Question about HP Office Equipment & Supplies
HP photosmart 5520 does not print in black - HP Office Equipment & Supplies
5 Suggested Answers
gaya79
  • 31 Answers
SOURCE: No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Posted on Nov 06, 2007
  • 130 Answers
SOURCE: hp c4480 prints blue instead of black
Check the print properties and verify the black ink cartridge still has ink in it.
Otherwise, you may have a bad ink cartridge. If the cartridge has not been used for a while, the ink gums up the nozzle. You can try cleaning the ink cartridge and slot with alcohol. However, new color and black cartridges may be the best solution.
Posted on May 02, 2009
  • 214 Answers
SOURCE: hp 2610 will not print black even with new cartridge. HELP
Try cleaning the gold contacts on cart first, with distilled water. Let dry and try again.
If not, try this one
1.Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Inkypete
Posted on May 24, 2009
maxcarson
  • 7627 Answers
SOURCE: hp photosmart will not print the black ink
Does it need a new cartridge? Replace .
Posted on Dec 11, 2012
How do I get my HP Photosmart 5520 series to print from the front as opposed to the queue?
Evelyn, I think you're a little confused, the print queue is created when the printer is in standby mode, or you're sending documents to print faster than the printer can deal with them.
Printing from the front, I assume, is from the front tray where the paper is.
When you send something to print, you see a little printer icon appear near the clock (bottom right), double click it and a window opens, click printer and if use printer offline has a tick at te side of it, click on it and it will release the print queue.
Mar 20, 2015 | HP Photosmart 5520 e-All-in-One -...
Why do my pictures have tiny black lines running vertically thru them when I print pictures?
Hi
If you have recently changed one or more of the cartridges you may need to align the print head, the following steps explain the process:
To align printer from the printer display
1. From the Home screen, touch the Settings icon, and then touch Tools.
2. On the Tools menu, touch the down arrow to scroll through the options, and then touch Align Printer.
3. Follow the instruction on the screen.
To align printer from the printer software
On Windows:
a. From the Start menu on your computer, click All Programs, click HP.
b. Click the HP Photosmart 5520 series folder, click HP Photosmart 5520 series.
c. Under Print, double-click Maintain Your Printer.
d. Under the Device Services tab, double-click Align Printheads.
These instructions were copied from the manual at the following link
http://h10032.www1.hp.com/ctg/Manual/c03353113
If this doesn't fix the problem, you may like to check the HP support page for the 5520 at the following link ---> support hp com
Trust this helps, best regards Alan
Feb 11, 2015 | HP Office Equipment & Supplies
Why wont my printer let me print off my work
Generally speaking when I see this message I just hit OK and it goes ahead and prints and everything shows up without being cut off - I am in the ink business and my test page shows this message all the time but its not an issue if you press OK and part of ther page is cut off you eitherr need to expand your margins or make the content fit the page
Sep 15, 2014 | HP Photosmart 5520 e-All-in-One -...
My 5520 all in one printer does not print black
did you try cleaning the head? or a new cartridge?
Tony
Jul 14, 2014 | HP Photosmart 5520 e-All-in-One -...
Black not printing
Leave the print head ( not the whole cartridge!) soaking overnight in a little puddle of solvent e.g. print head cleaner or alcohol. This is much more effective than the printer clean program or a quick rub with a cotton bud.
Apr 16, 2013 | HP Photosmart 5520 e-All-in-One -...
Hp 5520 will not print from sdhc 16g card
From what I can tell from the specs, the 5520 works with MMC and SD cards, 2GB and smaller. It won't work with higher-capacity SDHC cards.
Mar 15, 2013 | HP Hewlett-Packard - Photosmart 5520...
Hp 5520 will not print from sdhc card
From what I can tell from the specs, the 5520 works with SD cards, 2GB and smaller. It won't work with higher-capacity SDHC cards.
HP Photosmart 5520 wont print when pc is connected to router through ethernet and printer wireless
Have you tried a cold re-boot on printer PC and router worth a try first then check all are on-line and communicating Can you use the PC without the Ethernet cable or a direct cable to the printer just to set it up (Re-set up).
Regards David, more info may help all the bests.
Ps. my old HP is a pig at time but I never have to use the cable which is a good job as I can never find the thing...
Dec 25, 2017 | HP Photosmart 5520 e-All-in-One -...
Hp 5520 wireless printing
Please state what make/model printer you are using.
Aug 25, 2012 | HP Photosmart 5520 e-All-in-One -...
102 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
