Hello..i have kolin split type aircon and the remote control is missing..is there a replacement for remote control? I cant use the aircondition cause it is set to 25degrees...
  • 400 Answers
SOURCE: WATER LEAKING FROM MY SPLIT TYPE LG AIRCON
1. Do not set the aircon too low temperature in overcast weather, this will cause ice ups and water dripping. Optimal comfort zone temperature is 24c.
2. You need to open the grill cover on the front of the aircon which unclips either end left and right with a finger pressure. You will find two filters which can slide out and should be cleaned. First tap them together to remove dust, then you can wash them with mild soap and cold water.
3. There is the third possibility that an insect has made a nest in the drainpipe. You should look on the outside of the building and locate a plastic drainpipe. You can either blow into this pipe with your mouth or get a blower. This will unblock any restriction in the drainpipe.
Goodluck and ratemeplease.
Posted on Mar 19, 2009
  • 588 Answers
SOURCE: My KOLIN window type remote control AIRCON is building up ICE
If you already had the coils and filter cleaned and the blower is OK, that only leaves the refrigerant charge.
You are probably low on refrigerant.
Posted on Aug 25, 2009
SOURCE: MITSUBISHI ELECTRIC'S AIRCON REMOTE CONTROL ICON
lock out controllers
Posted on Oct 20, 2009
raulcvalenzu
  • 11 Answers
SOURCE: Kolin window type aircon shuts off by itself
a wiring connection in cotrol of on / off are malfunctioning
Posted on May 27, 2010
SOURCE: need a conia airconditer remote control here in
i had the same problem and i managed to find a universal remote control from JARCAR Electronics. Model of the remote: Digitech AR-1729. It doesn't list Conia as compatible but I managed to gain control of the aircon using the code: 291. For some reason when you press the power button on the remote, it's like your double pressing the on button so the aircon switches on and off quickly. You need to press the power button on the remote quickly and move it from reception before it powers down the unit again. At least I have control of the aircon again and I don't have to put up with these humid hot days in melbourne... Good Luck.
Posted on Jan 12, 2011
Kolin inverter window type aircon shut down with FO code
when you post the same question more than once in a few hours most here tend to ignore them. once is enough. when someone who knows the answer comes on maybe youll get lucky.
Jan 28, 2018 | Inverter Heating & Cooling
I have an split-type aircon (brand: Fukitsu) remote control AR-DL2. it has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift indoor unit cover and remove DC wire from display sensor. After 3 minutes again plug it and close the door. Now you try with your remote. If still problem, check your remote through cell phone camera by pressing any button in remote. If ultra light is visible thr' camera, remote is o.k. If remote is o.k, repair/replace PCB. Thanks.
Feb 09, 2011 | Heating & Cooling
I have an split-type aircon (brand: General) remote control AR-DL2. it has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix...
i have general electronic ac brand i cant found universal remote can u find one for me what are the universal remote that compatible for my ac tq
Nov 29, 2010 | Heating & Cooling
Need remote for a v-lec split type air conditioner
Why not try the dealer selling V - lec aircon? They are
in the best position to know where to get the replacements or clone remote controller for your unit.
Better still try surfing the internet, V-lec Aircon may have
a web site to service their clients. May this info, help you.
Jan 06, 2010 | Heating & Cooling
Need a conia airconditer remote control here in Australia. We have 2 split systems that use the same remote. Models CA 24003 & CA 3003. Conia have gone bust here and we can't get a replacement remote....
Jan 01, 2010 | Heating & Cooling
Jul 26, 2009 | Heating & Cooling
Remote control not functioning
is the remote lit up if so it maybe the sensor on the wall unit cant communicate with each other like a tv remote
Apr 28, 2009 | Heating & Cooling
This may be due to the size of the room. The master bedroom may be smaller than the living room? The unit is therefore reaching setpoint temperature and cycling (shutting off)? Or it could also be a faulty thermostat.
Jan 23, 2009 | Heating & Cooling
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
