Question about Car Audio & Video
When hooked up it want come on.done replaced the fuses and it still want come on
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 33 Answers
Do u have power and a good ground and does your remote wire have power
Posted on Oct 16, 2013
Replacing a 100a battery fuse
Make sure you disconnect the battery first so not to shoot sparks everywhere. Then one at a time take bolts out of each end of the fuse put new one in it's place put bolts back in make sure the amp and stereo are off hook the battery back up and you are done.
Jan 29, 2013 | AMP Anl Fuses Car Audio Gold Plated 100a...
My 1988 toyota 4runner won't show signs of getting power despite new battery
Hello, open the fuse box and look for a large 80A fuse, replace it if necessary, if it doesn't have the fuse some early versions used fusible link wire from the positive battery terminal instead, this is a fuse and will burn out inside the insulation if there is a short, check it using a 12 volt test light, you can get fusible wire from the auto parts store.
Apr 22, 2017 | 1988 Toyota 4Runner
Blowing fuses when power is hooked up
once you've done this, hooked up a radio backwards, you have to change the resistor...take it to a shop I only charge $18
Nov 26, 2009 | Cobra 29 LTD CB Radio
Disconeced battery to check fuses, hooked battery up when done, horn honked, whole vechical is dead no power, checked with a fluke have power to fuse box.
You have to have battery hook up to check fuses with test light,
When you unhooked battery you put vehicle in thief mode,
thats why horn honked and disabled ignition.
Nov 21, 2009 | 2008 Dodge Grand Caravan
I replaced my cab and after i switched the dashboard assembly/wiring etc the 4wd wont work !! where do the wires hook up at the fuse panel ??
DID YOU HOOK UP THE SHIFTER UNDER NEITHE THE TRUCK. IVE DONE THAT SWAP 4 TIMES THIS YEAR,AND YOU SHOULD ONLY HAVE PULLED HARNES AND COMPTER OUT OF RIGHT HAND SIDE, THE DASH CONNECTOR ON LEFT SID ENG BAY, AND YOUR SHIFTER HARNES ON THE UNDERSIDE OF THE CAB
Oct 30, 2009 | 1990 Chevrolet K1500
Amp keeps blowing the fuses
Serious short circuit on your output transistors, need replacing.
Sep 28, 2009 | JVC KSAX4504 MOSFET 600-Watt Amplifiers...
My dryer all the sudden is blowing the fuse at the panel. It runs for a short time and then blows the fuse. Sometimes it just keeps running and doesent blow the fuse. It is hooked up properly and has never...
UNPLUG THE CORD then,.,,,maybe the cord hooked to the dryer terminal block and just follow the cord to the unit and take off the axcess panel to power cord hookup is shorting out and needs to be replaced being hooked up properly is why its the first place to look for its
Aug 26, 2009 | AEG Dryers
Blower motor not working 1994 jeep cherokee
It sounds like you have an issue with your fuse block. Pull the fuse for the radio and remove the buzzer. see if this changes the situation.
Oct 29, 2008 | 1994 Jeep Cherokee Country
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
