No site configured at this address - Computers & Internet
Reset IP HP2015DN
Hi, not sure why this is coming under the router section. You'd need to post a little more information about the problem. Is it with the IP address settings on your router or those wirthin the printer itself. If its
the printer itself - the problem solution is available here possibly.
But Google Resetting the IP address on
HP2015DN
Details To open the HP Embedded Web Server, type the IP address or hostname of the printer in the address field of a supported Web browser. To find the IP address, print a Configuration page from the control panel of the printer by pressing and holding the Go button for 5 seconds. The HP Embedded Web Server URL can be bookmarked for quick access at a later date. Supported web browsers include the following:
  • Internet Explorer 6.0 (and later)
  • Netscape Navigator 7.0 (and later)
  • Firefox 1.0 (and later)
  • Mozilla 1.6 (and later)
  • Opera 7.0 (and later)
  • Safari 1.2 (and later)
  • Konqueror 3.2 (and later)
The HP Embedded Web Server has the following three tabs that contain settings and information about the printer:
  • Information tab
  • Settings tab
  • Networking tab
Once the HP Embedded Web Server opens, perform the following steps to configure a static IP address:
  1. Click the Networking tab.
  2. Click Network Settings under Configuration in the left menu bar.
  3. Click the TCP/IP tab.
  4. Use the drop-down menu to change the IP Configuration Method to Manual.
  5. Type the new IP Address in the box to change the IP Address .
  6. Change any other applicable networking information, if applicable.
  7. Scroll down the page and click Apply .
  8. Click OK on the confirmation screen and then close the browser window.
  9. Wait a few minutes and then print the Self Test/Configuration page and the HP Jetdirect Configuration page to verify that the IP Address has changed.
Dec 03, 2013 | Computers & Internet
I CANNOT OPEN OR SEND EMAILS
  1. Cannot send email but able to receive
    Typically, POP based email accounts have the same address for incoming and outgoing email servers. However, sometimes the email service provider might have a different outgoing email server which has a different username and password (next point). Please check with your provider for details if you cannot send email but can receive.Is the outgoing email server address correct?
    The outgoing email server (SMTP) address needs to be correct for you to send messages from the account. You can find this information in the email you have received from your web host.
    The outgoing email server address would typically be based on your web site's address, unless the server has been configured differently. Thus, if your web site's URL is www.my-web-site.com, the outgoing email server address would be either my-web-site.com or mail.my-web-site.com (substitute my-web-site.com with your actual domain name).
Apr 26, 2011 | Acer Computers & Internet
I just configured my MFC 490cw for wireless printing. It works but now I have IP address conflicts across all computers XP & Windows 7) and X-box in the house. If I turn the printer off, the network...
When configuring an address for the printer, the IP configuration might look like (just an example):
IP Address - 192.168.1.2
Subnet Mask - 255.255.255.0
Default Gateway - 192.168.1.1
It's important to note that even though you are not using any IP addresses in the default range for DHCP, the Subnet Mask and Default Gateway addresses will be THE SAME.
If you have another device on your network that will be assign a fixed address, you would use for example:
IP Address - 192.168.1.3
For any other devices, just increment the IP address by one, 192.168.1.4, 192.168.1.5, etc and use the same Subnet Mask and Default Gateway.
(see the owners manual or site for steps on configuraing the printer TCP/IP information). This should take care of any conflicts.
Jan 29, 2011 | Brother MFC 490cw Color Inkjet...
How i know the IP address assgined to the print server? once this how can I change it?
According to this site http://www.argecy.com/xtnd100s.html it it supports the use of HP's JetAdmin/Web JetAdmin utility which will allow you to configure the IP address as well as other features.
"Features such as full support for HP JetAdmin/Web JetAdmin"
Utility located here:
http://h20338.www2.hp.com/Hpsub/cache/332262-0-0-225-121.html
That same site also has this information about the ExtendView utility which may help you as well.
TROY LAN Administration Tools
  • ExtendView - 32-bit utility allowing most versatility and functionality available in network printing. Ability to view and configure print servers from unlimited number of views and quick and easy Windows IP address assignment are 2 key benefits. Features such as bulk configuration allow configuration changes for multiple print servers with simple steps. Save and restore feature allows a standard configuration to be saved and later recalled to restore same configuration
  • WebView - web based configuration tool allows complete status and configuration changes simply by typing the print server's IP address into a standard web browser
  • NetworkAlert - specialized Windows printer error utility providing proactive notification of printer problems through the use of SNMP traps
  • ExtendNet Connect - serverless (peer-to-peer) printing for Windows 95/98. Excellent tool for small businesses and remote offices
  • ExtendNet Connect NT - performance enhanced port monitor helps to improve the speed of data flow to the printer
Dec 22, 2010 | Troy ExtendNet 100s Print Server
Diffrent between Dynamic&static ip address
Static IP address is usually a single IP address provided by the ISP to you, which can be configured so that you can run a web server (host web sites etc), or access your home computer from any where in the world ( your computer and internet should be on ).
Dynamic IP address is usually IP address provided by the ISP to your DSL modem / computer (for dialup modems) for that internet session, next day or next time you connect the IP address will be a different one. (usually home internet connections are Dynamic IP based.
In a typical home environment if you have one wireless adaptor and planning for a wireless repeater its better to configure dynamic IP address in the repeater (so that you repeater will acquire IP address from the wireless adaptor)
Dec 09, 2010 | Computers & Internet
How to routing router static ip address and local
Use the Sonicwall configuration wizard..
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
Apr 22, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
Cant find my routers Gateway Site..?
First you must make sure that the Ip address 192.168.2.1 is your routers ip address.
Click on Start, Run, type cmd, then click OK. Type ipconfig /all and hit the enter key. You are looking for the Default Gateway address. Use that address in your web browser. When you set up your static Ip address on your computer, use the first three numbers of your default gateway's address, then for the fourth number, add one. For example. If your default gateway address is 192.168.2.1, then your static ip address should be 192.168.2.2.
Try this and let me know what happens.
May 31, 2008 | Intellinet Active Networking Intellinet...
192.168.0.1 site
First have you assured through the documentation that the default address for the configuration is 192.168.0.1. Second some routers require a secure connection to get to the configuration such as https://192.168.0.1 Third you can check to see if someone changed the gateway address by using the Command Prompt or the DOS Prompt and typing ipconfig and pressing enter. Look for the default gateway address it will probably be 192.168.?.? if it was changed and the 192.168.? part will match the IP Address assigned to the machine. If you still cannot get access to the configuration AND YOU UNDERSTAND HOW TO COMPLETELY CONFIGURE YOUR ROUTER; check out the users guide for instructions for resetting the router's contents -- this will WIPE OUT THE ENTIRE CONFIGURATION IN YOUR ROUTER and reset the routers configuration to the factory defaults. THIS COULD WIPE OUT USERID AND PASSWORD SETTINGS THAT ALLOW THE ROUTER TO ACCESS THE INTERNET. Only consider reset on the router if you fully understand what you are doing and how to reconfigure the router appropriately.
Thanks
Dec 03, 2007 | NetGear WGR614 Wireless Router
Open Questions:
Cloud storage and file storage - DataAlign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Online Cloud Backup technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Computer Data Backup is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Business Server Data Backup up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jul 20, 2018 | Quantum Computers & Internet
Computers & Internet Logo
David Payne
David Payne
