Question about HP iPAQ RX1710 Pocket PC
The pocket pc does not start up
The machine does not start up. I did both soft and hard reset but when it boots up it comes to the screen alignment stage and does not respond from there. I kept tapping th screen at various points in response to the screen message but it does not proceed any further from this stage.
  • Anonymous Apr 07, 2008
    Have the same problem. When I turn it on, it shows the reboot screen and it is stuck there. I try to reset it and take the battery out to reset, it takes it a long time to reboot and never goes into the regular screen so I can use it.
  • chezyg Jun 28, 2008
    i have the same everytime i turn it on the the aligning screen it will not let me go any further. have you manged to get it fix or knew what the problem was?
  • HP Master
  • 5,095 Answers
It's broken, get it fixed ! (omg labor costs huge)
if wanting to spend huge cash on something worth
$1 dead or $5 working right, (I see these for $1 at goodwill)
then buy new batteries first. All have a big one and some a well hidden tiny one inside, and both are bad this old for sure.
ever seen a 14 year old battery work, ? that is the age now.
2018, why thing any battery lasts that long.?????
Posted on Feb 23, 2018
SOURCE:
  • 17 Answers
SOURCE: imate jasjar
It sounds like your ROM image is corrupted somehow, reprogram the rom image. You can download an Win Mobile 5 image from www.clubmate.com or try www.xda-developers.com for cooked roms. Read the installation instructions carefully and you shouldn't have any problems.
Posted on Sep 13, 2007
  • 17 Answers
SOURCE: Describe your i-mate JASJAR Smartphone Problem:
It sounds like your ROM image is corrupted somehow, reprogram the rom image. You can download an Win Mobile 5 image from www.clubimate.com or try www.xda-developers.com for cooked roms. Read the installation instructions carefully and you shouldn't have any problems.
SOURCE: Ipaq RX 3115 Stops at align Screen
alright thank you.
Posted on Dec 03, 2007
  • 5 Answers
SOURCE: HP Ipaq rz1710
Have u recharged it????
try to reboot it. there is a small hull in the bottom on left side, push in it with the pin u have tp your PDA. that will reboot the system
Posted on Jan 04, 2008
  • 5 Answers
SOURCE: imate pda2k pocket pc shows align screen
go to start, setup, system, screen, and then click align screen. and then it will give u some small circles to tap on it. u tap correctly on the circles. after few clicks it will automatically tell u that ur screen has been aligned. ur problem is solve by a cute pakistani. pakistan live long. love u.
Posted on Feb 05, 2009
Cant switch fone on, its saying align screen all the time very gratefull for your help
Hi, if you havnt tried the soft reset, you can try that. If that doesnt help you can do a hard reset.
Hold down the power button and then use the stylus to press the soft reset button on the phone.
Thank you.
Dec 09, 2010 | i-mate JAM Pocket PC
I have an imate pda2k pocket pc and is working good. Out of curiosity i tried hard reset and it ends to align screen. Everytime i made a hard reset the screen show " tap the screen to setup your pocket pc"...
tap and hold on align target until it moves to next corner or next step, if you are using windows 6 or 6.5 you should be very much accurate on taping and holding to align the screen.
Nov 01, 2009 | i-mate PDA2k Pocket PC
Asus p320 Wont Boot anymore! help :(
Try this
"do hard reset:Press Right Soft Key and tap Reset at the same time, then please first release reset and hold the Right Soft Key, After P320 is powered-on , clean boot prompt picture will show on screen.Currently, you can release Right Soft Key. Follow the dialogue’s message, you can press “SEND key” to start clean boot or press “END key” to cancel clean boot.
Sep 10, 2009 | Dell Axim X50v Pocket PC
Hp ipaq rx5935 hangs at the end of the HP booting sequence
remove battery for 6 hr and reinstal and then hard reset.
bob.
Jun 20, 2009 | HP iPAQ rx5935 Travel Companion Pocket PC
Screen align problem
try to do hard reset if its not works
try to update rom image
if still not works try to replace your touch screen to new one
Dec 15, 2008 | HP iPAQ H3950 Pocket PC
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Resetting the Device
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
Performing a Soft Reset
A soft reset stops all running applications, but does not erase any
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
To perform a soft reset:
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
2. Use the stylus to lightly press the Reset button.
The Pocket PC restarts and displays the Today screen.
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Oct 16, 2008 | Computers & Internet
Imate pda2k pocket pc shows align screen
Oct 06, 2008 | i-mate PDA2k Pocket PC
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
Sep 27, 2006 | HP iPAQ RX3115 Pocket PC
Netbook pro won't startup
Go to netBookPro boot menu as follows: Whilst the splash screen comes up insert a paperclip in the tiny reset hole near the enter key, then press Ctrl + D +Esc(On). Now the netBookPro boot menu should come up, then select the option : !) Clean start main OS (just press Shift +1). Now you should get a reboot with the initial OS-settings. I experienced the same problem after running xclkcfg.exe (an overclock utility for the Sigmarion III ) so best stay away from this utility. have fun Rob.
Aug 08, 2006 | Psion NETBOOK PRO 3000 Pocket PC
Open Questions:
See all HP iPAQ RX1710 Pocket PC Questions
HP iPAQ RX1710 Pocket PC Logo
41 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
