Question about Dryers
We have a Siemens TXL 754 tumble dryer. If will not heat, seems to work ok otherwise. Any ideas please. Have checked and clean all filters. Many thanks Rick
SOURCE: my candy civ60 dryer dose not heat
hi i too had that problem,when an engineer looked at it the thermostat,element were ok,he suggested that there was a blockage in the air flow,i took the whole thing apart ( i had nothing to lose ) cleaned it with a hoover very carefully then with a clean dry paintbrush,there is vents underneath the dryer if these get blocked the dryer blows cold air, its a saftey measure so that the fluff dosent catch fire ! i hope this helps,mine has run ok for 3 months now.
Posted on Mar 09, 2007
  • 5 Answers
SOURCE: Tumble Dryer not getting hot
thermister i.e thermostat in located just in side of fillter housinfg damaged replace i
Posted on Sep 12, 2009
canbruce75
  • 1776 Answers
SOURCE: bosch tumble dryer, model wta 4100 , no heat,
If the dryer isn't heating, check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. Both components are located in the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Hope this helped and best wishes.
SOURCE: Hi, My 8kg Hoover Tumble dryer Vision HD stopped
try drying the inside of where the water reservoir is.also water may be collecting in a hole on the base of the condeser hosing.
Posted on Jan 11, 2011
  • 3074 Answers
SOURCE: SIEMENS SIWATHERM TXL 2400 /
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Posted on Feb 23, 2011
Clean filter
If this is a condenser dryer, it could be the condenser unit that needs cleaning
Dec 21, 2013 | Siemens Dryers
The tumble dryer is working perfectly and is vented through the external wall with a plastic hose , however the dryer is producing high moisture levels we have checked the connection fro the dryer to the...
Your problem is probably a heavy lint build up in the Dryer or Hose.
Check your blower system on the dryer for a heavy lint build up, also remove to clean or vaccum or whatever is necessary to clean the plastic tubing because they will still flow some air, but be really plugged up with lint and could cause a dryer fire.
This is a free answer, Please rate me
Apr 11, 2011 | Dryers
I have an indesit IS60V tumble dryer and it's no longer drying my clothes even though the dryer tumbles fine. I have checked the filters to ensure they are clean and the vent hose which all appear ok.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 24, 2010 | Indesit IS70C Electric Dryer
I've got a zaussi tce7276w condensing tumble dryer and its taking 3-4 hours to dry a load of clothes it doesn't seem to be getting hot inside i've cleaned all the filters and checked the back for blockages...
yu may have a bad heat switch but it sure sounds like ur dryer vent is kinked or clogged double check better yet unhook it from the back of the dryer and dry a load of clothes if better ur problem is in that vent
Feb 24, 2010 | Dryers
The tumble dryer is working but not heating??? cleaned all filters and water tank. any ideas???
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter. In your case it is better that y ou call in an engineer to test it. Also overloading and blocked filters can cause the thermostat to cut out and they can also go with simple wear and tear. Check your service manual for spare parts etc
Jul 19, 2009 | Dryers
No heat from my tumble dryer
Presumably the motor and fan are working.
Check filter, and if it is vented with a hose, make sure it is not blocked with fluff. if all seems to be o/k, then the heating element is probably faulty.
Please leave good feedback if this helps with your problem
Nov 26, 2008 | Dryers
Hoover nextra tumble dryer
Please first check if both fuses or the circuit breaker has not tripped.
If you are getting only 120v on one leg of the 140v power, you may get lights and no heat, otherwise please give the make and model.
Feb 26, 2008 | Dryers
Dryer takes longer
You need four things,each in the right amount to effectively dry clothes: Heat, Airflow, Tumbling and Time. The first two account for probably 90% of dryer problems. It looks like you almost ruled out #2 but this design likes to build lint up in the filter housing below the filter. Shine a strong light down into the slot where the filter goes. Pick out any clumps with a refrigerator coil brush and a vacuum. To rule out not enough airflow due to long vent etc. run one load through with the vent totally disconnected and see if it makes a difference. Otherwise we'll asssume the drum tumbles and that you're setting it for enough time. Check the temperature is left. You can get a rough idea of the drum temp by using a meat thermometer in the exhaust duct. Normal range is between 140-200 degrees.
Jan 06, 2008 | Whirlpool GEW9250P Electric Dryer
Dryers Logo
85 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
