Question about Measuring Tools & Sensors
What are fiber-optic leak detectors? - Measuring Tools & Sensors
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
  • 24 Answers
These are leak detectors that fiber-optic cables that run the full length of the pipes that you want to check for leaks. They work by measuring the changes in temperature of the cable when it comes into contact with the substance that is in the pipe. This gives you a really acurate reading of where the leaks are.
Posted on Oct 13, 2013
Can 10GE Optical Interfaces of a Switch Work upon a Unidirectional Fiber Connection?
10GE optical interfaces of a switch cannot work upon a unidirectional fiber connection. A unidirectional fiber connection occurs between two 10GE optical interfaces when one interface is Down because the Rx fiber is removed, while the other interface is still Up because its Rx fiber can receive link_Up signals from the PHY layer.
A switch determines the status of a 10GE optical interface according to the IEEE 802.3ae standard. As defined in this standard, the MAC layer of a 10GE optical can send local_fault and remote_fault signals. A switch can determine the link status based on only the link status of the PHY layer or based on the link status of the PHY layer and the local_fault and remote_fault signals from the MAC layer.
On a Huawei switch, link status of a 10GE optical interface turns Up only when the link status of the PHY layer is Up and both the local_fault and remote_fault signals are 0. When two 10GE optical interfaces are interconnected and the Rx fiber on one interface is removed, this interface goes Down and the MAC layer of the interface generates a local_fault signal. Meanwhile, the local interface sends a fault signal to the remote interface through the Tx fiber. The remote interface receives the link_Up signal from the PHY layer and the remote_fault signal from the MAC layer. Therefore, the link status of the remote interface goes Down.
S2300 Switch Thunder link com
Jan 22, 2017 | Huawei Computers & Internet
Tip
What is fiber optic connectors ?
The fiber optic connectors is the removable (active) device connected between the fiber optical cables, make the two optical fiber end face precision to dock, so that the output light energy of transmitter optical cable can be maximize coupling to the receiving fiber cable. And make sure its impact can be minimized because of its involvement in the optical link system , which is the basic requirements for fiber optic connectors. To a certain extent, fiber optic connectors also affected the reliability and the performance of fiber optical transmission systems.
Fiber optic connector according to the different transmission media can be divided into common silicon-based optical fiber single-mode and multimode connectors, as well as other issues such as plastic and as the transmission medium of optical fiber connector; connector structure can be divided into: FC,SC, ST, LC, D4, DIN, MU, the MT and so on . The ST connector is usually used to the end of wiring devices, such asfiber optic patch panels, optical transceiver; SC and MT connector typically used for network equipment side. Fiber end shape in the FC, PC (including SPC or UPC) and APC; divided by the number of the fiber core as well as single and multi-core(such as MT-RJ) points. Fiber optic connectors are widely used variety. In practical applications, we generally in accordance with the different structure of the fiber optic connector to be distinguished.
on Mar 30, 2012 | Computers & Internet
What is the difference between GPON B+ and C+ GPON transceiver?
B+ Module C+ Module Type One-fiber bi-directional optical module, class B+ One-fiber bi-directional optical module, class C+ Operating Wavelength Tx: 1490 nm
Rx: 1310 nm Tx: 1490 nm
Rx: 1310 nm Encapsulation Type SFP SFP Port Rate Tx: 2.49 Gbit/s
Rx: 1.24 Gbit/s Tx: 2.49 Gbit/s
Rx: 1.24 Gbit/s Minimum Output Optical Power 1.50 dBm 3.00 dBm Maximum Output Optical Power 5.00 dBm 7.00 dBm Maximum Receiver Sensitivity -28.00 dBm -32.00 dBm Optical Connector Type SC/PC SC/PC Optical Fiber Type Single-mode Single-mode Reach 20.00 km 20.00 km Overload Optical Power -8.0 dBm -12.0 dBm Extinction Ratio Huawei GPBD Board Thunder link com
Nov 02, 2016 | Computers & Internet
How to get optical to work
You hear about fiber optic cables whenever people talk about the telephone system, the cable TV system or the Internet. Fiber-optic lines are strands of optically pure glass as thin as a human hair that carry digital information over long distances. They are also used in medical imaging and mechanical engineering inspection.
In this article, we will show you how these tiny strands of glass transmit light and the fascinating way that these strands are made. Fiber Optic Patch Cables
May 01, 2014 | Hitachi 43UWX10B 43" Rear Projection...
Fiber optic plug does not connect
Optical fiber connectors need to be clean in order to work properly, they need some special cleaning tools, you have to ask for them at the electronic store, normally you should avoid disconnecting and reconnecting fiber optic connectors a lot.
Apr 05, 2014 | Samsung HT-Q100 System
Fiber-optic networking
Apply load balancing of the NIC interface, else put in a switch to interconnect all the computers. That should give equal speeds to all the PC's.....sodeep
Apr 06, 2009 | Computers & Internet
Fiber cable running through a steam tunnel
use UTP cable to replace a fiber cable
Dec 05, 2008 | Seicor Fiber Optic Cable
Fiber module
you can login though the console cable, switch back side conso;e port will be there, it will bw like RJ 45 port
May 10, 2008 | 3Com SuperStack 3 4400 (3C17204-US)...
Need fiber optic input jack for Onkyo TX-DS575
Had it ever worked, or are you setting it up for the first time?
Have you ASSIGNED the digital input in the menu?
Dec 18, 2007 | Onkyo TX-DS575 Receiver
Measuring Tools & Sensors Logo
1,204 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
