
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
Circuit diagram of 1400 watt woofer amplifier
www.the12volt.com/ subwoofer wiring diagrams and then find out what ohm of sub u have and how many voice coils and what ohm your amp is stable at.
Jun 10, 2009 | Beyma WOOFER, 1400 WTS, 18" => Model...
Wharfedale Moviestar 60+...
witch company your sub woofer. aleredy company has given user manuval see connections in manuval okkk
Mar 12, 2008 | Wharfedale Moviestar 60+ System
22 people viewed this question
 Grubhead
Grubhead
