Question about Apple iPod touch
IPOD touch volumn will not stay up, alway goes back to 0.
IPOD Touch, when you increase the volume it goes back to zero
This happened to me all i do is turn it off completley (not on sleep) and then it works
Posted on Aug 21, 2009
  • Olivia Hanna
    Olivia Hanna Nov 30, 2011
    Yeah that sometimes happens to me, I don't know why but if when it goes to zero, just turn it back up and it should stay there. Works for me. :-)
  • 342 Answers
I would recommend restoring your ipod. Below are the steps on how to do this just in case you need them.
Last Modified: February 16, 2009 Article: HT1414 Old Article: 305744 Using the Restore function for your iPhone or iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPhone or iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPhone or iPod touch settings are restored to their factory condition.
Whenever you restore your iPhone or iPod touch, Apple highly recommends that you perform a sync prior to restoring in order to back up any changes since your last sync. If you have movie rentals on the device, see this document before restoring.
Use the following steps to restore your iPhone or iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update. Connect your iPhone or iPod touch to your computer. Select your iPhone or iPod touch when it appears in iTunes under Devices. Select the Summary tab. Select the Restore option. When prompted to back up your iPhone or iPod touch's settings before restoring, select the Back Up option (as seen in the image below). If have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you (As long as you've backed up your device, you should not have to worry about restoring your phone).
Once the restore process has completed the iPhone or iPod touch restarts and displays the Apple logo while starting up
Hope this resolves you issue :)
Posted on Apr 24, 2009
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
How do i turn the volume up on the ipod 1 touch
on the ipod touch first gen there is a slider at the bottom of the screen
put your finger on the slider at the bottom of the screen and slide your finger from left to right to increase the volume.
hope this helps
Nov 26, 2013 | Apple iPod shuffle Second Gen. Silver (1...
I cant increase the volume !!
micro switch needs replacement, it has worn out.
Jun 13, 2012 | Apple Iphone, Touch, Ipod, & Nano
Sound
try to replace the (-) volume button it is defective so the volume will auto down..
after you replace that 100% works fine..
Apr 27, 2012 | Audiovox PLV16081 8 in. LCD TV
Very low volume on a brand new ipod touch what should i do to fix this problem
Turn on Ipod, on the left hand side there is a volume control switch. While you are on a song, hold the top of the volume control switch to increase the volume.
If that does not work then touch "settings", then touch "music" and make sure your "Volume Limit" is set to "Off", if it is not touch "Volume Limit" and set it to "Off".
Please do not forget to rate me
May 16, 2010 | Apple iPod touch Second Gen (8 GB,...
My ipod touch 2G speakers are not working
yes i have the same problem, only the alarm noises work. And when i take my headphones out, the noise level beam goes away.:S who can help me ??
Dec 28, 2009 | Apple iPod touch
Volume Control on my SCBT100 Blu-ray Home Theatre doesn't work.
Unplug the power and let it sit. Plug it back in and it should fix. Worked for me.
Oct 12, 2008 | Panasonic Home Theater System System
Apple iPod touch Logo
377 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
