Question about DeLonghi EAM3400 Espresso Machine
Water not being pumped through machine , everything else sounds right , but loud vibrating noise, machine gets very hot on top, and no water being taken through
3 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: water compartment loud sound
The pump might have fallen of the rubber supports in shipping. No it is not normal for it to make too loud of a noise when getting water. There should be a small amount of vibrating but not overbearing.
Posted on May 17, 2009
mnwarfield10
  • 452 Answers
SOURCE: water will not pump through machine or deliver
ring 07779933829 we repair
Posted on Jan 25, 2011
Why is My cimbali 21 s junior is making a loud noise when turn on
The La Cimbali Junior is a 1 group professional espresso machine. Most are located in restaurants that want to serve a cup or two for customers. You will find few homes with this level of machine. Especially with the proliferation of "Mini Super-Automatics" now offered where the whole been is ground, measured, compacted, and served with exacting amount and some top off with frothed milk!
The JR has several items that will normally buzz or whine when in operation. There are also defined "Clicks" of the group valve when a shot is pulled. I will go through the list of likely components that make loud noises when about to fail.
*** The following is for information only! Call your vendor for service as there are dangerous voltages, high pressure, and scalding stem present in these types of professional machines. ***
* All JR's come with a water pump. Two types; Vibration and Rotary. The vibration makes a buzzing sound (50/60 Hz) which will get loud if there is a blockage. The rotary pump with it's accompanying large motor will also "Clack" if no water is flowing through. Stop immediately as both sounds are an indication of a straining pump. If it suddenly goes quiet then the pump is damaged or hopefully the fuse blew. Call for service.
* The group valve will usually buzz when pulling a shot. But if it's louder than normal then there is a problem with the valve (clogged) or coil (shorted). Call for service.
* If there are loud blasts of steam and a quiet period with another blast in about 10 mins. Then the boiler is over heating (runaway steam). Unplug and call for service.
* If there is constant steam blast from the top, even if it's turned off (But NOT unplugged) the element is shorted to water. Unplug immediately and call for service.
* Popping sounds are normal at start up as the metal boiler expands during initial heating. But not after 10 mins of heating. Especially if you see water/steam coming from parts of the machine you don't expect. Unplug. Call for service.
* Power/Heater contactor will buzz if coil is damaged or contacts burnt. Call for service.
* Final; I do not recommend opening the machine yourself as once you hear a loud noise it's usually too late and the damage is done.
* Parts that needs check/replacement; Vibration or rotary pump, motor, group valve, safety valve, vacuum valve, thermostat/pressure-stat, element, boiler and element gasket, contactor.
Aloha, ukeboy57
Aug 26, 2014 | La Cimbali Junior Casa DT1 Espresso...
Loud drilling noise when coffee switch is turned on - rather than the usual purring noise - and no coffee delivery either
How old is your machine ? and what maintenance have you done over time such as replacing the shower curtain located at the pourring end of the hot water ? I had too very loud noise coming occasionnally from the stainless steel rack holding the cup while coffee is delivered. If your ground coffee is too fine it will stop flow during making a shot. Is water coming out when no coffee is placed in the portafilter.The water pump on this machine is a cheap pump that has to be replaced over time. Mine is 7 years old and has delivered four cups of expresso everyday of the year, and still working.3841c994-fb4b-459f-8d1f-710e0aafc3c0.jpg 2ead4f70-37c6-4236-a9c2-992dba149c4c.jpg
May 29, 2014 | Rancilio Silvia Espresso Machine
Lound vibration when running
Check gas control valve.
Good luck,
Marty
Feb 18, 2013 | Rinnai Water Heaters
Sudden loud vibration from the door of my Whirlpool dishwasher. Replacing the part didn't help.
see this causes and fix it. God bless you
Drain Pump If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 28, 2012 | Whirlpool Dishwashers
Loud noise on spin cycle
most common cause for this is pump bearing on water pump. remove belt and attempt to turn pump by hand. if it grinds get a new pump.
Oct 08, 2009 | Maytag PAV2300 Top Load Washer
Water compartment loud sound
May 16, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
My r85 rinnai water heater vibrates significantly and makes
Sounds like there is something loose in the line.Like cut off valve,check valve.
Mar 09, 2009 | Rinnai Digital Remote Water Heater Control...
93 Celica getting Hot
Sounds like your water pump may be going out.If the fan is mounted on the water pump,grab the fan on each side and try to wiggle it.If it moves side to side any its bad.
Jul 11, 2008 | 1993 Toyota Celica
Open Questions:
See all DeLonghi EAM3400 Espresso Machine Questions
DeLonghi EAM3400 Espresso Machine Logo
14 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
