Question about Kenmore 88752 Top Load Stacked Washer / Dryer
How to open front of washer cabinet?
Model 110 88752 791
Ser MJ3417114
Technician came out yesterday, said 2 of the 3 supports have punched through the big black center support (part #671012 at RepairClinic.com) for the washer tub.
Until we can buy a new unit, I want to rig up some alternate supports, like bricks or wood, so we can run an emergency load now and then (we have a not-fully-toilet-trained kid).  I know this is not ideal, but I think the benefits outweigh the risks.
Now I need to open the front cabinet back up, so I can get at the machinery, but I can't remember how the technician did it. I do remember that the cabinet clips are down near the bottom, one at each side, lined up vertically on the side lip of each side panel.
4 Suggested Answers
SOURCE: Removal of front cabinet panel of washer section
Should be two screws on each side of the bottom of the front panel. Takes those out and push the panel up and out. (There are two "tabs?" in the middle of the front panel that lock into the side panels, so you have to push up and then pull out.)
Posted on Jan 15, 2009
  • 1937 Answers
SOURCE: MOdel 110.92579110 leaking water out bottom of
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.92579110
LEAKING:
See the Sears site sub-components for the agitator, basket and tub. It's possible that one of the gaskets or seals has worn over time.
I'd also pull off the cabinet and check the hoses leading to and from the pump. It's also possible that the pump is leaking.
See the following for how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
The illustrations also show how to remove the transmission.
OIL
The black oil / fluid that you see is likely coming from the transmission.
Since it seems to be "spraying" around the inside of the cabinet, I'd assume that it is leaking from the top seal between the transmission and clutch.
See the following for a parts breakdown of Whirlpool top load direct drive washers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If you look at page 15, you'll see a Seal, Gearcase Cover. It is possible that that is the cause of your transmission leak.
The rust on the bottom of the transmission may (hopefully) be simply caused by the water leak.
I'd remove the gearcase cover (8 bolts) in order to check the gearcase cover seal, and to check the oil level. The Whirlpool transmission takes about 15oz or 80-90 weight oil.
Posted on Oct 17, 2009
Testimonial: "All the reference sites are very helpful and a time saver, so thank you! Now on to my further repair homework to solve all the mysteries of machinery."
blueextc3221
  • 15935 Answers
SOURCE: 94702 Front Load Stacked Washer / Dryer: How do I put the top back on my kenmore front load...
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!**((
Posted on Oct 01, 2010
Kenmore Washer model # 11082692120 is Leaking as it is filling the tub with water. It is leaking at the base of the machine on both sides and in the front bottom. it was gradual at first now it is leaking...
The leak is likely coming from a broken drain pump or detached pressure hose. Remove the machine cabinet to access and look at these areas.
Unplug the machine then release the console from the top of the cabinet. Remove the screws securing the console then pull forward and up and lay it back on the hinges.
Disconnect the lid switch h
arness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer
by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing
the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base
Using the side of your leg and/or body
as a support for the front of the cabinet, carefully lift up the cabinet and set it aside.
Replace the drain pump(part number
3363394) if it's leaking. Pry the clips securing the pump to the motor off and remove the pump.
Remove the hoses from the pump and connect it to the new pump and install it back in place in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine. Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Jul 16, 2011 | Kenmore Washing Machines
Lid switch needs to be replaced
Disconnect power then release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and lay the front on a cushioned floor to access the lid switch.
Remove the lid switch ground and mounting screws then release the wire harness from the metal retainers. Pull the lid switch connector out and install the new lid switch in reverse order of the removal steps.
Jan 23, 2011 | Kenmore Washing Machines
How can I replace the pump belt of a washing machine Sears Kenmore model #110.82671710 stock #26717
The Kenmore top load washing with the given model number 110.82671710 is a direct-drive type and doesn't have a pump belt. The pump is directly coupled to the rear spline of the motor.
The cabinet needs to be removed if access to the drain pump and replacement is necessary. Remove the screws attaching the bottom front corner of the console to the top of the cabinet then pull forward and up on the console and lay it back on the hinges.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base. Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up and set the cabinet aside.
With the cabinet removed, pry the clips securing the pump to the motor off and remove the pump.
