Question about Krups 888 Centro
My new smeg coffee and cappucino maker displays the message '' GROUND TOO FINE ADJUST MILL - I have done this and delivered water thru the cappucino maker as per problem page in manual but still the machine will not do anything.
  • 298 Answers
SOURCE: Coffee does not brew
If you are elictrically inclined you
could take it apart and jump
across the switch with a jumper
wire or whatever avaialable means
see if it works all the time
thereby proving the switch to
be defective
Posted on Dec 07, 2007
  • 3 Answers
SOURCE: filter coffee side does not work
I returned the coffee maker at the manufacturer's suggestion
Posted on May 12, 2009
SOURCE: On FME4 coffee maker the error message CALC
it means de"CALC"ify its detecting calcium build up the manual says to run white vinegar without the filter followed by two clean water cycles goto krups.com to download the manual
Posted on Dec 20, 2009
  • 39 Answers
SOURCE: Krups XP2070 coffee machine -
This will most likely happen when the pressure valves become defective. Replacing the two valves (they come in pairs) should fix the problem.
Posted on Dec 29, 2009
SOURCE: Message on Display
Maybe your electric hot water valve that let the water out of the stream wand is blocked. Remove the top and right hand sides covers and you would notice a sliver color metal valve mounted on a white plastic frame. Remove it out of the unit and clean the clear tubing fittings. At least on my unit, the nozzle inside the fittings is blocked with green deposit.
Posted on Mar 17, 2010
Ground too fine adjust mill comes on about every other cup.
With any coffee grinder (especially those that are used for espresso) the burrs can wear down after a while. It seems like you've used this machine quite a bit and for various different types of coffees. If your machine is still covered by the manufacturer I would suggest contacting them about the problem or call your local specialty coffee shop. They normally have or know of a guy that can fix this rather simple problem for cheap. Happy brewing!
Sep 03, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Empty circuit fill circuit insert water spout press ok
when inserted the water spout if the water is delivered,that means you have an issue with the flow meter and you have to tack it to maintain,
how ever if the message (fill circuit ) turned off after the posses of filling the circuit and when you are trying to brow coffee the message shows, that means the grinder is too fine adjust it and try ones more
Apr 12, 2015 | DeLonghi PrimaDonna S Deluxe Super...
Why is my coffee weak?
If it is a drip maker, only gravity drives the hot water thru the coffee grinds. If the coffee is ground too fine, it immediately packs up and doesn't let water flow thru it and the water flows around the coffee instead of thru it.
Try using a coarser grind, and if not you can use a lot smaller amount of coffee and water. A smaller amount of coffee is easier to diffuse thru than a large amount.
Another thing is to slow down the water speed entering the coffee basket. I found the best way to do that is to use water just above freezing and place that extra cold water in the reservoir. The cold water takes extra time to be heated up by the coffee maker so less water is released over the coffee grinds per minute.
If your coffee maker overflows a lot, that is a good indicator that the grind is too fine and/or your coffee filters are too flimsy and are plugging up the channels in your coffee basket and the coffee can't enter the flask, so it overflows.
But the easiest way to check out your coffee maker is to use extra cold water and just run half batches (5 cup) of coffee instead of 10 cup
Feb 25, 2015 | Coffee Makers & Espresso Machines
"GROUND TOO FINE ADJUST MILL! Insert water spout
  1. Insert steam spout and push OK.
  2. Fill your tank and add descale solution.
  3. Go to program settings - Descale.
  4. Follow the prompts on the readout.
  5. After descale and rise are complete refill your water tank.
  6. Your system should now work as normal.
Note: If you do not have a descale solution, run the above with just water. Remember to descale when you obtain a descale solution.
Sep 27, 2013 | DeLonghi Perfecta ESAM 5600 Espresso...
Have a delonghi Prima Donna 6700 coffee machine and get this message
Hi there coffee person.
Have you tried disconnecting the machine from the power supply. As well as that check if there are enough coffee beans in the bean in the compartment and enough fresh water in the water tank. Not only this but is the compartment with the coffee "tablets" - full or empty. Fill or empty accordingly. Connect to power again, if the machine does not work the only advice have from here is "to clean the machine" as described in the manual or as you are used to.
Good luck
kolbrun
Mar 03, 2012 | DeLonghi Prima Donna Avante ESAM6700...
How do I clean my burr mill (Models BMX3, BMX4, BMX5 and BMX6)?
Clean your burr mill before using it for the first time. Then, to ensure optimal mill function and durability, clean it regularly following these simple steps.
  1. Always unplug your burr mill after use and before cleaning.
  2. Open the hopper lid. Empty any whole beans from the hopper. Remove the top burr mill by rotating it clockwise. For better results hold the grind setting button while rotating the burr mill clockwise. This will allow you to clean the grinding wheel and the grinding compartment.
  3. Clean the interior recesses with a soft brush. Note: Never use water or liquid for cleaning the lower grinding section of this appliance. BRUSH NOT INCLUDED.
  4. Wipe the whole bean hopper, its lid and the mill exterior with a damp cloth.
  5. The ground coffee chamber and lid can be washed in mild detergent and water. They both are top rack dishwasher safe. Do not immerse the mill or the whole bean hopper in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  6. After completely drying the whole bean hopper and top burr mill, replace the burr mill in position by aligning snaps with receptacle and rotating counterclockwise to lock it in position. For better results, hold the grind setting button while rotating the burr mill counterclockwise. Once the burr mill is in position, pull gently to check it is properly locked in position. If the burr mill comes out, repeat this step again.
  7. Replace the ground coffee chamber and lid, making sure both snap securely into place.
  8. Fill the hopper with whole beans.
Sep 02, 2011 | Bunn NHB Coffee Maker
Krups 888 Centro Logo
50 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
