Question about Samsung BX2450 LCD Monitor
My samsung BX2450 is in sleep mode and i can not get it out of it , it flashes past HDMI channels i input HDMI but it remains in sleep mode then so it not an input issue , power is fine checked that is there no way i can hard reset it if keeping the power button in iv tried that aswell please assist
lukster
  • 217 Answers
SOURCE: HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Posted on Jul 20, 2008
SOURCE: samsung syncmaster 711p power issue
Its a general fault however all these units are under a 3 year warrantee the dates printed on the back, just call 08706010309 speak to a service engineer and they will arrange a swap out within 5 working days, no need to a receipt as they can tell the units age from the serial. the replacement will be under the same 3 years cover in my case it was for another 6 months
Posted on Aug 08, 2008
sabreusa
  • 271 Answers
SOURCE: HDMI failure Samsung HL-R5087W 50 in HDTV
After reviewing the service manual for this set, the problem is is in the DIGITAL BOARD. To get the right Digital Board you will need the Version number of the TV.
Good luck
N Sabre
Posted on Nov 09, 2009
SOURCE: Samsung LN-T4042h to PS3 "Not Supported Mode"
i fixed it, on the PS3 u hold the power Button while holding then Switch the power button on on the back for like 10 sec and it resets the picture settings to default
Posted on Nov 21, 2009
budmrtn
  • 11361 Answers
SOURCE: My samsung syncmaster 2493 wouldn't come out of
Look at the power supply, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 30, 2009
My samsung led tv is getting dark
With a DLP TV, getting a darker picture means it is time to change the bulb.
Feb 16, 2015 | Samsung Televison & Video
Samsung syncmaster sa350 start computer up then in the top left corner it shows a graphic that says hdmi, then the computer screen goes blank and the power button just blinks red continueously with a blank...
Is your computer connected via the HDMI cable? If not pull up menu and change to another input type. If it is HDMI, check cable ends. You can test by plugging into a Blue ray player and see if video plays on monitor as a test method to verify video coming from computer incase your video card has died for some reason..
Your monitor is going into sleep mode since it can not see an HDMI signal coming across the input. Check your cable though.. sounds like the biggest culprit to me.
Jan 29, 2014 | Smart Modular SV3170A
HELP! bought a BX2450 Samsung monitor and it`s not showing full resolution, i need a driver for my macbook pro 13` (mid 2010) anyone????
I have a very strong suspicion that you are connecting your Macbook Pro to the VGA input on the monitor instead of the HDMI.
Your Macbook Pro uses the Mini Displayport connection type. Are you using a Mini Displayport to HDMI adapter? If not, purchase one and that will resolve your issue.
If you are already using a Mini Displayport to HDMI adapter, make sure your resolution is set to the maximum (1920x1080 according to Samsung's website) in Apple Menu > System Preferences > Displays > Display.
If available, select the 'Best for Display' option which should automatically set the maximum resolution for the display. If not, select 'Scaled' and choose 1920x1080.
Sep 04, 2013 | Samsung BX2450 LCD Monitor
Can't locate input channels,only tv and av1 are highlighted
If none of the inputs (or most) are missing the set may need to have a reset of some type done to it--If a Samsung look thru the owner manual and then call Samsung customer service with the full model number.
May 26, 2012 | Televison & Video
Can i get hd channels without an hdmi input. The TV is an HDTV
Sounds fishy to me----almost every provider uses a box that has either HDMI or Component outputs for HD--your set should if HD ready have a Component input for that also--if it only has the HDMI for that you may be out of luck. Check the owner manual to see if one of the Component inputs is HD or not.
Apr 06, 2012 | Televison & Video
Jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
07
NOW 12:20 PM
SLEEP TIMER OFF/on
ON/OFF TIMER EVERYDAY
ON TIME 7:00 PM
OFF TIME 10:00 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
Dec 22, 2010 | JVC AV-36F702 36" TV
UNABLE TO REMOVE SLEEP MODE
you can't take it off of sleep mode. the only thing you can do is set it to go into sleep mode anywhere between 0 to 99 minutes. you do that by pressing "menu, 1, and 8." there, you can input how long you want sleep mode. no way of completely disabling. i'm thinking that somehow, it must have gotten set to 0 minutes.
hth,
razors
Mar 30, 2009 | Brother IntelliFAX 4100 Laser Fax
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung BX2450 LCD Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