Detach the hoses from the drain pump and attach it to the new one then install it back into the rear spline of the motor and secure it with the retaining clips. Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Dec 23, 2010 | Kenmore Washing Machines
The washer filled up with water but wont turn on
This is a clear evidence of a broken lid switch. Power to the drive motor is routed through the lid switch. The machine, therefore, will not turn on when the lid switch is not working. Manually activate the lid switch and if still doesn't work, bypass the lid switch. Disconnect power then jump a wire between the outer terminals of the disconnected connector from the cabinet top then reconnect power. Replace the lid switch to address the problem if the machine works with the lid switch bypassed.
Release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Nov 09, 2010 | Whirlpool LSN1000LW Top Load Washer
Our Kenmore washer (23812) stops working at the spin cycle, and the water will not drain out of the machine. Help!
This is a clear evidence of a broken lid switch. Power to the drive motor is routed through the lid switch during the drain/spin cycle. The machine, therefore, cannot drain and spin when the lid switch is not working. The drain pump doesn't work because it is directly coupled to the rear spline of the motor. Replace the lid switch to address the problem.
Oct 28, 2010 | Kenmore 23812 Top Load Washer
Kenmore model 110 top load washer water drips out slowly, takes a long time to fill tank
Either the inlet hose screens or the water inlet valve screens or the the water inlet valves not opening completely. Check the screens and the water flow from the inlet hoses by removing them from the water inlet valves. The water valves are not opening properly and needs replacing if the screens are clear and the water flow from the inlet hoses are good.
Remove the cabinet to access and replace the water inlet valve assembly. Unplug the machine from the electrical supply then release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and set it aside. You can now remove the water inlet valve assembly and install the new one then reassembly the machine.
Sep 25, 2010 | Kenmore 15864/15862 Top Load Washer
Where can I find the model number on my kenmore elite washer?
TOP LOADERS
Look at following areas for the model number:
* Rear Center Of Lid Well
* Left Upper Back On Base Cabinet
* Back Top Control Panel
* Right Rear Corner Of Washer Top Lid
* Open Lower Left Front Base
FRONT LOADERS
* Rear Center Of Door Well
* Right Rear Corner Of Washer Door
Oct 26, 2009 | Kenmore Washing Machines
Whirlpool ultimate 2 model#lsw9750pw3 ser.ct1941128 leaking in front. appears to leak from a bow with 2 hose connected.
Your water pump is attached to the motor and is probably the source of your water leak.
Replace the pump.
Use the attached video to show how to access the cabinet and pump.
May 03, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Difficulty installing brass clips on kenmore model 110.92274100
first off the clips should go right in place if the cabinet is installed properly..with the lid open tip the cabinet and place it in place.. the very front of cabinet must go UNDER the front frame plate of washer. And the side then sit atop the frame.(in the very rear,perhaps 2 inches in from either side there is as a small slot cut into the cabinet and a corresponding tab on the washer frame itself. it should literally sit right into place(might take a little finagling, but it'll fit nicely.. when this happens the brass clips, will first hook into the back wall of cabinet and then with a little pressure push and snap into the cabinet you removed
Mar 22, 2008 | Kenmore 24032\24036 Top Load Washer
Washer is filled but will not wash or rinse, there is a noise when trying to run. It will drain but not spin, and it will fill
Probably has a bad motor coupler between motor and transmission. Remove 2 screws in front or in back of console on ends. Shake console back and forth while pulling up. It will raise up in front and pivot back. Disconnect plug for lid switch on washer top. Remove 2 gold colored clips with flat blade screwdriver. Make note of how they go in first. Open lid and grab washer cabinet and pull forward, lifting washer cabinet off frame. Remove pump with 2 clips. Remove 2 screws holding motor clips. Remove clips. Remove motor. Look for broken fingers on coupler. Should have 3 on motor and transmission parts of coupler. If not, replace coupler. Very common part.
When re-assembling, tilt back cabinet and put front edge under frame. Then lower cabinet to base. Make sure sides are in frame. Install clips by hitting down with palm of hand. Install connector. Lower and install console screws.
Nov 15, 2007 | Roper RAS8445KQ Top Load Washer
Kenmore 88752 Top Load Stacked Washer / Dryer Logo
157 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
