Question about Thomson Speedtouch St585 V6 Sl Wireless Modem Router Mbps 4-port 10/100
I want to change my default gateway 192.168.1.254 in my thomoson St585v6 because it was ip conflict with another router.....how can i change that one ..pls help me out ..
Valaki tudna segiteni nekem
Posted on Dec 29, 2013
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
I am trying to connect my Dlink DKT-401 router to my Linksys cable gateway router. I am not getting internet access when connecting to the Dlink network
I DON'T THINK YOU CAN RUN 2 ROUTERS ON THE SAME NETWORK UNLESS ONE IS USED AS AN ACCESS POINT.
1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode. Note that some home wireless routers do not support client mode; these must be connected by cable. Check your router documentation for details on its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP address setting. Often, these default IP addresses will not work in a two router environment. Check the second router's IP address value and reset it if necessary to work within the valid address range of the first router (and to not conflict with any other device on the network).
3. Disable DHCP - To avoid IP address conflicts between all of the devices on the home network, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
Instead of adding a second wired router to an existing network, consider adding a network switch instead. A switch accomplishes the same goal of extending the size of a network, but it does not require any IP address or DHCP configuration, greatly simplifying configuration.
Readers Respond:
Dec 11, 2010 | D-Link Computers & Internet
Keep getting "limited access" when connecting to netgear wpn824v3
This problem occurs because of ip conflicts in network. For that you need to enable DHCP on router or need to change ip address in computers as your network range. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on DHCP enable it then save settings and restart router.. Let me know if you need further assistance. Thanks for using FixYa.
Oct 07, 2010 | Computers & Internet
How to change default gateway
Default gateway is the IP address of the router.
Connect the computer to the router.
Open the setup page of the router using the current default gateway number.
On the setup page of tghe router, you will see the router local IP address.
You will find the current IP address of the router there.
If you want to change the default gateway, you can change the router Local IP address.
Make sure that it will be a private IP address only and not the public IP address.
suppose the current default gateway is 192.168.1.1.
You can change it to 192.168.x.y. X and Y will be the number between 0 to 254.
Click Here for more information about the routers and network
Jul 03, 2010 | NetGear DG834G Router
IP address for the router was changed to a number I do not know. Is there a way to get back to 192.168.2.1?
Is there any computer connected to the router with the cable ?
If not then you will need to connect the computer to the router.
Check the Ip address and default gateway. default gateway will be the current Ip address of your router.
Once you open the router set up page with the current IP address , you will be able to change the IP address of the router
Click Here for more information about the router and network
Jan 25, 2010 | Gateway Belkin F5D7230-4 802.11g Wireless...
When i type 192.168.2.1 it dosnt take me to the router set up page
connect the computer to the router and check the IP address on the computer. The default gateway will be the the number that will help you to open the router set up page.
If default gateway is 192.168.2.1 and still you are not able to open the set up, then try this way.
Click Start ==> RUN ==> in run type " http://192.168.2.1" and click OK.
I hope the following link will help you
click Here for more info
Nov 09, 2009 | Belkin (F5D5231V4-SN-PD) Router...
I cant seem to figure out what is the IP address for my MSI RG60SE router.....
By default ip address is 192.168.1.1
or
192.168.0.1
But if your ip is different and if in your router DHCP is enabled then you have to check your computer ip address with which your router is connect.
Go to start menu then type in run "ipconfig /all"
then check gateway ip it is your router ip.
Also you can check your ip wtih phone reciver connect your phone receiver to router with phone line jack.
Then press * so you can listen configuration.
Let me kow if you need more assistanse.
Thanks.
Sep 24, 2009 | Computers & Internet
Conflict with partner network detected.
Default password is "1234".
You need to set up a subnet that is different than the subnet your vpn is connecting to.
For instance, default on the 334is: 192.168.1.0/24 SO the router will have an IP of 192.168.1.1. Because of the error, the other network has that same subnet (192.168.1.0/24)
And that router probably has the same IP as your router (192.168.1.1)
So one of the networks needs to change. You could just change the IP on one Network to: 192.168.2.0/24 and the IP of the router to 192.168.2.1.
I would change them both though, so this doesnt happen again.
Apr 14, 2009 | Zyxel Prestige 334W Wireless Router...
Ip conflict
Click Start, Click Run, type in CMD and hit the enter key, type ipconfig /all after the > sign and then hit the enter key, this will give you the ip address of the computer, the subnet mask and the default gateway, the DHCP server and the DNS server. You can reset the computer's IP address by typing ipconfig /release in the CMD window then typing ipconfig /renew. BPCS
Dec 30, 2007 | Belkin (F5D6230-3) Wireless Router
Changed router ip now unable to connect...
hi, i have the same problem that cannot connect to router after i changed ip address... i set my network connection to ip address 192.168.254.2 & subnet mask 255.255.255.0 & default gateway to 192.168.254.254... i can ping ip address 192.168.254.254 but cannot get into the web browser... i cant go back the router configuration page... pls. help... my router is zhone 6218...
Dec 24, 2007 | Zhone (6218-I2-200) Router
Thomson Speedtouch St585 V6 Sl Wireless Modem Router Mbps 4-port 10/100 Logo
125 people viewed this question
Top Thomson Computers & Internet Experts
Raj Patel
Jim Drosdick
Wbix
Are you a Thomson Computer and Internet Expert? Answer questions, earn points and help others
