Question about GE Adora GHDA656LSS Stainless Steel Built-in Dishwasher
Dishwasher with one inch of water in bottom when complete
I have a three year old ge adora dishwasher and when the cycle is complete it still has one inch of water in bottom
  • 113 Answers
Undo the drain hose from your drain and put it in a 5 gallon bucket and see how it drains your sink drain maybe stopped up or if it drains into a disposal it may be stopped up
Posted on Apr 24, 2009
Our 3 month old ge adora dishwasher stopped working properly yesterday. Made funny noise and later I started smelling something burning. Opened it and noticed no water was in it. Restarted and still n
Sounds like the water inlet valve isn't working. Check your house water pressure and make sure it's not above 80 psi. If it isn't, then call a repair company that handles GE warranty work.
Dec 02, 2014 | GE Adora Dishwasher. Built-In Tall Tub...
GE Adora dishwasher model ddt575smf0es leaking from condensation
Sounds like a poor install. If the hoses aren't collected correctly heat from water could cause expansion therefore looser doors and hinges. Make sure the water connections are tight and then check the screws at the bottom of the door. you shouldn't need a pro to fix.
Feb 25, 2014 | GE Adora GHDA654LBG Dishwasher
Dishwasher is not draining properly. 1 year old
Check that there is nothing clogging the inlet to the pump below the strainer at the bottom of the machine and slowing down water getting to the pump. This will mean stripping down much of the bottom of the machine, but is unavoidable. Also check that the drain line is not blocked. If there are no problems there, the change over valve may be leaking and returning some of the water to the machine instead of draining it out.
Feb 01, 2011 | GE Adora GHDA656LSS Stainless Steel...
My GE Adora dishwasher is not cleaning well and the detergent isn't completely disolving. What could be the problem?
Mine has been doing the same thing for about 2 months now.. I tried Finnish brand diswasher cleaner, but to no avail. Try this:
1) Empty your dishwasher, then take out the lower rack.
2) Start a regular cycle. Wait until you hear the jets turning, then open the door. Make sure there is enough water in the bottom - It should be just UNDER the heating element.
3) If your dishwasher is getting enough water, Reset your washer and allow it to drain.
4) Go to the store and get a gallon jug of white vinegar. Start your dishwasher on a regular cycle.
5) Once you hear the jets turning, Open the door and add FOUR CUPS (liquid measure) of white vinegar to the water in the bottom. Let the wash cycle complete.
6) When the wash cycle drains, the rinse cycle will fill. Once the rinse cycle starts, add ANOTHER FOUR CUPS of white vinegar to the first rinse cycle.
7) Allow the first rinse cycle to drain. Let the second rinse cycle complete normally.
I know this sounds too good to be true, but it REALLY DID work for me, this evening as a matter of fact! I also bought some hard water/soap film detergent additive from the store. It was kind of expensive, but I'm using it for a while just in case.
I hope this helps. Like I said, I couldnt believe it when my dishes came out clear again! Also, I turned OFF the heated dry cycle, and just opened the door and pulled out the racks when it was done.
Good Luck!
Mar 30, 2010 | GE Adora GHDA654LBG Dishwasher
5 yr old GE Adora -- have it repaired or replace?
look in the back and make sure the drain hose is about 18 ins high if the hose falls it will not hold the water in the machine
Feb 10, 2010 | GE Adora GHDA656LSS Stainless Steel...
Will not complete a cycle
Very likely a bad timer switch.
Fortunatly, they are fairly easy to replace.
Just make certain you plug in all of the connectors that came off the old one into the same places that they cam off the old one.
Oct 27, 2009 | General Electric Adora GHDA670N Built-in...
LEAVE MORE WATER THAN SHOULD BE
There is a drain hose that runs from your dishwasher to underneath your sink. (usually connects in right below the drain spout)
It sounds like this may have become clogged, or the sink drain is clogged causing the water to back-up in to the dishwasher drain hose.
Mar 20, 2009 | GE GLD5800L Dishwasher
GE NAUTILUS GSD3200-J00WN DISHWASHER WON'T COMPLETELY DRAIN
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Dec 27, 2008 | GE Profile PDW9880NSS Stainless Steel...
Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
GE Adora GHDA656LSS Stainless Steel Built-in Dishwasher Logo
725 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
