Question about Bosch WAS24460UC Front Load Washer
Liquid detergent WVH28360GB - Bosch WAS24460UC Front Load Washer
What type of detergent is best liquid or powder
Liquid detergent is better for all washing machines.
Apr 22, 2016 | Miele Washing Machines
Whirlpool commercial duty washer - liquid detergent
Jenny what do you mean by 'flow right out of the compartment'. IF the detergent flows right into the machine as you pour, it ok.
Jan 05, 2014 | Washing Machines
I have a front loading Kenmore washer and when i put liquid detergent and fabric softener, the liquid flows into the machine - should the detergent and fabric softerner remain in their compartements until...
Yes the detergent and softener will stay in the dispenser drawer until the correct time for them to be dispensed. The detergent is dispensed during the main wash cycle and the softener will not dispense until the rinse cycle
Jul 26, 2011 | Kenmore Washing Machines
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Can liquid detergents be used in a dishwasher?
Only dishwasher detergent can be used in a dishwasher. Some of them are liquids. Regular liquid detergents such as dish detergent or laundry detergent is too sudsy and it will make so many suds that they will be all of the dishes and the floor if used.
Mar 03, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Do I put powder detergent in the same place I put Liquid detergent?
Detergent compartment
Add liquid or powdered detergent to this compartment for your
wash cycle. The detergent separator must always be in place,
either in the front or back position.
 Do not fill beyond the “MAX” level.
 Liquid or powdered color-safe bleach may be added to the
Main Wash compartment along with the same type of
detergent, liquid or powdered.
 Liquid detergent: Put the SEPARATOR in the front position,
between the guides, as shown as shown by Position 1 below.
There will be no gap between the bottom of the wash cycle detergent
compartment and the bottom of the separator.
Powdered detergent:
Put the SEPARATOR in the back
position, behind the guides as shown by Position 1 below. There will be
a gap between the bottom of the wash cycle detergent
NOTE: The separator will be in the POWDER (back) position
when shipped from the factory.
Nov 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Which detergent for Haier HNS1260 washing machine.
Yes you can use liquid detergent, If your's is a high effeciency machine, use HE detergent. It cleans as well, but makes less suds, which can cripple a front loader. Alternative HE detergents can be made at home,if you're interested. They can be either liquid or dry. You can find the recipes on YouTube, with the search set to "Homemade Laundry Detergent". We make the dry version, and it works better than anything we can buy. It costs us .02 cents per load.
Back to your question, though. If you intend to use liquid detergent, look into your dispenser and see if there is a moveable divider that you can change for liquid or dry detergent dispensing. Set it to the appropriate setting if it does. If not, use very little detergent, and you may have to add it directly to the load, skipping the dispenser altogether. Another thing that you might consider is that, if you ever have to have any warranty type work done, and the tech discovers that you have used liquid detergent, they will want to void your warranty.
Best regards, --W/D--
Aug 20, 2009 | Haier Washing Machines
LG 2277 Liquid Detergent Box & Insert
please put detergent into the main(left) side of the dispenser
Feb 15, 2009 | LG WM-2277HW Front Load Washer
Detergent drawer
I ended up having to call Samsung support for this same question. Left to right two vertical bars = detergent (liquid or Powder) flower = softner, single vertical bar = bleach.
Oct 19, 2008 | GE Energy Star WCVH6260F Front Load Washer
MALBER WD 1000- CAN I USE LIQUID BLEACH?
Liquid detergent and liquid bleach are best.
Aug 21, 2007 | Malber WD1000 Front Load Washer/Dryer
Bosch WAS24460UC Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
