Question about Pramac Towable Diesel Generator 219 kW, Perkins Engine, Model
I need a diagram of the perkins kd50316j 3 cylinder head torque settings
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: perkins 3 cylinder powered pramac generator
Start looking at your safety circuits.
1. High water temp
2. Low Oil
3. Low water etc...
From the manual these are the protection circuits.
• Engine protection: low oil pressure, high engine temperature.
• Genset protection: under/over voltage, overload, battery charger failure, battery voltage out of limits,
under/over frequency, start failure.
• Circuit breaker protection: IV poles.
• Differential protection.
Any one of them will trip the fuel relay closed. What you may be able to do is disconnect one at a time each protection circuit and see when the fuel relay opens. (Make sure to reconnect each one if it had no effect on the fuel solenoid)
Once you isolate which circuit it is in then you can chase wires or change the bad switch.
Thanks for choosing FixYa.
Kelly
Posted on Jun 26, 2010
Need head bolt torque specs for a 1996 saturn sl
Quote:
Originally Posted by norvelplagbao52
1993 saturn sl2 1.9 dohc cylinder head torque
specs and sequence
Cylinder head bolt
tightening procedure:
CYLINDER HEAD BOLT TIGHTENING SEQUENCE:
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
torque the cylinder head bolts. Torque: 30 Nm (22 ft-lbs).
In sequence,
torque all bolts. Torque: 50 Nm (37 ft-lbs)
In sequence, turn each bolt an
additional 90 degrees.
specs and sequence
Cylinder head bolt
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
In sequence,
Sep 19, 2013 | 1996 Saturn SL
Looking for wiring diagram for a Massey Ferguson 35 with 3 cylinder perkins diseal
You might look through these images:
https://www.google.com/search?q=1961+Massey+Ferguson+35+wiring+diagram&ie=utf-8&oe=utf-8&client=firefox-b-1-ab
Feb 18, 2018 | Toys
Installing a used engine in my boat
This is a random choice for your engine.
You would really need the model and probably the serial to get the correct specs.
The Perkins Model AD3.152 engine used in Massey Ferguson 135 tractors built between 1968 and 1975 had the following torque specs.
45 hp
1211 ft pounds of torque at 1300 RPM
Max RPM was 2000
Feb 16, 2013 | Cars & Trucks
What is the torque setting on the head bolt for a harley davidson sportster
Cylinder Head Bolt Installation
Factory Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in three stages.
1. Tighten each bolt to 7-9 foot pounds of torque.
2, Tighten each bolt to 12-14 foot pounds of torque.
3. Mark each head bolt and head with aligning marks. Tighten each bolt 1/4 turn (90 degrees).
Torque Wrench Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in four stages.
2. Tighten each bolt to 12-15 foot pounds of torque.
3, Tighten each bolt to 22-25 foot pounds of torque.
4, Tighten each bolt to 38-42 foot pounds of torque
Good luck, i hope this helps.
Aug 06, 2011 | Harley Davidson XL 1200 C Sportster Custom...
Need the torque settings for a '94 cutlass supreme sl 3.1 in reference to the cylinder heads I need the sequence and the torque if possible a diagram
Heres the diagram and specs for the cylinder head and also i have enclosed the torque specs for the intake and its tightening sequence, good luck and hope this is helpful, have a good day.
Cylinder head bolts. Step 1) tighten to 44 ftlbs.
Step 2) tighten an additional 95 degrees.
Lower intake bolts. Step 1) all bolts are tightened to 115 inch lbs.
Upper intake bolts.Step 1) all bolts tighten to 18 ft,lbs no diagram, start in the middle and work your way out going cris cross.johnjohn2_88.gifjohnjohn2_89.gif
Mar 19, 2011 | Oldsmobile Cutlass Supreme Cars & Trucks
Correct pressure for torque the head of mazda pickup 1998
Since you didn't say which engine you have, I've pulled torque specs for 3 different engines. Also, since I can't include a diagram showing the relative locations of the numbered head-bolt locations, it would be a good idea for you to purchase a vehicle specific repair guide that will show this info.
Take particular note about the TTY (Torque to Yield) bolts used on 2 of the 3 engines shown. It is said that new head bolts MUST BE USED when head is replaced or re-installed to obtain the proper torque.
B2500 4 Cylinder
Torque sequence: --------- ' 10 6 2 4 8 ' front ' ' ' 7 3 1 5 9 ' -----------Step 1: torque in sequence to 51 Ft/Lbs Step 2: torque again in sequence to 51 Ft/Lbs Step 3: final tighten all bolts an additional 90 to 100 degrees recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) that permanently stretch during the initial installation. New head bolts must be used when cylinder head is replaced or re-installed to obtain proper torque.
B3000 3.0 6 Cylinder
Torque sequence ---------- ' 6 4 2 8 ' ' ' ' 5 1 3 7 ' ---------- Step 1: torque to 59 Ft/Lbs Step 2: loosen in sequence (1) full turn Step 3: torque to 41 Ft/Lbs Step 4: torque to 73 Ft/Lbs
B4000 4.0 6 Cylinder
Torque sequence --------- ' 5 1 3 7 ' ' ' ' 6 4 2 8 ' --------- Step 1: torque cylinder head bolts in sequence to 26 Ft/Lbs Step 2: torque cylinder head bolts to 56 Ft/Lbs Step 3: turn cylinder head bolts in sequence an additional 90-degrees recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) that permanently stretch during the initial installation. New head bolts must be used when cylinder head is replaced or re-installed to obtain proper torque.
Good luck with this job!
Feb 06, 2011 | 1998 Mazda Pickup
What are the torque settings for a 1997 audi a3 1.6 cylinder head
The torque settings for a 1997 Audi A3 1.6 cylinder head:
1. Tightening sequence
2. Cylinder head instructions:
2.1. Renew bolts: Yes.
3. Tightening torques:
3.1. Stage 1 - Tighten: 40 Nm.
3.2. Stage 2 - Tighten: 90 degrees.
3.3. Stage 3 - Tighten: 90 degrees.
Please do rate my response. Thanks!
Jan 22, 2011 | Audi A3 Cars & Trucks
Need to know cylinder head bolt torque specs
Head Bolt Torque For your 1994 Oldsmobile Cutlass Supreme (3.4L SFI DOHC): clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 6 2 3 7 | | 5 1 4 8 | --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque. clearpixel.gif clearpixel.gif clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 8 4 1 5 | | 7 3 2 6 | front --------- of engine | 6 2 3 7 | | 5 1 4 8 | Step 1: torque to 40 Ft/Lbs --------- Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.
Feb 07, 2009 | 1994 Oldsmobile Cutlass Supreme
Hi I'm looking for cylinder head torque settings for a 1992 BMW 316/318 e36
BMW cylinder torque setting all models
According to my service manual as follows.
Cyl head to engine block (torx e12 M10 bolts)
Stage 1 30nm (22 ft – lb)
Stage 2 + 90 degrees
Stage 3 + 90 degrees
Cyl head to lower timing chain cover 10nm (89in – lb)
The tightening sequence is from inside to outside crossover as normal. Loosening sequence is from outside to inside crossover. Remember to set torque wrench at low setting and work gradually up through the whole sequence until you get the desired torque.
Jun 16, 2008 | 1992 BMW 3 Series
Pramac Towable Diesel Generator 219 kW, Perkins Engine, Model Logo
88 people viewed this question
Top Pramac Electrical Supplies Experts
RSole
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
