Question about Krups Dolce Gusto KP 2100 Espresso Machine
Dolce Gusto KP 3006 is leaking from the pod area. Any solutions?
2 Suggested Answers
  • 449 Answers
SOURCE: dolce gusto lattee machine keeps leaking round the pod area
If its not condensation the seal is gone.
Posted on Jun 06, 2012
The red light comes on and then goes green. Filled with water and pod in but nothing happens. Completely silent.
one step at a time do you get water with out putting the capsule
what is it doing is there any sound coming from the pump do you have any flashing red light? need more info
Jan 11, 2016 | Krups Dolce Gusto KP 2100 Espresso Machine
Will not pierce pod completely
you have to change the plate which is based at the roof of the capsule holder it will wear out due to hot water
May 12, 2015 | Krups Dolce Gusto KP 2100 Espresso Machine
Why is my dolce gusto is leaking. can it be repaired?
remove the plate which is clipped neat the capsule holder and try again if it works see if you can opening the hole or replace
Oct 05, 2014 | Krups Dolce Gusto KP 2100 Espresso Machine
Leaking from pod holder
I had the same exact problem and my machine started to smell even though I descaled it regularly and cleaned any of the milk that dripped out of the capsule. Finally, we took apart the whole machine and found a TON of dried, rotten milk. It was disgusting. We completely cleaned the accessible part of the machine with a vinegar solution and put it back together. I was hoping that we fixed whatever was causing the leaking, but no such luck. It is still leaking and still smells bad, so we are going to get a different kind of machine. I will not be getting a Dolce Gusto again, because I have called their customer service multiple times about this problem, and none of them ever had a solution. The whole milk thing grosses me out, I think I'll just get a single serve coffee machine and foam the milk myself.
Aug 25, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
Dolce gusto machine turns itself off
i there why does th machine keep running on once you put the pod in unlike the tassimo once you have the right amount out the pod it cuts off dolce run on for ever and you drjnk ends up wattery
Apr 16, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
Hine ran out of water while making coffee. Now it wont work.
Sounds like an overload fuse has blown (possibly) there are resettable fuses in some, not in others. Have you checked you element?
Apr 07, 2012 | Krups Dolce Gusto KP 1006 Espresso Machine...
My krups dolce gusto stopped working. The lights turn on but nothing happens, no water comes out. I have tried every suggestion there is but nothing has happened..I'm afraid I'll waste money on...
Hi, Could be a number of things. Is your pump working. Thermoblock maybe blocked or faulty. A thermo sensor on the thermoblock maybe faulty. Brewunit maybe jammed. Descale will not help if it wont pump. Id be looking at the thermoblock or sensor. If their at fault then the machine will do nothing. See how you go and ill keep a look out for any more questions you may have. Dazza Repairer
Oct 23, 2011 | Krups Dolce Gusto KP 2100 Espresso Machine
My dolce gusto krups machine won't open and allow me to remove the pod.
We have had this problem twice now. The solution is to drill (yes drill!) through the capsule - a blocked outlet from the capsule itself and the injection of hot water creates a high pressure seal - you have to release the pressure. Do this over the sink - I had hot chocolate spraying about 6 feet from the machine when the pressure was released!! But this solved the problem.
Mar 05, 2011 | Krups Coffee Makers & Espresso Machines
Krups Dolce Gusto KP 2100 Espresso Machine Logo
46 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
